03-12-2013, 09:42 AM
Removing rear diff. fill plug.. any ideas?
My rear differential fill plug is frozen in place. I haven't even attempted the drain plug yet. I used a 24mm socket with 1/2" drive ratchet and it started to round off the bolt. So then I tried a 15/16" box end wrench. No luck. Tried a chisel and hammer. No luck.
I have a new drain and fill plug at the dealership waiting on me to pick them up. Any ideas on how to get the existing fill plug out???
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
03-12-2013, 09:57 AM
Real Name: Kevin
Real Name: Kevin
You absolutely need a 6 point socket, for sure. Then PB Blast twice a day for two or three days should help. If that doesn't do the trick, give it some heat from a propane torch, LOTS of heat. If it still won't budge after a couple heat cycles, buy a disposable 15/16th six point socket and hammer it on there nice and tight. If it still rounds the corners and won't budge, your last resort is to weld a harder nut to the face of the fill plug and turn it with that.
Obviously you'll want to order new fill and drain plug bolts (I like the hex head ones), and this time don't spare the anti-seize. Good luck!
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
Nevermind.. I just searched Google and found lots of threads on this topic. Should have done that first. My bad.
03-12-2013, 09:58 AM
Real Name: Jesse Allen
Seafoam deep creep and a pair of channel locks or vice grips.
____________06 SR5 4WD V6______________
High Country Fab Winch Bumper|Engo 10k| URD T.C.A.I + URD MAF Cal|885s on 5100s|Daystar 1.5|4Crawler 1.25 BL|265/70/17 Treadwright Wardens|Spidertrax|VSC Off Switch|Amsoil fluids
Thanks!
03-12-2013, 09:59 AM
I have heard good things about PB Blaster for unseizing bolts...havent used it yet but may be worth a try.
2007 4Runner Limited V8
03-12-2013, 10:08 AM
Get a impact that you hit with a hammer and it turns ( not sure the name of tool ) . Couldn't get mine off , hit one of these and it came off in 4 shots .
99 limited -millennium silver - e-locker - toytec adjustable coil overs - 890 OME rear springs - bilstein 5125 rear shocks - 1'' body lift - diff drop - pan hard drop - spidertrax 1 1/4 wheel spacers - goodyear duratracs 285-75-16 -
build =
http://www.toyota-4runner.org/3rd-ge...-good-bad.html
03-12-2013, 11:44 AM
You can also try using a 50/50 mix of automatic transmission fluid and acetone. It's supposed to be orders of magnitude better than PB Blaster or other comparable products.
03-12-2013, 12:02 PM
Real Name: Kevin
Real Name: Kevin
I actually tested a 50/50 ATF and acetone mix against PB Blast against my lugnuts, the '85 was an ocean truck and had been sitting for years and they were frozen so tight I was twisting studs off. So I soaked one set in PB Blast for two days, they came free on the second day. I hit the other side with the 50/50 twice a day for four days, then gave up and used PB Blast, they came free on the 5th day. That ATF/acetone mix doesn't work.
PB Blast is the bomb, you just need to give it time to cook.
03-12-2013, 12:32 PM
Great ideas guys. I'll give it another whirl tonight when I'm home from work.
03-12-2013, 02:03 PM
All good suggestions. I tried all of them on mine back when I first got the vehicle. None of them worked though, sometimes that just happens.
I had my mechanic weld on a socket and remove it.
2006 SE V8 4WD
275/70/17 BFG ATs*TT Ultimate/5100s*SPC LR UCAs*AP Spacers*Gibson*Stubbs*RCI Skids*AFE*JVC*On Board Air*48" HL
03-12-2013, 09:49 PM
Success!
Used a large air compressor powering an air chisel and shocked the fill plug loose. Then used a heavy duty air impact gun to free the drain plug. Replaced both with new plugs and new crush washers, torqued carefully by hand. The previous owner or whoever worked on this thing before must have put these in with an impact gun...it was ridiculous.
Put 3 quarts into the diff and it still didn't run out of the fill hole. These axles are hard core. You'd see something like this on a 2500 series pickup.
03-12-2013, 09:53 PM
Congrats!!!
Did you fill it with synthetic??
2004 4Runner Sport Edition 4x4, V6
Stratosphere Mica
284k
03-13-2013, 02:57 AM
Interesting, a member had posted a link to a military study (IIRC) that talked about the 50/50 being the best to use. I had been wondering how well it works.
03-13-2013, 09:03 AM
Real Name: Kevin
Real Name: Kevin
Was that a military test? I thought it was a machine shop that did that.
In any case, I wasn't impressed with their test, it was sloppy. They had no control, no way to know that they were subjecting their test nuts to the same standard of abuse, etc. I'd love to see a proper lab run some rigorous tests and see what they get.
