04-19-2013, 11:00 PM
Real Name: Jeff
Real Name: Jeff
Plasti-dip
So, I'm considering plasti-dipping my chrome parts on my 2007 SR5 4x4.
I want to black plasti-dip all the chrome parts. The grill, the emblems, the rear chrome placard.
I need tips, suggestions, and most off do I remove the emblems? Or do I just mask around them.
If there is thread somewhere. I apologize for the duplicate thread. Just post a link. And, I will move on.
Thanks.
2007 SR5
4.0L
4x4
Titanium Metallic
04-19-2013, 11:30 PM
Real Name: Maharshee Patel
warm up the can with a blow dryer just a little. I tries spraying with a cold can once and i ended up having to re do it because of blobs
2014 4runner Limited Attitude Black Metallic 55W 5000K TheRetrofitSource Morimoto HID
2006 Subraru WRX Limited STI swapped and fully built
2007 4runner SR5 4WD V6 55w 4300K Morimoto Xenons, Morimoto 90mm Halo's, Blacked out trim, Plasti Dipped Wheels, Nitto Terra Grapplers 265/70/17(R.I.P)
2008 Nissan Sentra SER Spec-V (Sold)
04-20-2013, 12:14 AM
Real Name: sean
Real Name: sean
no need to take anything of the car just use painters tape and newspapers to cover around the badges, be sure to shake the can a lot and make sure you give each coat enough time to dry like around a half hour if its warm out. Most of the excess should come off with the tape but for the spaces in between the letters use a toothpick or something similar.
2005 SR5 V8 plasti-dipped emblems/grille/badges, daystar 2.5/1.5 lift, ATX Crawl wheels, 265/65/17 BFG rugged terrains, HCF delete, aFe pro dry filter, Gibson catback exhaust, Pioneer head unit, JL audio 500w amp, JL audio 10"sub
04-20-2013, 03:56 AM
www.dipyourcar.com has more info than you'll ever need... check out the "Videos" tab and go over to Youtube and you'll find all kinds of instructional videos. Pretty awesome site!
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
04-20-2013, 07:42 AM
you tube it. plenty of good instructions on there.
2006 Tacoma DC TRD Radiant Red
OME 885's & Dakar Rear 3"
285x75x16 Goodyear Duratracs
TRD Trail Edition wheels
04-20-2013, 07:13 PM
Just mask a square around the emblems, you dont have to mask them off perfectly. I did remove the front because it just pops out. The unwanted plasti will peel off easily if you put enough coats on the area. Any accidental over spray can be taken off by a terry towel or something by simply rubbing. As stated above, search some on youtube or go to dipyourcar and you will find everything you need. I just did my wheels last week. Love plasti dip. Enjoy!
04' Natural White SR5 V8
05' s2k
04-20-2013, 07:18 PM
Real Name: John Lee
Real Name: John Lee
I just ordered the 4 wheel kit in charcoal grey for my silver 4th gen. Also just ordered a 2.5" lift to go along with it.
04-20-2013, 08:04 PM
I've been considering the blackout look on my charcoal gray runner. My door handles are chrome and wonder if those should be blacked out as well.
04-20-2013, 11:16 PM
Plasti-Dip Removal
How easy is to remove this stuff if you don't like the results or the way it looks?
Thanks!
04-21-2013, 01:08 AM
Real Name: sean
Real Name: sean
Thanks!
it literally just peels off with no residue or damage to the chrome underneath
04-21-2013, 01:43 AM
Real Name: Jeff
Real Name: Jeff
Great info guys thanks.
So, is did you guys do some prep work to the chrome first? Scuff it up a bit? I will check out YouTube links for sure. But, I also trust you fellow TR4 owners experiences first.
And as far as peeling off excess plasti-dip. Does it not adhere to paint?
2007 SR5
4.0L
4x4
Titanium Metallic
04-21-2013, 11:29 AM
Real Name: sean
Real Name: sean
no need to prep anything but setting up the tape and newspapers...it adheres to anything you spray it on but it also comes off anything you spray it on
04-21-2013, 01:57 PM
No... don't scuff up anything. Just clean the chrome with alcohol and use cotton swabs to clean the edges and in between. Having it clean just helps the PlastiDip adhere better. Once you get a corner up, you'll be surprised by how easily it peels off and leaves no residue of any kind!
04-21-2013, 05:32 PM
Real Name: Jeff
Real Name: Jeff
Great! Thanks again.
The TR4 community is great! You guys don't flame. And, are very helpful. I appreciate it.
I wish I could connect with someone in Ohio and do some offroading around here (what little trails we have left).
2007 SR5
4.0L
4x4
Titanium Metallic
05-18-2013, 07:19 AM
could you post pics of ur plastidipped wheels...trying to decide btw charcoal gray and black
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
