Old 11-08-2020, 06:13 PM #1
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Rear door cladding rivets?
I'm in the process of replacing my door - a deer charged me and left this nice little love mark.
So I picked up a junkyard door with 03-05 cladding and need to swap it out.
The parts page lists 2 rivets that look similar and I'm confused whether (7) 90269-04047 or (10) 90269-04054 is the correct part number for the 3 rivets that hold it on. Anyone have any idea?
Exterior Trim - Rear Door for 2006 Toyota 4Runner | Toyota Parts
Another option my buddy suggested would be pop rivets from the hardware store. Is this a possibility?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 07:43 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
You'll probably need a combination of the blue and orange fasteners. I would just buy a pack from Amazon. This is what the front fender flares use I would imagine its the same for the rear.
Amazon.com: Febrytold 100 Pcs Fender Flare Clip Kit for Toyota 4Runner Tacoma Highlander RAV4 FJ Cruiser, Replace OEM # 75495-35010 75397-35010: Automotive
Edit: nevermind, I didn't know they used actual rivets in combination with the clips. Here is an actual picture of the Toyota part if that helps you.
9026904054 Toyota RIVET, Price: 0.46$, Weight: 0.002kg - PartSouq Auto Parts Around the World
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 07:52 PM #3
Derekv Derekv is offline
Derekv is on a distinguished road
I used aluminum pop rivets. Worked great.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 11:29 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Absolutely get the blue and orange fasteners linked here. You will need them. They are generally not reusable, even if you pop them on and then need to remove the panel again for some reason.
As for the rivets, just get a box of 3/16" x 1/2" aluminum pop-rivets. That's what I have used on both the rear cladding panels on my 4runner.
Also be aware that the 2 plastic tabs on the cladding are probably broken and you will need to fabricate up new ones. I have also done this.
Just use some 1/16" galvanized sheet steel from Home Depot and cut a 1"x3" strip and bend into a Z shape. Drill the hole for the rivet and them use some good, metal to plastic epoxy. I used JBWeld stuff from the parts store. Epoxy them into the correct position to line up with the door holes for the rivets.
I also reinforced some of the tabs for the plastic fasteners because they are weak and either break or you can't get them to pop in because the tab is flexing away. Again, I use JBWeld plastic weld putty to reinforce the plastic tabs.
Here's how mine looked after doing the epoxy and tab fabrication.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 03:40 PM #5
I have the blue and orange clips.
Yeah there were two diff rivets so I was confused, I might just use generic rivets.
Derek V
I ended up buying a Harbor Freight rivet tool/rivet set. I think it'll be easier/cheaper this way. Thanks!
cladding , door , number , part , rivets
How to replace rear door cladding piece Derek 4th Gen T4Rs 3 11-02-2019 07:59 PM
[Found] WTB: 4th gen fender & rear door flares/cladding (2006-2009) LakeRunr Want to Buy/Trade 3 09-15-2019 11:17 PM
Ltd door trim/cladding Crammit442 3rd gen T4Rs 2 06-13-2018 12:50 AM
door cladding/trim KoNEJO 4th Gen T4Rs 3 05-25-2013 05:38 PM
Driver Side Rear Door Trim (cladding) the_josh Want to Buy/Trade 1 01-20-2012 11:41 PM
