Old 05-31-2013, 10:38 PM #1
e2hastie e2hastie is offline
e2hastie is on a distinguished road
Need advice from more educated
Long time lurker first time poster. Need some help in deciding between two different used 4th Gens. I currently already own a 2006 Sr5 v6, looking to add another runner to the family. The two I have narrowed down to are another 2006 sr5 v6 with 70K miles in Salasa Red, the other is 2006 Sport w/ V8 in white and 105k miles. The price is almost the same between the two of them. The decision I am having trouble making is I know the reliability I have had with the v6 so am I taking a risk buying a used V8? It hasn't had the timing belt done that I know of so I know that i'd have to get that done is there anything I should worry about with the V8? XRAS? Reliability? Thanks for any insight any one can provide
e2hastie is offline   Reply With QuoteReply With Quote
Old 05-31-2013, 11:11 PM #2
JohnnyT's Avatar
JohnnyT JohnnyT is offline
JohnnyT is on a distinguished road
JohnnyT's Avatar
If you have a v6 and like the v6 then get the v6 with less miles with the price being the same. The Salsa Red is sharp too IMO.
.......or get the other one.
2007 Sport 4x4 V8, Magnetic Gray - stock
JohnnyT is offline   Reply With QuoteReply With Quote
Old 05-31-2013, 11:21 PM #3
wkeryder4's Avatar
wkeryder4 wkeryder4 is offline
Real Name: Will
wkeryder4 is on a distinguished road
wkeryder4's Avatar
Real Name: Will
Is there a reason your were looking at the v8 other than the v8 itself? It sounds like the v6 would be a better deal unless you had something in particular that you wanted the v8 for.
wkeryder4 is offline   Reply With QuoteReply With Quote
Old 05-31-2013, 11:44 PM #4
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
I like the V8, the XRAS on mine lasted 175,000 miles without any problems. I really is a better ride than the stock SR5 I have know.
V8Man is offline   Reply With QuoteReply With Quote
Old 05-31-2013, 11:47 PM #5
smc23's Avatar
smc23 smc23 is offline
Real Name: sean
smc23 is on a distinguished road
smc23's Avatar
Real Name: sean
if you want the V8 and you know the timing belt hasn't been changed you could use that as a bargaining chip to lower the price a bit since it needs replacing at that mileage. The 4.7 is a great engine very reliable with the correct maintenance, cant really say anything about the x-reas since I don't have it.
2005 SR5 V8 plasti-dipped emblems/grille/badges, daystar 2.5/1.5 lift, ATX Crawl wheels, 265/65/17 BFG rugged terrains, HCF delete, aFe pro dry filter, Gibson catback exhaust, Pioneer head unit, JL audio 500w amp, JL audio 10"sub
smc23 is offline   Reply With QuoteReply With Quote
Old 05-31-2013, 11:52 PM #6
No reason for the v8 except the added power and extra towing capacity if/ when needed. As an added wrinkle I'd like to turn this into more of a off road capable vehicle and have my previous 4runner be more of the "grocery getter" for the wife. So I am mostly trying to determine if the added 30k miles makes much of a big difference. I know its trivial in the end, either one is a great rig. Just curious on peoples opinions if the added power is worth the extra miles.
Old 06-01-2013, 12:09 AM #7
smc23's Avatar
Real Name: sean
smc23's Avatar
Real Name: sean
Well hey who wouldn't like extra power! If you plan on making your second runner more off-road capable the V8 would be a good choice with the extra torque and hp for bigger wheels/tires, aftermarket bumpers and weight added it takes to make a serious off-road vehicle.
