Nobody probably reads my build thread.
A good weekend mod I did recently was to install an FJ passenger side wheel well liner to cover up more of the air intake inlet
The FJ's have a different liner with the air vents moved up. If you guys trimmed your front liner like I have with my aftermarket bumper, it leaves a lot of the air intake exposed.
Parts needed:
Liner part# 5380735111. OEM is like $160 but aftermarket is $25.
Orange and blue clips #75495-35010 #75397-35010
Black 'pinch' clips
FJ's:
Mine:
I layered the factory liner with the new FJ liner because the FJ liner didn't follow the rear of the fender very well so I used a bit of both.
Intake entrance:
Not much of a path for water:
The one extra bolt/washer is used to help hold up the bottom of the new liner:
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
