Originally posted by jeober
Koz is right about the fuse. A 6awg wire need a big fuse. If such a big wire finds a short to ground without a fuse, you might in for some fireworks. Hopefully, the inverter would provide this detail.
Does anyone know if OEMs mount inverters and run the AC voltage any distances in the vehicle? What kind of wiring is used (protection)?
OK, well what kind of thing are you running with that AC coming off the inverter? Stuff permanently install in the car or just quick use stuff?
I would recommend not running anything permanently installed since should anything goes wrong wiring wise you can kiss your car goodbye after the fire. As far as running the wire off the battery to the inverter put either a circuit breaker, or a fuse properly rated for whatever kind of current you're pulling within 18 inches of the battery connection. Of course as everyone else has said so far be sure to go through a rubber grommet in the firewall and make darn sure the wire insulation is not cut or damaged in anyway on its entire length.
