Old 05-11-2013, 02:01 PM #1
bergs's Avatar
bergs bergs is offline
bergs is on a distinguished road
bergs's Avatar
Head gasket failure on the V8?
How common are head gasket failures on the V8? I ask because my temp spiked when towing a small tractor on the highway and the way the temp gauge is acting, I am fearing a head gasket issue.
Temp goes up when the engine is under a moderate load.
Temp returns to normal when cruising
I cannot confirm at this time whether or not the overflow tank was needed however the coolant level is at the designated "full" level.
bergs is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 02:25 PM #2
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
never heard of one, but it's possible. might be the thermostat or waterpump?
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 02:26 PM #3
Pritchnakoff's Avatar
Pritchnakoff Pritchnakoff is offline
Pritchnakoff is on a distinguished road
Bergs I don't have the V8, but a similar experience happened to me a few years back when on a trip from San Francisco to Denver. Under normal cruising or event high downhill speeds, the temp was normal. Then as soon as the engine was under ANY duress the temp would go straight through the roof...
Eventually I found a shop in BFE NV/UT area and it turned out I had not thoroughly washed out the space between the radiator and it was not getting enough air passing through to cool the fluid. The mechanic grabbed a hose and jammed it up and under and at full pressure a bunch of dried up caked on mud came falling down. Temp was fine for the rest of the trip. I dodged a huge bullet and learned a good lesson there, not sure if you do any wheeling, but it's a cheap thing to look out for, before thinking of something much pricier.
I hope it's not your head gasket, good luck!
2004 4Runner Sport V6 - Silver
BFG KM2 285/70/17 | Shrockworks Sliders | Spidertrax FF | TRD CAI | TRD Valve Stem Caps | Camburg UCAs
Toytec C/O Lift 3/2 | Custom Rack | iPod Controls | R Diff Breather | Cobra 29 LTD BT | Custom End Links | Weather Tech Liners | Custom Rear Drawers
Pritchnakoff is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 02:58 PM #4
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
First thing I would check is what Pritchnakoff stated. debris, leaves, and crap settle in between the radiator and evaporator, the fins clog up and the stuff rots away into a mud that packs stuff up. A partially clogged radiator will exhibit symptoms similar to yours.
The 2UZ-FE doesn't have many headgasket issues as far as I know unless you overheat them, but that doesn't mean its not impossible.
After letting the vehicle sit for a long time and when you start it, is there a puff/cloud of white smoke? What about a rough idle? Low coolant level? These are all possible indicators of a failing headgasket, a thermostat could be an issue, but unlikely as they usually fail open rather than closed and would cause lower than average temperatures.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 04:10 PM #5
ebg18t ebg18t is offline
ebg18t is on a distinguished road
Hummm.. My old Kubota tractor weighed about 3500#, trailer weighed about 750#. That should be no problem with the v8.
Are your coolant levels at the right level? Any past issues with the truck?
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 07:50 PM #6
tollboothwilley tollboothwilley is offline
tollboothwilley is an unknown quantity at this point
Also, it is possible that your fan clutch is starting to go out - maybe its slipping when it shouldn't and isn't pulling enough air. There is a way to test it but its been a while since I dealt with fan clutches. Just another option though - you said that the temps come down at cruising speeds.
Don't forget to change coolant regularly too, if you haven't.
Black 2003 Sport Edition V8
tollboothwilley is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 08:28 PM #7
bergs's Avatar
bergs's Avatar
The water pump was replaced about 30,000 miles ago when the t-belt was done.
The area between the radiator and condensor(?) appears to be clean however I did not inspect from the underside. I do go offroad but thoroughly clean after every trip. Regardless, it is something I will check in the morning.
Fan clutch is new.
BlackWorksInc- I will look for a white cloud the next time I start it. Idle doesn't feel terrible but how rough is "rough"? As far as low coolant, I added about a pint to the radiator once I was home. (The adding of coolant in my case is somewhat to be expected since I have an ever-so-slight leak at the t-stat housing.)
My question for you is, if this is a head gasket, would I be able to essentially over-pressurize the cooling system using hard acceleration which would force the coolant to purge into the overflow and possibly overcome the radiator cap? This question is based on what I was experiencing with my ATV when that head gasket failed...curious of the chances of replicating the scenario with my 4Runner. 15psi on the ATV versus ?? psi on the 4Runner
Thank you all for the help so far! I have a few thing to check still.
Old 05-12-2013, 05:48 PM #8
bergs's Avatar
bergs's Avatar
This issue HAD to be related to a steam pocket, though I'm not sure how it would have gotten into my cooling system.
Went for a drive today, performed some hard accel tests without issue. Got on the highway, floored it from 30 to 90 and the temp did not budge.
Guess it's not a head gasket...
