05-11-2013, 10:27 PM
Long tube headers
Hi there. I was curious if anyone can tell me if the 2002ish tundra Long Tube headers are a direct bolt on to our 4.7 V8s? I have seen it on here some videos and such, but there really isnt any good supporting conversations on it. I do not want to go with shorties yet. Do I need to put in a body lift to clear the steering arm? I did read that was an issue for one gentleman.
Please keep the comments "to search" to a minimum because I have and have not found a lot, but some.
Thank you in advance.
2004 SR5, V-8, 6000k HID in headlights and Fogs, HCF MIA, K&N drop in, Rear Cat Convertor missing, MagnaFlow muffler, ToyTec Ultimate, Light Racing UCAs, SpiderTrax, 255/85R16 Cooper St, AVIC-X930BT, XM Satellite and HAM Radio. Otherwise completely stock.....For now. This pulls one HELL of a homebuilt camping trailer! Details to come!
05-11-2013, 10:32 PM
I'm pretty sure I'm the only one running them. They bolt up to the block fine on both sides. A new Y-Pipe will be required for the flanges to line up. My steering still rubs slightly, I need to address this eventually. The dip stick also needed to be re-routed. I don't think a BL will help the clearance on the steering, the header just needs to be pounded out of the way.
2003 SR5 4WD: V8 TRD Supercharged, TRD Headers, ARB Bull Bar, CBI Rear, OME 886 coils w/ 1/4'' Spacer, AllPro 3.5's w/1.5 DS, 5100's, 285 Cooper STT, Slee SS Brake Lines, Custom Sway Bar Links, 4xInnovations Sliders, AllPro Lower Links, DDM HID's, 30" Light Bar/Duallys, Safari Snorkel, Custom Y-Pipe, Magnaflow, BudBuilt, KurtFab Diff-Brace, Wet Okole's, JL Sub/Amp, KCCO
05-12-2013, 11:05 AM
SO you are just planning on beating/caving in one header tube to achieve the clearance for the steering? How did you relocate the dip stick tube? Just bend that also? I am not worried at all about building new pipes at all. My father has a muffler shop still a few hours away, so I will probably just head there to do it. Did you mileage go up much when not enjoying the sound of the exhaust?
05-12-2013, 11:51 AM
If your planning on putting headers on to improve mpgs, don't bother.
4Runner Lifted/Locked/Armored/Blown
www.texaswheelin.com
05-12-2013, 12:02 PM
Yeah they just zip tied the dip stick out of the way. I'm just gonna take a rounded piece of wood and massage the header in around the area. As far as mileage I do get it on it pretty frequently but I don't really think my mileage changed up or down. Though to be honest I don't calculate it. They take a bit of work to make them work but they're worth it 100%.
05-12-2013, 12:03 PM
Also I'd plan a whole weekend around the ordeal. My truck was at the exhaust shop for a couple days.
