Old 04-06-2021, 12:19 PM #76
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Originally Posted by Flesh Eater View Post
Bumping this.
I was looking at the Power Stop Z36, 338mm kit from Rock Auto for my 08' Runner. Anyone use that kit before? I've had great luck and performance with these Z36's on my Chevys when towing across the country or in the mountains. I notice there were two options at 319mm and 338mm.
Thanks!
I did the 5th gen setup on my 4th a while back. Worked great when it did, but in the end every OEM caliper upgrade I've done has seized.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 02:20 PM #77
GLW68 GLW68 is offline
GLW68 is on a distinguished road
Update on install
Just an update on longevity.
My right front Centric reman lasted 4.5 years and 35K miles before seizing. I expected a bit longer life. Although can't really say it's better or not without using new calipers.
Driver's side was fine. Akebono pads were in great shape on the functioning side. Would highly recommend those.
Replaced them both with O'Riellys and Wagner OEX 976 pads because they had them in stock and I wanted to fix it the same day. I'm sure that was/ will be a mistake LOL. (Caliper hardware included was incorrect - twice...had to polish old pins and reuse. Pads fit fine, but don't seem to be as strong stopping as the Akebono)
GLW68 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 03:22 PM #78
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
Do these not work on normal slides that can be serviced periodically to keep from seizing?
First Toyota, never tore into one before.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 06:05 PM #79
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Usually the issue is the piston/s seizing in the bore.
2004 Limited V8
Old 04-06-2021, 06:29 PM #80
Same here. Not a slide pin issue. Piston issues.
Old 06-27-2021, 01:58 AM #81
Pirate702 Pirate702 is offline
Real Name: Mark
Pirate702 is on a distinguished road
Real Name: Mark
Hello Mike, my first post on here. Question, I am looking at getting on 07 4runner Sport. Do they have the brake issues like the sr5's? Will I need to upgrade the calipers and rotors eventually? Also was wondering what size tires you are running and if you have any lifts on your 4th gen?
Pirate702 is offline   Reply With QuoteReply With Quote
Old 06-27-2021, 05:20 AM #82
Bkt4runner's Avatar
Bkt4runner Bkt4runner is offline
Bkt4runner is on a distinguished road
Bkt4runner's Avatar
Originally Posted by Ducmonsta View Post
After trimming the backing plate and painting, this is what you'll end up with.
Attachment 83047
Somewhat of the finished product.
Attachment 83048
Glock_19 also had us install Hawk performance pads on the rear. There's really no need to show you guys that part of the install. We also installed Goodrich's stainless brake lines and flushed the entire brake system with DOT4 fluid.
Keep us posted on how well these rotors last. My main concern is that they are more likely to crack then the plain non-slotted. I'm getting plain Centric cryo treated rotors with new oem calipers, oem pads and Goodrich stainless steel brake lines on my 2003 SR5. They should last well over 100,000 miles and are reasonably priced too.
-2003 SR5 V8, white with grey trims
Bkt4runner is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 07:45 PM #83
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
35k miles then seized? That sounds faulty to me.
meltdowner is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 08:03 PM #84
4.5 yrs. sitting outside doesn’t help longevity.
Factory set lasted a good long time. But that has been about average for replacements
Old 07-14-2021, 02:33 PM #85
GeoFlory's Avatar
GeoFlory GeoFlory is offline
Real Name: George
GeoFlory is on a distinguished road
GeoFlory's Avatar
Real Name: George
Well, I'm not mike, and I don't know if the '07 Sport has brake issues, but if your question has not been answered, I recently bought an '07 Sport Edition, and I can tell you that you will not have to upgrade anything (never know about repairs); the Sport Edition comes with the 338 mm rotors and companion 13WH calipers along with the Brake Dust Shield (backing plate?) for 17" wheels. Apparently some people bend and/or trim the 16" Brake Dust Shield when doing the 338 mm upgrade. I also have a '09 SR5 with the 319 mm rotors; my front rotors and dust shields are looking in rather bad shape and one of my calipers seized up on me the other day; that means I need all the parts, so I plan to go with the full 338 mm upgrade. After a bit of searching, I found what they call their Brake Dust shield (PN 4778160120 & 4778260120) for 17" wheels, which I will use to replace the present dust shield (PN 4778135160 & 4778235160) for 16" wheels. I already have 17" wheels from the factory, but only the Sport Edition gets the 338 mm brakes, regardless of wheel size from the factory.
If there remains any doubt about it, the 338 mm rotors are PN 4351260151 (X2), and the 13WH calipers to go with them are PN 4775060261 & 4773060261 (L&R). I have confirmed that the pads are the same for either size of rotors.
