Old 04-06-2013, 11:30 AM #1
MtnT4R's Avatar
MtnT4R MtnT4R is offline
MtnT4R is on a distinguished road
MtnT4R's Avatar
Strongest solvent to SAFELY clean paint?
I park every day in a parking structure on the second level, and the ceiling directly above the driver side is where two floor sections of the level above me are joined together. Apparently, the magnesium chloride that the DOT coats the roads with in the winter has all day to drip off the cars above me, funnel through the cracks, and deposits itself all over the driver side of my T4.
I've tried cleaning it off with car wash soap, Goof Off, Goo Gone, and paint thinner, all to no avail. The only method that seems to work-on the windows only- is to scrape it off with a knife. This stuff is ridiculous. Its basically magnesium chloride that has been concentrated into a thin paste. I was hoping you all would know of a stronger solvent I could use to remove this crap that is clear coat safe. Any suggestions?
'02 SR5
"Gas pedal's on the right.'
~Logan
MtnT4R is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 12:33 PM #2
Derek G's Avatar
Derek G Derek G is offline
Derek G is on a distinguished road
Derek G's Avatar
STAY AWAY FROM SOLVENTS! Start with a good cleaner polish and work it around a small area. If this doesn't work move up to a more aggressive polish such a light rubbing compound. Find the compound with the minimum amount abrasive to get the job done. Once you have all of he deposits removed, go over it again with a polish then a coat wax. Use you hands and now a power buffer to avoid burning through the finish.
Derek G is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 12:36 PM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Clay bar. If that doesn't work I would try compound.
I hate salt. I want to move to where it never snows.
Old 04-06-2013, 01:18 PM #4
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
You better bring a caulking gun with you to the parking lot and seal those cracks to prevent further damage.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 02:07 PM #5
MtnT4R's Avatar
MtnT4R's Avatar
Thanks for the suggestions! I always knew I was walking a fine line with those particular products, but never noticed any damage from using them. Rubbing compound it is.
'02 SR5
~Logan
Old 04-06-2013, 02:24 PM #6
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Safest solvent for paint is water, otherwise all other solvents will degrade/dissolve the paint to some degree. hence why we need to rewax a car after washing, ect ect.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 09:02 PM #7
Burt Burt is offline
Burt is on a distinguished road
Havn't had issue with MagCloride that required much more than a good wash, but I've used Simple Green to remove bug splat from front grill, lights,hood and windshield with no problems. I then wax the area afterwards.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 09:14 PM #8
Casper421's Avatar
Casper421 Casper421 is offline
Real Name: Chris
Casper421 is on a distinguished road
Casper421's Avatar
Real Name: Chris
Or a place with snow that doesn't use salt, like Cali.
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
Casper421 is offline   Reply With QuoteReply With Quote
Old 04-06-2013, 09:15 PM #9
Derek G's Avatar
Derek G's Avatar
While we're on the topic. Never use dish soap to wash your truck either, it strips the waxes and oils.
Old 04-07-2013, 11:23 AM #10
T4R2014's Avatar
T4R2014's Avatar
I just hate snow in general.
Old 04-09-2013, 08:04 PM #11
Ryan H Ryan H is offline
Ryan H is on a distinguished road
Try heating it up with a heat gun (or hair dryer) and use a plastic razor blade and maybe a little acetone and rag. The plastic blade will not scratch the paint if used correctly. I work at a car dealership and this has always helped me get any kind of hardened gunk off. Be gentle with the acetone though. Pretty much just use it to loosen the gunk up.
Ryan H is offline   Reply With QuoteReply With Quote
Old 04-09-2013, 08:08 PM #12
And if your paint is still in solid shape, you could always try pressure washing. I pressure wash our cars at home all the time and it leaves good results. Just don't pressure wash a new paint job or touch ups or where your paint is starting to come off. Otherwise it shouldn't penetrate the clear coat.
STRONGEST tube bumpers? T?@\7 Classic T4Rs 26 05-30-2012 05:09 PM
Strongest paint for roof rack Net4n6 General Discussions 8 05-19-2011 02:43 PM
Parts Washer Solvent Kurtis General Discussions 2 01-03-2011 01:56 AM
How can I safely treat this rust? hyperthread Maintenance/Detailing 1 09-07-2010 05:24 AM
For Sale = 2004 SR5 4Runner 2WD, clean, Clean, CLEAN... w/ maintenance records... 4runDiZZLe Classifieds - buy & sell (no commercial ads please) 1 01-19-2010 03:53 AM
