Old 04-06-2021, 12:19 PM #76
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Originally Posted by Flesh Eater View Post
Bumping this.
I was looking at the Power Stop Z36, 338mm kit from Rock Auto for my 08' Runner. Anyone use that kit before? I've had great luck and performance with these Z36's on my Chevys when towing across the country or in the mountains. I notice there were two options at 319mm and 338mm.
Thanks!
I did the 5th gen setup on my 4th a while back. Worked great when it did, but in the end every OEM caliper upgrade I've done has seized.
2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 02:20 PM #77
GLW68 GLW68 is offline
GLW68 is on a distinguished road
Update on install
Just an update on longevity.
My right front Centric reman lasted 4.5 years and 35K miles before seizing. I expected a bit longer life. Although can't really say it's better or not without using new calipers.
Driver's side was fine. Akebono pads were in great shape on the functioning side. Would highly recommend those.
Replaced them both with O'Riellys and Wagner OEX 976 pads because they had them in stock and I wanted to fix it the same day. I'm sure that was/ will be a mistake LOL. (Caliper hardware included was incorrect - twice...had to polish old pins and reuse. Pads fit fine, but don't seem to be as strong stopping as the Akebono)
GLW68 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 03:22 PM #78
Flesh Eater Flesh Eater is offline
Flesh Eater is on a distinguished road
Do these not work on normal slides that can be serviced periodically to keep from seizing?
First Toyota, never tore into one before.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 06:05 PM #79
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold
Real Name: Skip
Usually the issue is the piston/s seizing in the bore.
2004 Limited V8
Old 04-06-2021, 06:29 PM #80
Same here. Not a slide pin issue. Piston issues.
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 8 06-22-2012 01:52 AM
brake upgrade q avenged yoda 3rd gen T4Rs 3 12-05-2011 11:34 AM
EBC Brake Upgrade pcooke1 4th Gen T4Rs 17 03-24-2011 09:39 AM
Brake upgrade macoyle 4th Gen T4Rs 1 02-20-2011 03:21 PM
SE brake upgrade? Teqeeler 4th Gen T4Rs 5 02-02-2010 01:46 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
