Old 04-29-2013, 04:52 PM #1
the rizz the rizz is offline
the rizz is on a distinguished road
Anything I'm forgetting? Preventative maintenance at 200k miles...
About to turn over 200k miles on my 2003, V6, 4x4. I want this thing to last until 400k, so I've been giving it a nice refresh. Here's what I've done so far. Anything else I'm forgetting?
-New front rotors and pads
-New spark plugs (didn't do the wires...does that matter?)
-Drain and replace tranny fluid
-Drain and replace both diffs and transfer case fluid
-Grease all zerks
-Drain and replace power steering fluid
-Drain and replace radiator coolant
-New air filter and cabin air filter
-Clean MAF sensor
-Replace burnt out dash bulb
-Fix clunking sway bar bushing
-Replaced leaking CV boot
-Obviously rotate tires, change oil, etc.
What else? I'm at a loss after all this... Thanks!
the rizz is offline   Reply With QuoteReply With Quote
Old 04-29-2013, 10:07 PM #2
LobstaMobsta's Avatar
LobstaMobsta LobstaMobsta is offline
LobstaMobsta is on a distinguished road
Clean throttle plate....make sure to have someone open it by pressing the pedal, some electronic throttle systems can be damaged from manual operation
LobstaMobsta is offline   Reply With QuoteReply With Quote
Old 04-29-2013, 10:35 PM #3
macoyle's Avatar
macoyle macoyle is offline
macoyle is an unknown quantity at this point
macoyle's Avatar
It may be time for new O2 sensors, check wheel and hub bearings, and possibly fuel pump so you don't end up stranded
04 4runner 3" ultimate Toytec, 1" BL, Helo Maxx 6 17x9, 285 BFG A/T's, Leather Install royal purple in diffs, shrockworks bumper, 20% tint, 4300k HIDS, reverse lights, in dash nav, K&N intake, etc. Build Thread
macoyle is offline   Reply With QuoteReply With Quote
Old 04-29-2013, 11:02 PM #4
Fuel pump and o2 sensors sound like expensive maybes!
Old 04-29-2013, 11:18 PM #5
macoyle's Avatar
macoyle's Avatar
o2 sensors are only like 50-60 ea
Old 04-29-2013, 11:26 PM #6
X4 = 240$ plus labor that is not necessary unless MIL is on with a 02 sensor code
Old 04-30-2013, 02:16 PM #7
Thanks for the ideas, guys. I may take a shot at the steering rack bushings too. Things seem a little loose up there....
Old 04-30-2013, 02:58 PM #8
97hb's Avatar
97hb 97hb is offline
97hb is on a distinguished road
97hb's Avatar
V6 are cop no plug wires
2017 Ram 3500 4X4 - The hauler.
2003 SR5 4X4 4Runner - 412K+ Off-road Toy.
1997 Civic SFWD 674hp 530tq - Because racecar.
97hb is offline   Reply With QuoteReply With Quote
Old 11-05-2013, 12:40 PM #9
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
-Grease all zerks
-Clean MAF sensor
Fuel Filter might be a good idea.
Old 11-05-2013, 04:04 PM #10
boondoggle's Avatar
boondoggle boondoggle is offline
boondoggle is on a distinguished road
boondoggle's Avatar
Brake fluid might be a good idea if it's never been changed. Maybe even go around and put a light coat of grease on the door/hood hinges. Especially the doors you don't use very often.
How long since you replaced the serpentine belt?
One of the gas charged shocks on my hood is worn out. It's not something I'd replace just to replace, but they probably have a limited lifespan.
2004 Sport Edition V8 in "rare" Titanium Metallic
~165k miles, 2nd owner since 99k miles.
boondoggle is offline   Reply With QuoteReply With Quote
Preventative Maintenance Troutsrunner 3rd gen T4Rs 3 04-02-2013 06:48 PM
Time off = Preventative maintenance. Some advice please. AZ4FNER 3rd gen T4Rs 8 11-21-2011 12:49 AM
POLL: Who Does Your Preventative Maintenance? FireEngineer Maintenance/Detailing 17 03-08-2011 09:08 PM
Preventative Maintenance Suggestions for a 98? Scag 3rd gen T4Rs 2 02-11-2009 02:20 PM
Preventative Maintenance MARSHALLMAY 3rd gen T4Rs 0 10-12-2005 04:36 PM