Old 06-01-2013, 12:32 AM #8
Robs08Runner's Avatar
Robs08Runner Robs08Runner is offline
Robs08Runner is on a distinguished road
Just go by color here. One is right and one is wrong. Lol
Robs08Runner is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 12:54 AM #9
smc23's Avatar
Real Name: sean
smc23's Avatar
Real Name: sean
i do agree with this, not much of a fan of white unless you black out all the chrome
Old 06-01-2013, 01:37 AM #10
Troymclure's Avatar
Troymclure Troymclure is offline
Real Name: Jake
Troymclure is on a distinguished road
Troymclure's Avatar
Real Name: Jake
Id say go with the V8. If you want to make it more offroad capable, the V8 will definitely help. I have a V6 and my Dad has the V8, both are sports, and I often wish I had the extra power. But in the end, its up to you, its your car
Troymclure is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 02:46 AM #11
Geologist's Avatar
Geologist Geologist is offline
Real Name: Alex
Geologist is on a distinguished road
Geologist's Avatar
Real Name: Alex
The 4.7 V8 is a great motor, especially if you're gonna run larger tires. You should be able to use the timing belt as a bargaining chip to lower the price. That's typically a $800-$1000 service. I average about 13-14 mpg with the V8, mostly around town with a 3/2 lift and AT tires.
2003 4Runner SR5, V8, 4WD
A few mods...
@LostInTheWoodsT4r on IG
Wheeling Videos
Build Thread
Geologist is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 02:59 AM #12
trailrazer's Avatar
trailrazer trailrazer is offline
Real Name: Eric
trailrazer is on a distinguished road
trailrazer's Avatar
Real Name: Eric
It's a Toyota.... another 30K won't make much of a difference. Consider which one is in better shape and whether you want the V8. Since your V6 is the DD, I'd lean towards the 4.7 and worse MPG after lift/tires...but more HP and torque. Make sure neither were owned in a state where roads are salted. I made that mistake with my first 4Runner.
2003 4Runner SR5 4WD V6... Sold
2008 4Runner SR5 4WD V6- 5100's FJ Coils DS Spacers - 265/70-17 Cooper ATP's on Ultra Drifter's
http://www.toyota-4runner.org/4th-ge...d-v-2-0-a.html
trailrazer is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 08:16 AM #13
T4RME's Avatar
T4RME T4RME is offline
T4RME is on a distinguished road
T4RME's Avatar
My wife drives a 2008 Sport V6 bought with 36k mi and now with 85k mi. For work she put on over 30K in miles in one year. I am now seeing how those 30K miles really beat it up like front bearing, idler pulleys, shocks.
Also, I wouldn't want to finance anything over 100k AND I always consider why someone is dumping a vehicle at the mileage they are. Something has inspired them, perhaps mounting problems...
My .02
2008 4Runner Sport V6/4WD/White
T4RME is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 09:01 AM #14
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
Another difference is the 4 wheel drive system. The V8 has full time 4 wheel drive, the V6 is selectable.
Xreas is a better ride but if you are going to do a lift you will probably be replacing that anyways.
I had a 2003 Limited V8 with Xreas. Put on Daystar spacers and went anywhere I wanted to go. I don't do extreme technical stuff but I like to go where I want to.
Now I have a 2005 Sport V6. It is lifted with King shocks. I like this one better than the limited. It is Salsa Red and that is one sharp color.
I am taking it out wheeling in about 2 hours for the first time so I cant compare it to the Limited yet. But on the road, it is just as peppy as the V8 was and mileage seems to be just a tad better
Need advice from more educated-driver-side-front-jpg
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 06-01-2013, 10:57 AM #15
Brazenhead's Avatar
Brazenhead Brazenhead is offline
Brazenhead is on a distinguished road
Brazenhead's Avatar
Pssst! Get a Tacoma! You already have a 4Runner.
Seriously though, we have one of each and I love them both (of course the V8 a little more) but I still want a Taco.
2014 T4R SR5 premium pkg wife’s daily, 2004 Tundra DC 4x4 current daily, 2003 T4R SR5 V8 4x4 (sold), 2005 T4R Limited V6 4x4 (sold), 2000 Tundra AC 4x4 (sold), 2003 Echo (sold), 2007 FJC (sold and dearly missed)
Brazenhead is offline   Reply With QuoteReply With Quote
Advice on 1st gen toy-freak Classic T4Rs 17 06-09-2013 10:11 AM
Need Advice..would you buy??? 67mike 3rd gen T4Rs 14 04-18-2012 10:40 AM
need educated Julie/iowa Classic T4Rs 8 06-30-2011 08:38 AM
Toyota getting educated, changing Tundra's model mix Thai All Other Vehicles 21 04-26-2007 06:06 PM
Advice: Beware of bad advice from unqualified journalists Thai 4th Gen T4Rs 1 02-05-2003 10:04 AM