1998 4Runner Ltd, V6, 4WD -- Traded for '07
2007 4Runner Sport Ed, V8, 4WD
2009 4Runner SR5, V6, 4WD
GeoFlory is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 05:23 AM #86
Real Name: Mark
Real Name: Mark
Thanks for the reply and info. I think my rotors are warped or something, when I go to brake it shudders like crazy. I am pretty sure they have never been changed and have 194,000 on them. So I am putting on new rotors, calipers, and pads just to be sure. lol
Old 08-01-2021, 10:26 AM #87
GeoFlory's Avatar
Real Name: George
GeoFlory's Avatar
Real Name: George
Originally Posted by GeoFlory View Post
. . . I don't know if the '07 Sport has brake issues, . . .
I have been studying the 4th gen brake caliper situation, and believe there may be an issue. After reading of other people's problems, and now undertaking my first brake job on a 4th gen ('09 SR5), my right front brake recently locked up and got very hot driving home. Looking into it immediately, I also checked the left front caliper and found that one side was frozen and apparently had been for some time. I couldn't even compress the pistons with a crowbar. I had thought about disassembling the calipers and lubing them (as the FSM recommends), while I got the parts for the 338 mm rotor conversion, but decided it might be impossible for me to get the pistons out. I just put it on jackstands and started disassembling the brakes. I have now got all the parts and have started reassembling.
Since the FSM only recommends lubing the calipers and replacing seals when new pads are installed (I've never heard of anyone actually even doing that), I have decided to add some preventive maintenance of my own. I see that it is commonly recommended to flush brake fluid every two years or 30k mi. Therefore, every two years, I will remove and lube the pistons of my calipers, check the seals, and flush the brake fluid. I haven't kept good records of how often I replace brake pads, but I would estimate it is a lot longer than the purported average (20k-70k mi). Thinking back, I would say I replace pads no more than once every five to ten years. I had my '98 4Runner for 14 yr and replaced them once. Anyway, I will report in a couple of years if this works out well.
Meanwhile, I had trouble getting the brake lines out of the calipers. I used a trick from the internet: I got a 10 mm flare-nut wrench, put it over the brake-line fitting, clamped the 10 mm wrench opening tight over the fitting with vise-grips, and then beat the wrench with a rubber mallet until it broke loose. The fitting didn't seem corroded when I got it out, making me think it may have been over-torqued. Toyota spec says to torque it to 15.2 Nm (11 lbf ft); I am going to use Loctite 242 (blue) on this fitting to secure it, prevent corrosion, and seal it. In accordance with Loctite instructions, I will reduce the torque by 20% because Loctite is effectively a lubricant; so, I will torque the brake-line fitting to 8.8 lbf-ft, which is actually just as tight, since the lubricant allows the fitting to slide into the same final position with less friction. I will also report in a couple of years if this works out well for removing the brake line.
If anyone is wondering how to torque a brake-line fitting, connect a spring scale to the opposite end of the flare-nut wrench; measure the length of the flare-nut wrench from the center of the 10 mm end to the point of attachment of the scale (5.25"). Compute the force necessary, with this moment arm, to give 8.8 lbf-ft of torque: 8.8 * 12/5.25 = scale reading (20 lb).
Old 08-08-2021, 03:47 PM #88
GeoFlory's Avatar
Real Name: George
GeoFlory's Avatar
Real Name: George
Well, the deed is done; I have gone from 319 mm rotors to 338 rotors on my '09 SR5 to match my '07 sport. I don't really consider this a significant upgrade to the '09 SR5, since I believe the original is totally adequate because the SR5 has a GVWR of 5580 lb and the Sport Edition has a GVWR of 6005 lb; the bottom line is 338 mm rotors and 13WH calipers cost the same, so since I was replacing the parts, I went with 338 mm rotors etc. ( I tow the boat a lot). On the rear brakes, my rotors were in perfect condition (even though the local brake shop quoted to replace them for $200 Plus $140 labor); however, I replaced the original caliper seals (from 2009) which were visibly less pliable than the new seals, but otherwise in perfect condition, with the new supplied seals. While I was at it, I inspected the emergency brake; it appears to be in perfect condition, so I left it alone, even though I had planned to disassemble and lubricate it. A local shop had quoted me $1600 for a brake job; I did it myself with improvements for $400 (I saved about $500/hr doing it myself. Maybe I'm in the wrong business).
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
brake upgrade q avenged yoda 3rd gen T4Rs 3 12-05-2011 11:34 AM
EBC Brake Upgrade pcooke1 4th Gen T4Rs 17 03-24-2011 09:39 AM
Brake upgrade macoyle 4th Gen T4Rs 1 02-20-2011 03:21 PM
SE brake upgrade? Teqeeler 4th Gen T4Rs 5 02-02-2010 01:46 AM
