10-20-2016, 08:14 PM
#31
Real Name: Mark
Real Name: Mark
@ techoguy
Whoever did that painted the ticks, I have done three clusters so far so been in and have seen the insides. I like it as well, may have to try it.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
10-20-2016, 08:27 PM
#32
Real Name: Hoop
Real Name: Hoop
I love the white with blue accents. How is this done? The blue accent part? Paint?
If I were to attempt this, start with center console first before attempting the cluster?
10-20-2016, 09:02 PM
#33
Originally Posted by S p a r k y
@ techoguy
Thanks! Do you know how they painted them? I'm assuming they painted the back with a translucent blue paint? I really like how it looks but if you paint it, it's forever blue.
I wonder if you can put blue tent or light filter behind it if you cut it to size? I might have to try that.
10-20-2016, 09:04 PM
#34
I hope to try this soon too
10-20-2016, 09:28 PM
#35
Originally Posted by techoguy
This is an old thread so I'm hoping someone might be able to help me. Does anyone know the specifics of how to get the outer tick marks to be a different color than the numbers around the gauges like this image?
I'm trying to plan this mod and when I look at the pictures of the LED locations it makes it look like the numbers and ticks are lit up from the same LED but this pictures seems to mean that's not true.
Does anyone have a picture of the LEDs that specifically light the ticks or know how many LEDs it'll take for that section?
I have no problem doing this mod, but this is my daily driver so I want to make sure I have everything before I start so I can finish in one go.
Thanks in advance for any help!
My guess is this: Fluorescent Speedo & Gauge Needle Restoration Paint - HiPo Parts Garage
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines// http://www.toyota-4runner.org/4th-ge...ld-thread.html
10-20-2016, 09:43 PM
#36
Real Name: Mark
Real Name: Mark
Originally Posted by jfry008
That's probably what they used, because if you zoom in you can see it's not perfectly even. I would try a filter or tape like
@ techoguy
said!
I have some of the paint mentioned above, that's what I used on my needles.
'04 Sport V8
10-20-2016, 10:05 PM
#37
Can you access the back of the graphics to put a filter in? I don't want to paint the face of it for the reason mentioned about it looking even.
And for the needles I take it you have to take the red off then paint the blue on the back?
10-20-2016, 10:28 PM
#38
Real Name: Mark
Real Name: Mark
Yes you can access the back, will need to take needles off to do that! Not hard use a fork and pull up.
Yes you need to scrap factory orange off. Do you have a limited? Cause they are red and a little different
'04 Sport V8
10-20-2016, 11:22 PM
#39
@ S p a r k y
thanks for the picture. I think I'm going to try placing a blue light filter behind it. That should work as long as the lights not dispersed within the front gauge panel itself.
I just got an 04 v8 4x4 Sport. making a list of mods for my project . A few AC control lights are out so going to replace those and no probably the gauge lighting too. The only section I really don't want to do is the steering wheel LEDs. We'll see.
10-21-2016, 01:24 AM
#40
I thought the limited clusters had more leds on the perimeter instead of the few in the middle of each gauge on the sr5 and sports.
2007 Toyota 4runner Sport Edition 4x4, 15% tint, 1.5 inch ALL PRO spacers, de badged, Full interior LED swap (cluster, hvac, etc), plastidip wheels, blacked out headlight housing, K&N, smoker kit, carbon fiber shifter knob, carbon fiber interior wrap, diff breather mod, added VSC off mod, added Compass rearview mirror, independent fog lights, DTRL delete, zXe bulbs, Jensen VX7022 NAV head unit, back up camera, custom rear storage
10-21-2016, 10:56 AM
#41
Real Name: Mark
Real Name: Mark
@ S p a r k y
Steering wheel is just as easy as cluster, if you can do one the other is same. Just unhook battery loosen screws on either side of wheel. You can lift the center of steering wheel up on top of steering column, with plenty of airbag wires left and it wont explode. Very easy.
'04 Sport V8
10-21-2016, 11:00 AM
#42
Good to know. The air bag is what makes me hesitant.
Sent from my SM-N920V using Tapatalk
2004 V8 4x4 Sport - Icon Stage 2 3/2" lift- TC UCAs - Icon 3" Overland Springs - MK6 Level 8 Wheels 0 offset - KO2 275/70R17 (upgrading to Nitto Ridge 285/75R17 34" soon) - Lots of lights, DIY switches
Many more mods to come plus build thread
Follow me on IG: @ChaseOverland
07-30-2017, 05:39 PM
#43
Real Name: Parker
Real Name: Parker
How did you mod the key ignition light?
11-02-2017, 10:20 AM
#44
Second that! Also is anyone stil doing the swap if i sen them my cluster and dash? If SO HOW MUCH?
12-03-2017, 11:48 PM
#45
I'd also be interested in having the center console/multifunction display with blue lights. Is this still being offered?
