06-05-2013, 03:01 AM
Rear clunk noise after replacing front strut assembly
My 2004 4runner is equipped with the XREAS system and I just upgraded the front suspension with Rancho's QuickLift complete strut assembly (instead of using a spacer). Now the rear suspension is making a clunk noise when on an uneven road or while going over a bump. It almost seems like the car might be bottoming out. However, there are no signs of this happening. All nuts and bolts are tight, and all bushings are in good condition, so do you think that it may be something internal such as in the rear shock? I know the XREAS system connects the front and rear shocks, so I'm thinking that all the fluid has drained out. Any help would be greatly appreciated!
06-05-2013, 05:49 AM
Real Name: Alex
Real Name: Alex
Did you change any of the shocks? (i.e. Swap or mess with) If you swapped any, the opposite needs to be swapped at the same time, and if you messed with it, check all connections.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
06-05-2013, 12:19 PM
I only changed the front shocks and did nothing to the rear. Would that cause the clunk noise I am hearing?
06-05-2013, 12:28 PM
Real Name: John
Real Name: John
If you removed the front shocks then that would kill the rears because the system is designed to have the passenger front connected to the driver rear and the driver front connected to the passenger rear. This is a closed system that cannot work without all the components installed as the hydrolic fluid runs back and forth between the 2 connected shock. At this point you are better off getting new rear shocks.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
06-05-2013, 12:31 PM
I just ordered a new set for the rear. Hopefully they will fix the noise!
06-05-2013, 01:10 PM
If you just did the front 2 only I can't believe your rear end isn't bouncing around like crazy. Mine was barely even driveable until I got the rear shocks replaced also.
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
06-05-2013, 01:36 PM
The fact that you opened up a sealed system and left it open after.. If you had taken a little more time and done your homework you'd of saved your self this hassle and maybe a little $..Trust me I've learned this the hard way when I was younger.
06-05-2013, 01:38 PM
The rear end has been quite the opposite.. it feels "dead" and very little bounce
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
