04-04-2013, 01:02 PM
Custom roof rack
So I searched and I couldn't find any threads about fabricating a whole roof rack. I'm using tapatalk, so maybe things are getting left out?
Anyway, title says it, I'm looking at building my own roof rack. I started welding about 6 months ago, and I've turned the corner on being able to produce decent results. Granted, my angle grinder comes in handy, but I'm confident I can build this to be safe on the road.
I'm using a lincoln power mig 140, and I have a great big gas bottle of C25.
Basically, I wanted to run my Yakima fairing and two steelhead bike mounts, but couldn't see it as possible without a whole custom setup. I didn't want to use the rail grabber attachment because I thought it looked funny and stuck up too high, plus I'd need another fairing.
What I'm thinking of is having the two biggest pieces bent into a rectangular shape of the right dimensions, then welding them together and building a a basket out of small steel stock, and adding two Yakima size bars at the right spot.
I can get the steel pretty cheap, probably all for under $80.
Does anyone have thoughts on this or pictures of custom setups they have done?
04-04-2013, 03:04 PM
Moderator
Moderator
I think you're on the right track. I think designing and building your own is the way to go to ensure you get exactly what you want while saving money.
I designed my own roof rack:
and had a fabricator build it:
Same fabricator built my friend Mike's (RIP) as well and sounds similar to what you want to build:
One thing to note is that the roof curves from left to right and front to back. to compensate for this, you either have to make the legs that attach to your roof +2" tall or put a slight curve in your lower bars.
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
04-04-2013, 03:31 PM
That's probably the best looking roof rack I've seen on a 4th gen.
2003 SR5 4WD: V8 TRD Supercharged, TRD Headers, ARB Bull Bar, CBI Rear, OME 886 coils w/ 1/4'' Spacer, AllPro 3.5's w/1.5 DS, 5100's, 285 Cooper STT, Slee SS Brake Lines, Custom Sway Bar Links, 4xInnovations Sliders, AllPro Lower Links, DDM HID's, 30" Light Bar/Duallys, Safari Snorkel, Custom Y-Pipe, Magnaflow, BudBuilt, KurtFab Diff-Brace, Wet Okole's, JL Sub/Amp, KCCO
04-04-2013, 04:01 PM
Moderator
Moderator
Thanks...much appreciated
04-04-2013, 04:14 PM
Right on. That's what I'm looking for. The bracket looks like what I was picturing too.
What did you use to make the blueprint?
04-04-2013, 06:09 PM
Moderator
Moderator
I used Google Sketchup. it can also export .dwg files.
04-05-2013, 02:19 AM
would you consider sharing that file and/or blueprint?
04 SR5 2WD
Odometer reading as of 3/25/2013: 45,515
04-05-2013, 02:36 AM
Right on. I was hoping you'd say that. I had heard about it but hadn't downloaded it yet, but I am getting now.
What did your rack cost you total?
And did you run into any problems in the design or the build?
04-05-2013, 02:39 AM
And your runner looks awesome by the way.
04-05-2013, 03:07 AM
Location: DFW, TX. / Santa Rita, Copán Ruinas, Honduras, C.A.
darkie that is a good looking rack sir!
-Daniel Kent
Adventure Copán, LLC.
www.AdventureCopan.com
Changing Lives Through Coffee!™
'87 4Runner "pepe" :steer:
04-05-2013, 05:07 AM
Real Name: Jon
Real Name: Jon
... I designed my own roof rack ...
Very nice design work on the rack Kevin. Are the middle feet just resting in the gutter for support or did you secure them somehow ?
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
04-05-2013, 10:34 AM
Real Name: Brian
Real Name: Brian
That looks great,what size and type tubing did you use?
04-05-2013, 11:16 AM
Got sketch up and messed with it a bit. I'm definitely going to have to read some tutorial stuff. Did you make the lines and then tell it to substitute the lines with material of a certain thickness?
04-05-2013, 01:18 PM
Moderator
Moderator
I'll have to go through my backup drives to see if I still have it. If I find it i'll shoot it over to you.
I really can't remember how much it ended up coming to. It was quoted at a specific price then I agreed to a partnership with Perkins Performance to sell these rack through his company that lowered the price significantly.
I didn't run into any issues during the design process other than over engineering the rack. One design had hydraulic pistons that could fold the lights down and rotate via a cabin mounted control box (i'm a nerd). During the build process, the only issue was the bottom bar curvature had to be increased slightly to ensure proper clearance when you add weight to the roof due to tube flex.
-Daniel Kent
Thank you both!!
Thanks!! Yes it's resting on the rubber gutter. It's strictly used for weight support as the stock mount locations are very secure.
I used 1" OD 4130 Chromoly tubing all the way around with a total weight of 88lbs.
Yeah, drawing a line first and use that as a guide for the tubing. It ensures that the measurements stay consistent.
04-05-2013, 02:29 PM
So draw the line, then create a shape that reflects the material size and drop it to the line? This may be one of those questions that's hard to describe. If its covered in the tutorial just tell me to read. I'll be spending some time on it tonight.
I really like the whole design of yours, but I was shooting for simplicity like a con-ferr rack. Easy for me to build, and no computer planning needed. Although I should get familiar with the program.
