04-01-2013, 08:52 PM
Intake, exhaust any help for 4.0?
Ok I have searched, every thread seems to turn into flame war and personal attacks. I am not looking to drag race, just looking for an additional 20HP or so, a little more pep for towing, passing, and a little better MPG. If this cannot be achieved I am fine with that and better money spent elsewhere. I was just making sure $650 for intake and Cat Back would not be a waste.
Thanks
Mud: 2007 SR5 4WD V6. FJ Springs/Struts with Daystar 2.5" and 1.0" lift. Cooper Discoverer ATP 265/75-16
Viper alarm, Kenwood CD player with Polk DB's all around Eclipse 500.1 sub amp, Sundown SD10 sealed
Track: 2008 Pontiac G8GT 6.0 V8, Headers, Intake, Ported TB, Solo Performance exhaust, Custom Pat G Tune. 12.3 @ 112 1/4 mile.
04-01-2013, 09:37 PM
The Tacoma guys seem to like shorty headers for low rpm gains.
WishIWentLongTravel 2006 V6 - Icon extended travel coilovers w/ resi, Total Chaos UCA, Wheelers Super bump's, Metal Tech "LT" w/ Icon VS 2, Metal Tech lower links, JBA Long Tube Headers, Dirtydeeds exhaust, Gunmetal Konig Countersteer X, B.A.M.F LCA Skids
04-01-2013, 11:03 PM
Real Name: Jesse Allen
I am a firm beliver in URDs T.C.A.I and MAF cal combo. The cost in the end is right around that 650 mark u have. After installing both these products I have had a significant power AND mpg gains. This is very dependent on how I drive. Keeping my rpms low and using cruise control at 65mph I can muster about 23 mpgs( hand calcd) with a 4 inch lift and 32s. When I am romping,towing, wheeling or just passing someone I can feel a huge difference. URD claims 15 HP on stock rigs so in combination with their intake I imagine I picked up around 20. I am saving my cash for DT long tube headers, URD y pipe and a borla kit for the rest. If your going to spend money on your exhaust buy the best don't skimp your self. As far as the intake URDs is the best one out there hands down. Go check it out and if you want any pics of my setup lemme know. I'm loving it thru and thru.
____________06 SR5 4WD V6______________
High Country Fab Winch Bumper|Engo 10k| URD T.C.A.I + URD MAF Cal|885s on 5100s|Daystar 1.5|4Crawler 1.25 BL|265/70/17 Treadwright Wardens|Spidertrax|VSC Off Switch|Amsoil fluids
04-01-2013, 11:27 PM
Real Name: Alex
Real Name: Alex
Thanks
For CAI, I had made the mistake in ordering from K&N. Save yourself a few bucks, and get the drop in K&N filter, as the "Cold" Air intake will be gaining more, but warmer air. Now, if you went TRD or aFe, you'd have the fully enclosed filter.
For towing, however, you'll be wanting more torque than power. A nice exhaust will do that. Honestly, though, you could do that with some nice headers with high-flow, if any, cats.
Performance-wise, long-tubes typically do better. (This, however will take away some ground clearance, and increase under hood temperature.)
A better muffler can allow for better-flowing exhaust gases, as well as a mean sound when you get on the gas. I personally would say go with magnaflow, although I'd have to leave that choice to you. And, to increase this a bit (you probably won't even notice it, though), a lot of people on the forum do the resonator delete, which will help with the horrendous smell with the back window down, if the exhaust is either a. dumped, or b. routed out the side.
(And if you want, there are a few people who have actually gotten the TRD supercharger working with the 4.0 v6. Just a heads up ;) )
04-01-2013, 11:35 PM
No cai
Not to start pissing match , but if you search this out it this has been up & down the road many times .AFEdry filter, Headers yes , find a muffler you like drone gets old , I did do urd y-pipe so far so good (kiss o death) popped a p0420 so far just replaced gas cap , fingers crossed have o2 on standby, not an expert by any means but all old timers say we have CAI already makes more noise than anything their opinion not mine . Check out skylinetracer his mods are where its at !! I did what they said invest in suspension !!
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
04-01-2013, 11:47 PM
Real Name: Alex
Real Name: Alex
I agree with them on this, although the enclosed CAI's have take air from the same place as the OEM intake, but have a higher flow filter. It's not too notable of a change, so I'd say it's not really worth it, but that's my opinion. It does, however, have some affect, and a few people, such as Gaterose, have one of them, and as far as I know, he likes it.
04-02-2013, 12:01 AM
Great info. With my G8 I have to custom tune with headers, no cats or aftermarket cats. Is the 4 runner the same?
04-02-2013, 12:10 AM
No 4r has total 4, 2 fore & after cats or 2 on the manifold & so on .So far only seen 2 headers jba or Doug Thorley or magnafloe & pacestter make some sorta oem replacements , both the true headers come in shorty or long tube , depending on your st smog laws won't pass visual ! Nv only has ecu plug & send . That's all I got ! If you want horsepower I STRONGLY suggest skylinetracer build he does it !!
04-02-2013, 12:33 AM
Real Name: Jay
Real Name: Jay
I currently have on my 4r... AFE intake and full exhaust. Gas mileage I can't tell the difference but as far as get up and go it's there. Not as much as one would hope though. Going to buy the URD MAF CAL to see what happens once that's on. Honestly I think all the parts I put on will only work better if i tune it.
My Build
04-02-2013, 12:58 AM
Keep in mind this engine was designed primarily for low end torque. Any gains you might find in the HP department are going to be found way up in the power band i.e. not usable in almost any day-to-day use. The stock intake is already a CAI, maybe throw a high-flow filter in for peace of mind but just know that the difference in the volume of air you can flow through an aftermarket intake over stock is very small and only noticeable at the very top of usable revs. Aside from a SC kit this is not really a 'tuner' engine and any gains you can eke out are going to be small, expensive and not very usable. Honestly, your money is much better spent elsewhere.
2009 4runner Trail V6, Icon 2.5 Ext travel front CO, Icon 2.0 remote resi rear shock w/ Icon springs, TC UCA, Custom Sway-bar End Links, 1.25" 4crawler BL w/ radiator drop, Cooper Disco AT3 285/70r17, ProComp 7098's, KurtFab diff bracket, Hayden tranny cooler, side-routed exhaust mod, Shrockworks Sliders, Full RCI Metal Works skid plates, Dual-Batteries, Kenwood TS-480HX HF radio, Kenwood TM-D710 VHF/UHF/APRS radio, Husky floor mats.
KJ6QDJ
04-02-2013, 01:05 AM
^^^^^^ I said it dummer my engrish getting better no ?
04-02-2013, 01:06 AM
You are absolutely correct. I could notice a difference after my intake but not until the MAF cal did I feel what it really had. If you wanna get really tuned out. Look into afr wideband tuners.
