Thread Tools Rating: Thread Rating: 4 votes, 2.75 average. Display Modes
Old 10-09-2014, 08:17 AM #16
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Originally Posted by tucktuck8 View Post
great write up. The fluid level is checked with the engine running correct?
Yes, the engine must be running.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 10-09-2014, 10:26 AM #17
fullboogie fullboogie is offline
Real Name: David
fullboogie is on a distinguished road
Real Name: David
Originally Posted by toyo View Post
I had some time to kill last week and did a complete pan drop, cleaned the metal screen/filter, dropped and cleaned the valve body and reinstalled everything back. Filled with fluid until it became a very small trickle. Entered the temp window and checked the fluid. I needed to add about 20 Oz. This was due to removing the valve body as it needed to run to pump the fluid into the VB. All is perfect.
I always like to drop my pans at least once every 60K for further inspection. Knock on wood I have put over a million miles on Toyota transmissions and have only had 1 failure. That one was on my 2001 RX300 which is known for weak tranny. It went out at 340K.
Doing a pan drop and refill, how many quarts are you using? Since this stuff is only available at the dealer, I'd like to have enough on hand before starting this project.
fullboogie is offline   Reply With QuoteReply With Quote
Old 10-10-2014, 06:19 AM #18
toyo's Avatar
Real Name: Steven
toyo's Avatar
Real Name: Steven
I would buy at least 5 qts.
Old 10-10-2014, 01:09 PM #19
ARunner's Avatar
ARunner ARunner is offline
Real Name: Kyle
ARunner is on a distinguished road
ARunner's Avatar
Real Name: Kyle
Great information. I'm unread with regard to the transmission fluid change and all that is associated with getting it right or wrong, so I apologize in advance if this question is obvious.
Is there a clear definition of what temperature is the right temp for fluid to begin to exit the overflow hole? Reason I ask is "operating temperature" of my transmission as revealed via Scangauge seems to vary widely. I've seen it as high as 180 and on cooler days be in the 120-130 degree range. As we go into the cooler season it might even be lower. I would imagine this line on the graph would stay linear and therefore the fluid would continue to rise as temperature of the transmission rises, thus my confusion about what temperature to validate the overflow hole at and/or what is considered "operating temperature".
03 Limited V8 4WD
ARunner is offline   Reply With QuoteReply With Quote
Old 10-10-2014, 07:51 PM #20
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Not exactly sure what you're asking but the temperature range targeted for checking the transmission fluid level is 97-115F.
If you pulled the overflow plug when the fluid was hotter than that, yes, too much would flow out.
For the most part, if you simply drive the truck until the engine coolant comes completely up to full operating temp and then let the truck idle and pull the overflow plug, everything takes care of itself as the transmission fluid should be very close to the lower end of the 97-115F range at that point.
Not a bad idea to let the truck idle for an 5 extra minutes or so, for good measure, and that gives you time to move the shifter through the gear range.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 10-10-2014, 08:04 PM #21
ARunner's Avatar
Real Name: Kyle
ARunner's Avatar
Real Name: Kyle
That's exactly what I'm wondering. Is it standard operating procedure to pull the overflow plug or are people only doing this because the fluid level on the dipstick is too high and this is the best option to remove excess?
03 Limited V8 4WD
Old 10-10-2014, 08:11 PM #22
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
There is no Dipstick on the "Sealed" WS ATF transmissions on 4Runners. The Overflow Plug is more accurately referred to as the "Inspection Plug" and has a calibrated tube that you use to determine the fluid level at a given temperature.
Checking it when it is too cold or too hot will yield an incorrect fluid level reading and thus skew your results. It should always be checked at the appropriate temperature range and after running the transmission through all its gears.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 10-10-2014, 08:31 PM #23
ARunner's Avatar
Real Name: Kyle
ARunner's Avatar
Real Name: Kyle
Umm... I have a red handled dipstick for the transmission right next to the yellow handled oil dipstick... 03 V8. Not sure what transmission we're talking about here. Since the OP has a V8, I assumed they were all the same. Was the dipstick removed on later models?
03 Limited V8 4WD
Old 10-10-2014, 08:39 PM #24
superman3043's Avatar
superman3043 superman3043 is offline
Real Name: PD
superman3043 will become famous soon enough superman3043 will become famous soon enough
Real Name: PD
Correct. 03's have a dipstick. Later the transmissions were "sealed"
-PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
superman3043 is offline   Reply With QuoteReply With Quote
Old 10-10-2014, 08:43 PM #25
As was pointed out, '03 2UZ-FE Equipped V8's had a traditional dipstick equipped transmission that uses Type IV ATF, as did '03 & some '04 1GR-FE equipped V6 4Runners until they became standard with WS ATF "Sealed" Transmissions.
Old 10-10-2014, 09:01 PM #26
ARunner's Avatar
Real Name: Kyle
ARunner's Avatar
Real Name: Kyle
Ahh. All this makes quite a bit more sense now. Thanks.
03 Limited V8 4WD
Old 07-09-2019, 01:29 AM #27
CredeCo76 CredeCo76 is offline
CredeCo76 is on a distinguished road
Have you ever done the temp check mode at the same time to compare both methods?
CredeCo76 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 05:34 PM #28
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Yes, that's exactly what this thread is about.
See first sentence of first post.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 07-25-2019, 08:01 PM #29
lorennerol lorennerol is offline
lorennerol is on a distinguished road
Apologies for the thread archaeology here...
Have owned my 05 Limited from new and it's just 500 miles short of 200k. Yesterday driving home it refused to shift past 3rd gear. The tranny has been a bit wonky for a while, not engaging immediately at starts, not releasing at stops.
It's entirely possible that I stupidly emptied some of the fluid during a recent oil change in a dark, cold garage, so I'm going to see about topping it off tonight in hopes of reviving 4th and 5th gears.
It seems like the general procedure is:
1. Open the overflow plug and add fluid through the fill plug until it dribbles out the overfill.
2. Close overflow and fill plugs.
3. Drive slowly around neighborhood to bring it up to operating coolant temp.
4. While still with the engine running, move shifter through all the gears several times.
5. Let idle five more minutes.
6. Open overflow and let excess run out until stream breaks.
I'm thinking #5 is done with the engine OFF, but that's not specified here.
Appreciate the knowledge here, and welcome input.
Indyota Jones, Thread Archeologist
lorennerol is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 10:54 PM #30
To follow up for any future finders of the thread:
I had to repeat the process twice, as the first time nothing came out of the overflow after I removed the plug.
Also, the fill plug is high on the passenger side of the transmission at the rear, near the transfer case. You'll need a 24mm standard (non-deep) socket for it.
I now have all five forward gears, which is helpful on the rare occasion we get to the speed limit on the freeways around Seattle.
Thanks to all who contributed to this post...it saved me $500 at the tranny shop and a two week wait.
check , fluid , temp , transmission , ws fluid
how to check transmission fluid level? Idgy Maintenance/Detailing 14 01-03-2022 05:05 PM
Check transmission oil level? paraordnance 4th Gen T4Rs 12 12-04-2017 12:44 AM
Can't enter temperature check mode in transmission gsrthomas 4th Gen T4Rs 11 04-09-2013 09:42 PM
Do you check the trans fluid level with the engine warm and running??? Jeff T 4th Gen T4Rs 6 04-22-2011 06:45 PM
Fluid fill check 4th gen A/T - oil temp detection mode jeober Maintenance/Detailing 7 01-24-2007 09:43 AM
