Old 06-16-2013, 06:13 PM #1
raminux raminux is offline
raminux is on a distinguished road
Question Fuel Consumption Surge, Possible Reasons?
I recently bought a 2003 4Runner which needed a couple of repairs and fixes. So I took it to the mechanic last week and the following jobs were done:
1- The pipe departing from the main body of the muffler was cut which was welded to its place.
2- rear brakes were replaced: disks, pads and calipers.
3- one hand brake string was replaced.
4- a leak happened in a pipe related to the steering wheel which was fixed.
Now, it looks like there is a sudden surge in fuel consumption. The system used to show 12-12.5L/10km (19.6-18.8mpg). Now it shows 15.9-16.3L/100km (14.8-14.3mpg). I also sense the increase in fuel consumption and I am wondering why this could have happened? Which one of the above repairs could possibly have such an impact. Or perhaps another reason is in effect.
Thanks.
raminux is offline   Reply With QuoteReply With Quote
Old 06-16-2013, 10:24 PM #2
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
You said something about replacing a hand brake string. I assume this is a parking brake cable. Is it adjusted properly, if not the parking brake could be dragging.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 06-16-2013, 10:30 PM #3
eddiebx's Avatar
eddiebx eddiebx is offline
eddiebx will become famous soon enough eddiebx will become famous soon enough
eddiebx's Avatar
Thanks.
Do you know if they happened to have disconnected the battery (which might've reset the stored MPG data)? I think that MPG display is based on a long term average so if it was recently reset it would be starting fresh, so to speak. This might be one cause for the lower numbers.
I would try manually calculating it for more accurate data.
eddiebx is offline   Reply With QuoteReply With Quote
Old 06-17-2013, 12:24 AM #4
eddiebx: Actually they did disconnect the battery since the clock had to be adjusted too. I didn't think the fuel consumption rate is a longterm average and I have mostly been driving in the city since I got the t4r back. I wonder if 14.5mpg is normal or not?
03_4x4Runner: When the parking brake (which I called hand brake) was used and then released before starting the vehicle, I hear a noise coming from the lower part of the vehicle (like something is making a noise while rolling). I am going to the garage again to have it checked.
Old 06-17-2013, 10:22 AM #5
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
op, is this by the read out ( which isnt accurate anyway) or hand calculated? do you have v6 or v8? imo, with v8, 14.5 all city driving is good. you cant expect high mpg numbers when driving mostly or all city.
chaz is offline   Reply With QuoteReply With Quote
Old 06-17-2013, 10:28 AM #6
Originally Posted by chaz View Post
op, do you have v6 or v8? imo, with v8, 14.5 all city driving is good. you cant expect high mpg numbers when driving mostly or all city.
Yes, it's v8.
Old 06-17-2013, 10:32 AM #7
WXman's Avatar
WXman WXman is offline
WXman is on a distinguished road
WXman's Avatar
yeah my guess is the parking brake is hanging...or possibly the caliper is sticking on one or both sides after the brake job.
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
WXman is offline   Reply With QuoteReply With Quote
Old 06-17-2013, 02:29 PM #8
eddiebx's Avatar
eddiebx's Avatar
I believe the reading on the dash is a long term average and not a tank to tank average. If you are talking about this display reading low, I wouldn't worry about it too much especially after you said that the battery was disconnected. Perhaps calculate the MPG by hand for a few tanks and see how that goes.
If you want to check for parking brake drag, jack up the rear and spin the tires. There should not be any excess drag and you should definitely be able to spin the tire by hand.
Old 06-17-2013, 04:09 PM #9
fo'dilly fo'dilly is offline
fo'dilly is on a distinguished road
Calculating Mpg by hand instead of using the read out usually puts me at about 2 miles less per gallon than what the computer says. From what i've read this seems to be pretty typical city mpg
fo'dilly is offline   Reply With QuoteReply With Quote
Old 06-18-2013, 09:57 PM #10
The parking brake cable is to be replaced. I will next do a manual calculation of fuel consumption and will write it back here.
Old 06-19-2013, 10:31 AM #11
chaz's Avatar
chaz's Avatar
in case its of any interest. V8 MPG if you still do only city & almost no highway, dont be surprised if it comes out less than 14.5 with the hand calculation, but add a little highway mileage, it will go up a bit, & my guess is you will be somewhere in the middle of the avg. v8 mpg. what im saying is, since you haven't had it too long, that the slight dip in mpg may just be a result of the battery disconnect (reset) & mostly or all town driving & may not be the result of something being wrong.
Old 08-03-2013, 05:51 AM #12
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
could be a stock calip[er...touch your wheels after a long drive..see if the temp are about the same.
mine dropped to as low as 12mpg on the display meter. and found out my right front caliper was hot..super hot after a few miles drive.....after servicing the caliper....my mileage display now reads 18mpg on intercity and 21mpg on highways..when i reset it...
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 08-03-2013, 12:55 PM #13
TRDCal's Avatar
TRDCal TRDCal is offline
TRDCal is on a distinguished road
TRDCal's Avatar
Haha...my suggestion was going to be take your truck back and have them replace the string with a proper cable lol
SOLD Jan/15
03 V8 4x4 Limited, RAS converted to coil w/1.5 spacers, Bilstein 5100's 2.5" setting, 265/70R17 Grabber AT2s, FJ Rims, Custom headers, dual exhaust, 20% tint, HCF delete, VSC off mod, blacked-out headlights, WeatherTechs, TRD shift knob.
TRDCal is offline   Reply With QuoteReply With Quote
Fuel consumption error - Maint light reset adam5oh 4th Gen T4Rs 2 12-23-2020 08:46 PM
Improving on 12mpg fuel consumption duffbeer911 3rd gen T4Rs 3 07-17-2012 09:55 AM
Horrible fuel consumption problem! Brand X Classic T4Rs 0 01-12-2010 12:02 AM
Question fuel consumption W211_to_T4R 4th Gen T4Rs 10 07-20-2008 01:33 PM
Accuracy of multi-information display (fuel consumption, temp, etc) CosRunner Engines / Suspension / Wheels / Tires / Audio / Accessories 7 04-01-2008 12:16 PM
