01-01-2014, 10:16 PM
#31
Originally Posted by LTDSC
yes. My last set up with 2.5" spacer and tacoma struts.
well im only looking for about 2 inches of lift up front so i will see what im going to get. might do .85 on 5100's and see what that gets me
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
01-01-2014, 11:45 PM
#32
Real Name: Sam
Real Name: Sam
probably get about 2" out of it.
01-01-2014, 11:50 PM
#33
are you running longer brake lines on your truck?
my main reason for going with about 2 inches of lift is not to have more maintenance then stock. not to tall for cv problems but tall enough for the look i want
01-01-2014, 11:52 PM
#34
Real Name: Sam
Real Name: Sam
i need to order rear brake lines and front. I dont "need" them now i just want them for peace of mind.
02-20-2014, 04:15 PM
#35
Does anyone know if 2014 Tacoma TRD fronts will bolt right in our 4runners?
17 Tundra, 18 4runner
05-16-2014, 02:12 AM
#36
well i got the trd tacoma front coils. now to search for fj read springs and then 5100's and im set
05-16-2014, 04:56 AM
#37
Out of curiosity. Why are you going with 5100s? The spring/strut combo you have there is a direct swap, a lift from 1.5-2" and from everything I've read a VAST improvement in ride.
Not trying to talk you out of the 5100s or anything. I would love a set myself but if you have a good shock why drop the extra $. The rear tacoma shocks and fj springs combined with the fronts you have pictures would probably be a very nice improvement with minimal fund drainage.
'03 with '12 TRD Taco swap with 1/2" Toytec front/1.5" DaystarRear, 265/70/17 Cooper Discoverer ATP's on Sequoia Split Spokes
Scarcely for a righteous man will one die; yet perhaps for a good man some would even dare to die.
Romans 5:7
05-16-2014, 09:54 AM
#38
so what year springs and struts from a Tacoma would be a direct bolt on for an 05 Runner? or are you guys just gonna use the springs???
Mike....
05-16-2014, 11:19 AM
#39
Mike....
All 2005 and up, you just want to make sure it's a 4x4 TRD I believe.
I am going to use the springs, struts and rear shocks.
Romans 5:7
05-16-2014, 11:27 AM
#40
Mike....
from what i have been reading it gets about 1-1.5 inches of lift from the coils and im looking for something around 2-2.5 so thats why i would go with 5100's set on .85
05-17-2014, 11:11 PM
#41
Hey guys new here... just bought a 2003 limited no xreas. I also purchased a complete trd tacoma suspension to put on it. At the start of this thread someone mentioned a bushing swap in the rear. Is that a part you buy or do you remove it from the 4runner parts? Also, I was going to do a daystar 1.5/2.5 spacer lift but after reading I m not sure what spacer sizes I would need to use in combination with the tacoma trd setup. Any help, advice or input would be awesome. I only know enough to be dangerous
05-18-2014, 10:12 AM
#42
Is yours 4x4 and v6 or v8? The tacoma set up with the Daystar 2.5/1.5 will probably be nose high and will definitely max out your upper control arms which will mess with your alignment.
How much overall lift are you wanting to gain?
Romans 5:7
05-18-2014, 09:27 PM
#43
I got some front struts off my trd 05 tacoma sport with a daystar leveling kit already pressed on for sale if somebody wants ? Its the 1.5 spacer lift.
IN YOTA WE TRUST
05-19-2014, 01:06 AM
#44
My t4r is a v8 4wd. I figured the 1.5/2.5 wouldn't work together with the trd setup. I have a brand new set of 255/75/17 duratracs that I want to put on some fuel 17x8.5 wheels. I like the more aggressive look of the 1.25 spacers but I wanted to achieve the same look with wheel offset. I ordered +14 but I think I should have bought -5 or -6 can't recall for sure which it was. I don't do any heavy off road stuff so that's not needed to factor in. But I do want level not a fan of rake. Would fj rear springs in back and taco up front give me a mild level lift?
05-19-2014, 01:17 AM
#45
i think you would be looking at about 1-1.5 in the front and .5 to 1 in the rear if im not wrong
