Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Old 12-17-2017, 06:44 PM #46
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Originally Posted by chiefdancinglizard View Post
Watchya using for the hi lift setup? I was trying to use those might mounts and it just didn't feel solid with the high lift. Works great with the maxtrax though, bolted in the corners. Very interested in the specs of your setup. What size hole is that?
Hi lift mount was 1/2" holes drilled through crossbars with 1/2" bolts down through, wing nuts on the bottom. Secure and tool less. Lock it with a cable lock.
Since I've moved to a prinsu rack for more space I'm also selling my Yakima 23H mounts (Set of 4) and that aluminum rotopax contraption if anyone wants it. Rotopax mounts not included.
blackoutt is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 05:47 PM #47
starkeef starkeef is offline
starkeef is on a distinguished road
Roof Rack Question
Hi, the roof rack on my '97 4Runner was removed a few years ago and powder coated. I am finally getting around to putting it back on. I have all the hardware but the real problem is the screw inserts that are in the roof. They're all rusted. I found new inserts but have no idea how to put the new ones in as the old ones are anchored in there pretty well. Do I need to take it to a body shop or a Toyota dealer... or what? They are obviouly not meanyt to be removed as they hold the weight of whatever the rack is carrying but I need to replace the severly rusted ones.Thanks for any help.
starkeef is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 06:29 PM #48
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
Hi, your 4Runner is a 3rd Gen so you'd probably have better luck posting your question in the 3rd Gen sub-forum.
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 08:07 PM #49
ShaftedTwice's Avatar
ShaftedTwice ShaftedTwice is offline
ShaftedTwice is on a distinguished road
Hey fellas, I seem to have stupidly lost the hardware that goes with the factory rails. All of it. I have the actual rails and crossbars, minus one of the feet that go with one of the rails (somehow a box got misplaced when moving). Does anyone know the list of hardware for a 2006 Sport Edition that I'll need to put them back on?
I would just get another rack at this point, considering I'll have to buy that foot somewhere, but as far as I can tell, unless I'm willing to drop a grand, I'd have to attach a roof rack to my factory rails.
ShaftedTwice is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 08:10 PM #50
ThShowzOver's Avatar
ThShowzOver ThShowzOver is offline
ThShowzOver is on a distinguished road
I would personally go with the rola roof rack!
2021 Toyota 4Runner TRD OFFROAD PREM 4WD 4.0L V6
Performance: K&N Air Filter
Off Road: BFG KO2 275/70/17 | Bilstein 5100's All around w/ front .85”
Other: LED 5500k Highs and Foglights | LED Reverse Lights | N-Fab Nerf Running Boards | Husky Tech Digital Floormats | 20% Window Tint
ThShowzOver is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 08:13 PM #51
Assuming you're replying to me, wouldn't I have to have the factory rails on to attach it?
Old 01-22-2018, 08:17 PM #52
Your correct.
Factory Roof rack - Useless?-ato6009_3mab-jpg
Old 01-22-2018, 08:22 PM #53
Are there decently priced options that you know of that would replace the factory rails, or am I better off trying to find some bits and pieces for mine? I do really like the Rola rack, I've been eyeing it for a while!
Old 03-20-2018, 03:52 PM #54
Reh0055 Reh0055 is offline
Real Name: Ronnie Hansen
Reh0055 is on a distinguished road
Your correct.
Sorry I’m bringing this back but wanting to get a rola rack given I won’t be using it much so the cost makes more since than a Gobi or what not. Question though...... which one did you use and how did you mount it low like that?
Reh0055 is offline   Reply With QuoteReply With Quote
Old 03-20-2018, 05:08 PM #55
Monkey Wrench Monkey Wrench is offline
Monkey Wrench is on a distinguished road
One option for the factory roof rack is to make crossbar mounting brackets and use Thule or Yakima cross bars.
I made these out of high-strength stainless steel angle iron, grade 8 bolts and 3/16" steel flatbar. This allows the crossbars to be mounted much lower than the Yakima or Thule mounts, and it only cost about $70 for the mounts vs $200.
Factory Roof rack - Useless?-img_2787-jpg  Factory Roof rack - Useless?-img_2786-jpg
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
Monkey Wrench is offline   Reply With QuoteReply With Quote
Old 06-03-2018, 09:57 AM #56
Lost-Again's Avatar
Lost-Again Lost-Again is offline
Real Name: Old man
Lost-Again will become famous soon enough
Lost-Again's Avatar
Real Name: Old man
Very nice! I might try to copy that.
2018 T4R TRD Pro Stock - RSG Sliders - Lock'er Down Console Safe - Yaesu 7900 - Cobra 75 - Garmin 55 Dash Cam - Gaia GPS - Garmin InReach Mini - Earthmate - Baja Designs Squad Sport Ditch Lights w/ Cali Raised Low Profile Ditch Light Brackets -Diode Dynamics SS3 Fog Light Kit - LFD Crossbars - BFG K2s - Warn VR EVO 10s - Warn Semi-Hidden Bumper
Lost-Again is offline   Reply With QuoteReply With Quote
Old 06-03-2018, 05:10 PM #57
Lost-Again's Avatar
Real Name: Old man
Lost-Again's Avatar
Real Name: Old man
So how did you capture the bolt head inside the track to tighten it down? Slip a wrench into the track?
Old 06-03-2018, 10:20 PM #58
The carriage bolts have a square section at the base of the bolt that fits perfectly in the track, so it doesn’t spin as you tighten everything down. I did need to add a thin washer behind the track so the square base didn’t extend past the track.
Old 06-29-2018, 10:52 AM #59
ZBarren1 ZBarren1 is offline
ZBarren1 is on a distinguished road
Works fine.
https://imgur.com/a/qw5Qq6M
ZBarren1 is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 11:06 AM #60
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
Not sure if LFD has been mentioned in here yet. I just got mine. Awesome stuff and out of this world customer service. I think I have seen Jacob, one of the owners, on this forum before.
Is it more expensive than your $10 angle brackets and a few feet of strut...yes. but it's a quality part and worth the money to me.
LFD Off Road - Ruggedized Crossbar 4th Gen
Brian3676 is offline   Reply With QuoteReply With Quote
factory , rack , roof , stock
factory roof rack RichardY 3rd gen T4Rs 10 09-16-2015 05:19 PM
WTB: factory roof rack bNugs For Sale: T4R Items 4 09-17-2011 08:21 PM
Bike rack rails for factory roof rack? Jimi900 3rd gen T4Rs 7 08-02-2011 05:15 PM
I want a factory roof rack bigtuna 3rd gen T4Rs 3 06-25-2008 05:09 AM
