06-14-2013, 12:22 AM
Can I make my power socket constant?
My kids watch tv and everytime I kill the teuck the tvs go off. Is there an easy fix?
06-14-2013, 12:43 AM
did you try to turn it a bit? it worked in my last jeep jk
2006 V8
06-14-2013, 01:27 AM
Real Name: John
Real Name: John
JA Full Time 12volt Power Mod
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
06-14-2013, 02:41 AM
Originally Posted by morphious
so the wire replaces the relay?
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
06-14-2013, 02:44 AM
Real Name: John
Real Name: John
Yes.
06-14-2013, 10:13 AM
I've done the ac mod. What about the one by the shifter
06-14-2013, 10:39 AM
Yes.
Not sure what you mean by 'replaces?' The relay is still there, you just run a wire to "jump" two different parts of the relay. Probably be more accurate to say the wire allows you to bypass the relay, because the relay itself is still there.
I did this mod a few months ago and what I discovered was that this mod will put the front and rear 12v power outlets into full-time-on mode.
However, if your 4runner has a cigarette lighter (and mine does) in the console, that's on a separate circuit so it will only be on when the ignition is on.
Martin AKA Zapp Branigan - No longer a 4runner owner!
06-14-2013, 06:39 PM
Real Name: John
Real Name: John
[QUOTE=Martinjmpr;1404402] Not sure what you mean by 'replaces?' The relay is still there, you just run a wire to "jump" two different parts of the relay. Probably be more accurate to say the wire allows you to bypass the relay, because the relay itself is still there.
I suppose you could do that, I did this and the full time window mod and removed the relay on both mods. I have also done the fog light mod and that one retains the relay as you bend one pin and jumper from there.
