04-08-2013, 02:48 PM
#16
Wow that looks great. Such a clean install.
04-08-2013, 02:51 PM
#17
Real Name: Ryan
Real Name: Ryan
Question for those with the Hanma double row. Maybe momo can answer this.
Can the two mounting brackets on the double row be removed and flipped over so that the mounting tabs point inwards instead of out? that would shave a couple inches off the overall length.
Would it be possible to create your own brackets maybe? I cant tell how the bracket is attached to the light bar.
2007 Toyota 4Runner Limited V8 4x4
|Goodyear Duratrac 275/65R18|Daystar 2.5F RAS Adjusted Rear|1.25" Spidertrax|BM Chop|WeatherTech Floor Liners|28% Tint|LED Interior/Exterior Swap|4300k HID's|"Black Series" Projector Lenses|Jet Yellow Fogs|Pioneer AVH-P8400BH|Airaid Synthamax|HCF Delete|
04-08-2013, 04:19 PM
#18
Registered User
Real Name: Morris
Registered User
Real Name: Morris
yes, the mount brackets can be flipped around with the feet turned in. Even then the 40" DR would be too long. If somebody had access to a plasma cutter they could easily cut some brackets that could mount in the side rails then have a little zig zag bend to them to hold the light itself. They could also be made to bring the light a little more forward
04-08-2013, 05:43 PM
#19
If you do flip the brackets to save space, you lose the ability to lock in teeth between the light and the bracket. Not sure how good the hold will be then.
04-08-2013, 05:58 PM
#20
I like that. What does it look like from inside the vehicle at night? any glare on the hood?
But there is something that doesn’t right look right in the last pic of the “sun”; it looks like it is aim up to high and could be angled down a couple more degrees. The low beams top out at 3’; highs are around 6’; the middle of the “sun” look like it is 12’ in the air.
'05 4Runner V6 Limited in Natural White with Stone Gray leather. Big Features: X-REAS, JBL 6 CD w/ 10 speaker system and Powered Moonroof.
'06 Chevy Express extended cargo van with a Duramax diesel & rebuilt HD/Towing trans.
http://meerkatsound.com/
04-08-2013, 06:31 PM
#21
No glare on the hood, because the the angle of the roof does not allow the beam to even shine on the hood. Make sure you keep your sunroof shade closed though ;)
You are totally right, I just have not had a chance to adjust it to the proper height yet. The fact that it is twice as high as the headlights will cause the two beams to 'triangulate' at some distance in front of the car, so I need to find some time to play around with it until I find an angle that I like.
Just another engineer with an attitude | 2006 Limited Build Thread | More Photos! | KCCO
2006 V8 Limited | RAS | 40" LED light bar | Spidertrax | WeatherTech | 2" leveling kit | 6K LED reverse lights
04-10-2013, 05:09 PM
#22
Any distanced output pics? in a field or something of the like? Absolutely great thinking, very tempted...
2017 TRD Offroad Premium "2CRAYC"
OG: Galactic Gray 2K6 Limited "CRAYC"
Build: http://www.toyota-4runner.org/4th-ge...ld-thread.html
04-10-2013, 05:10 PM
#23
Real Name: Matt
Real Name: Matt
Originally Posted by BannerBuilt
I agree. If you check out the specs on the Hanma/Totron bars, you'll see that the single row bars use 24 5W CREE bulbs (120W total), while the double row bars use 48 3W CREE bulbs (144W total).
In reality, you are only giving up 24 total watts, or 1W per bulb, by going with the single row bar.
Actually the 40" DRs that I've seen are 240W and have about 80 3W CREEs. The single row bar for every size is half the wattage of its double row counterpart. My old 30" bar was 180W and my current SR (like yours) is 90W.
04-10-2013, 05:16 PM
#24
Whoops, my mistake. I picked that up somewhere, maybe I got crossed up with different brands. I will edit the previous comment.
I'll try this weekend, but no guarantees...I'm usually out at the bars before dark, which makes it tough to get any pictures of the 4R at night
04-10-2013, 08:20 PM
#25
Awesome, once you get it re angled, can you update the pictures please. I'm wondering how far you can tilt it down before the roof line acts as a cut off.
04-13-2013, 08:12 PM
#26
Love the write up, thank you tons!! I have been looking at a way to mount a light like this under my basket to make is "stealth" or what have you. I will have to look into doing this.
04 SE V8. Magnaflow overlander exhaust. Yakima Loadwarrior. OME 884/895 265/70/17 Firestone Destination A/T. Sylvania Super Star Ultras low beams and fog lights. CBI Offroad Fab 4th gen Ditch light bracket, Olympus Offroad Pod lights. Spidertrax 1.25" Wheel Spacers, low budget sleeping deck/storage box, CB (still sitting in the box =X)
08-08-2013, 08:50 AM
#27
Where you able to adjust the bar any?
08-08-2013, 01:14 PM
#28
Real Name: Chris
Real Name: Chris
Wow, this is exactly the install I've wanted to do, glad someone bumped it since I hadn't seen it before
08-08-2013, 02:02 PM
#29
why did someone have to revive this thread?! now i wantttttttttt....
Golden State RUNNER
2008 Galactic Gray SR5 4x4 V6
Build Thread
Photo Album
08-08-2013, 03:45 PM
#30
Pretty slick. Is that the spot beam pattern? Does it light up the road at all since it's placed so far back on the roof?
