Old 06-05-2013, 12:52 AM #1
raminux raminux is offline
raminux is on a distinguished road
Question Using 265/75R16 insteadof 265/70R16?
Hello,
On my AWD v8 4Runner, will there be a problem using 265/75R16 tires instead of the default 265/70R16 size. I have read with AWD, all four tires must be the same size which is what I am planning to do. I also know the truck will run faster than the speedometer will show; so I must be careful not breaking speed limits.
Any other problem? Gas consumption difference?
Thanks.
raminux is offline   Reply With QuoteReply With Quote
Old 06-05-2013, 04:40 PM #2
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
Originally Posted by raminux View Post
Hello,
Thanks.
70 and 75 is your tire width, i.e. how thick the rim is... You're not going to be able to run them on the stock rims. And no, Thicker tires won't require spedometer recalibration... Tire diameter can, however.. If you go from 265's to say 285's, I'd say you may want to look into recalibrating spedometer.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 06-05-2013, 05:15 PM #3
Ernest1863's Avatar
Ernest1863 Ernest1863 is offline
Ernest1863 is on a distinguished road
Ernest1863's Avatar
Hello,
Thanks.
going from a 265/70R16 to a 265/75R16 is basically going from a 31" tire to a 32" tire. I recently did the same to my 2003 sr5 v8 and there are no problems. It seems kind of close, but there isn't any rubbing. Noticed little if any MPG droppage.
Good luck to you man!
16th birthday present
2003 black sr5 sport, v8 4.7 liter, black bull bar, avs ventvisors, auxiliary lights on bull bar, blue gauge needles, double DIN pioneer touch screen radio, leveling kit, 32" Toyo Open Country AT 2's, hcf delete, drop in K&N filter, and 18" magnaflow muffler.
War Damn Eagle
Ernest1863 is offline   Reply With QuoteReply With Quote
Old 06-05-2013, 05:24 PM #4
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
Your Speedometer will be a little off, more noticeable the faster you go. It is going with a taller tire, not wider.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 06-05-2013, 05:38 PM #5
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
Wait, explain?
-Helpful DIY Videos
Old 06-05-2013, 05:43 PM #6
NJshadow93's Avatar
NJshadow93's Avatar
For the 16" rims, 265/70 is the stock size. Going from 265/70 to 265/75 is increasing the height, or diameter, of the tire. The tire will be an inch taller. 265 is the width, so stock size is 265 millimeters wide. The speedometer will be a little off because the taller tire does not rotate at the same speed as the stock size. It is not much, I went from 265/65/17 to 265/70/17, which is the same as OP wants to do, just different size rim, and the speedometer is off about 0-3 mph depending on how fast I'm going.
Old 06-05-2013, 06:23 PM #7
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
I get the speedo part.. I was just always under the assumption width and height is switched.. (awkward..) What does going 285/70 do then?
-Helpful DIY Videos
Old 06-05-2013, 07:08 PM #8
Doozi's Avatar
Doozi Doozi is offline
Doozi is on a distinguished road
Doozi's Avatar
The 70 and 75 are the aspect ratio representing the height of the sidewall... it's the percentage of the tread width. The overall height of the tire would be 2 sidewalls + the wheel diameter.
>> a 265/70 has a sidewall that is 185.50mm (70% of 265mm) so the height of this tire would be 30.61"
>> a 265/75 has a sidewall that is 198.75mm (75% of 265mm) so the height of this tire would be 31.65"
Just about an inch different as others have mentioned. The larger diameter does lower your indicated speed, but not by very much in this case.
Hope that helps!
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 06-09-2013, 12:55 PM #9
Thanks for the tips.
Old 06-09-2013, 04:08 PM #10
Icepuck72's Avatar
Icepuck72 Icepuck72 is offline
Icepuck72 is on a distinguished road
Icepuck72's Avatar
I run this tire size in duratracs. Minor rubbing. Just depends on what brand tire you use.
2006 Tacoma DC TRD Radiant Red
OME 885's & Dakar Rear 3"
285x75x16 Goodyear Duratracs
TRD Trail Edition wheels
Icepuck72 is offline   Reply With QuoteReply With Quote
265/70r16 or 245/75r16 Any thoughts? CarbonCrew 3rd gen T4Rs 9 02-21-2013 11:38 PM
Will 305/70r16 fit? Frilot22 3rd gen T4Rs 4 11-08-2012 11:33 PM
305/70r16 tires are they too big? lolofdz 4th Gen T4Rs 12 03-21-2012 03:32 PM
WTB/TRADE: My 265/75R16 for your 285/75R16 aeroneer1 Want to Buy/Trade 0 03-21-2012 11:52 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