Old 05-12-2013, 06:49 PM #9
TRDCal's Avatar
TRDCal TRDCal is offline
TRDCal is on a distinguished road
TRDCal's Avatar
I recommend stop trying to convince yourself its the head gasket. There not known to go, your not showing definitive signs of a head gasket and its the most expensive part to change so it makes no sense to start there.
The only way you over pressurize the system would be to over heat the fluid. Hard acceleration wouldn't be enough to over heat the fluid unless there's a malfunction somewhere. I would start by making sure there's no air in the system and make sure the fan clutch is working. Just because a part was changed doesn't mean its not the problem, fault part (especially if its aftermarket) or improper installation could be the cause. You could also try flushing the system, maybe the rad is internal blocked.
SOLD Jan/15
03 V8 4x4 Limited, RAS converted to coil w/1.5 spacers, Bilstein 5100's 2.5" setting, 265/70R17 Grabber AT2s, FJ Rims, Custom headers, dual exhaust, 20% tint, HCF delete, VSC off mod, blacked-out headlights, WeatherTechs, TRD shift knob.
TRDCal is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 07:40 AM #10
zimm zimm is offline
zimm is on a distinguished road
Change the thermostat- it's cheap. If that thing is sticking, it could overheat at anytime. You can test it in a pot of boiling water on the stove to see if it opens.
2008- sold
zimm is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 08:16 AM #11
bergs's Avatar
bergs's Avatar
Not trying to convince myself of anything. The symptoms I was experiencing on the road emulated a head gasket issue.
I replaced the t-belt, water pump, etc about 30,000 miles ago and had no reason to suspect that there was a steam pocket (or other issue) within the cooling system.
My vehicles are always maintained so caked up dirt, internal radiator blockage or some other maintenance scenario is not highly likely.
As far as the 2nd part of your post, yes, hard accel can over pressurize a cooling system due to a combination of heat and increased cylinder pressure as a result of additional fuel/air being introduced to the combustion chamber that needs to be burned. This is exactly what was happening to my ATV(most recently) which resulted in the coolant overflow and the rad cap being overwhelmed by pressure. My question was out of curiosity of this occuring with the V8.
Disagreements aside, I do appreciate your response.
Old 05-13-2013, 07:04 PM #12
The system is designed to overpressurize naturally, that's the purpose of the overflow bottle. The issue is when the coolant doesn't go back in, i.e. you see crust around the cap or something simlar where the coolant is getting out.
An air pocket is quite possible as you stated your thermostat is leaking, anywhere coolant can seep out when cool or hot is a place air can go in. As for the headgasket, normally if the headgasket is leaking, when the engine cools or sits after a while it will leak coolant into the cylinder (usually cylinders that have negative pressure in them) and thus will show a puff of smoke at start-up. This is often the most common pre-cursor, symptom to indicate a possibly failing head gasket.
Old 05-13-2013, 08:39 PM #13
TRDCal's Avatar
TRDCal's Avatar
Thanks for taking my post well, I try to disagree with respect
In my line of work, when a problem arises you always go to the books and see if a part was recently changed, if it was then that's where you start your troubleshooting. 30,000 miles ago isn't necessarily "recent" but that's my thought process anyways.
I may have misinterpreted your "hard accel" question. Your correct, on a motor with a bad HG you could definitely over pressurize the coolant, (most the time it will just come out of the overflow as BlackWorks said) in some instances of really bad HGs, with the engine running and rad cap off you'll see bubbles. I was saying on a perfectly serviceable motor, it is impossible to over pressurize coolant system just from hard acceleration. Cuz if it was possible I'd have experienced it many times by now, especially since I got the duals
Exactly, also explains why you get rough idle for a few secs on the first start of the day. Coolant doesn't burn so well lol.
SOLD Jan/15
Old 05-13-2013, 09:01 PM #14
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
You would pretty much have to bake this engine in order for the head gasket to blow. This V8 is going to go down as one of the most bullet proof engines Toyota has developed.
Glad to see that all is ok.
toyo is offline   Reply With QuoteReply With Quote
Old 09-01-2013, 10:51 AM #15
bergs's Avatar
bergs's Avatar
Looks like my previous post was lost.
Here's the latest:
T-stat housing gasket (NOT the o-ring) was replaced yet over temp condition still exists.
Seems to happen when the engine is under added stress such as highway with A/C or towing.
Appears to be affected by ambient temps in that it will take longer to happen on cooler days/ nights.
Full throttle acceleration tests make this issue appear as if there isn't enough flow as the temp does not spike under full throttle, only partial.
So, before my post was lost I got to wondering...what would it take to cause a blockage in the cooling system?
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
Head gasket? 92-SR5 Classic T4Rs 2 09-05-2012 02:40 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
What head gasket to go with? Coreyctr198020 Classic T4Rs 0 01-02-2011 01:25 AM
Head Gasket - DIY Angella Classic T4Rs 29 01-22-2006 07:09 AM
