Old 07-22-2013, 06:29 AM #16
ebg18t ebg18t is offline
ebg18t is on a distinguished road
For comparison the stock measurements I found were:
Front: 19"
Rear: 21"
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 10-30-2013, 03:28 AM #17
cacarbuff cacarbuff is offline
cacarbuff is on a distinguished road
Let's get more suspension options in here! And maybe we could link to it in the stickied Suspension Options thread...
Heights:
Front: 22.5" both
Rear: 24.25" (DS), 24.75" (PS)
Suspension:
Front: Icon Extended Travel Remote Resi Coilovers cranked up a bit with Total Chaos UCAs
Rear: MetalTech LT Standard coils with 1.5" Daystar spacers and LT Icon VS 2.0 Shocks
Weight Additions:
Gobi Rack w/ shovel, custom cargo drawers, AT spare tire, 48lb Golden Cattle Dog mix
cacarbuff is offline   Reply With QuoteReply With Quote
Old 10-30-2013, 05:43 PM #18
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
FR: 24.0
FL: 24.0
RR: 25.0
RL: 25.0
Front: Walker Evans Coilovers cranked a bit
Rear: Toytec Superflex with 1.5 daystar spacer on driver side
LTDSC is offline   Reply With QuoteReply With Quote
Old 03-19-2014, 11:15 PM #19
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
Front: 19"
Rear: 21"
This is what my 05, V6 sport measured last weekend in stock form.
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 03-21-2014, 04:08 PM #20
dereky dereky is offline
dereky is on a distinguished road
2006 limited with V6
1" toytec body lift
Front 5100s set on second lowest level with eibach 620 coils.
Rear is toytec super flex 2" lift with 5100s and 1.5" DS spacer on driver side.
Front DS-24.5 PS-25.0
Rear DS-25 PS-25.0
dereky is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 06:16 PM #21
Roburban's Avatar
Roburban Roburban is offline
Roburban is on a distinguished road
Roburban's Avatar
Anyone have any Cornfed 3/2 measurements???
2008 Sport V6, Cornfed 3/2 Spidertrax, 265/70/17, TUFF LED 30" Bar.
Roburban is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 06:26 PM #22
Since that is a spacer and reuses your current spring/damper just add 3"/2" to your current ride height. If you change springs (like adding FJ's) you will see much more variance.
Old 05-07-2014, 08:28 PM #23
Soulman Soulman is offline
Soulman is on a distinguished road
Just installed the Toytec Ultimate lift. But, I swapped out the rear springs for OME 895E- these were supposed to lift 1.5" but ended up lifting about 2.25". Glad I didn't go with any higher. The fronts I had to turn down about 1/4 inch for about a 1/2 inch decrease in lift.
So,
----- Before--- After
DF--- 18.75--- 22.0
PF--- 19.0--- 22.0
DR--- 20.75--- 23.0
PR--- 21.0--- 23.25
Question- how much "settling" can I count on? I haven't driven it much at all as I want to get an alignment done before it starts wearing on my brand new BFGs. Overall, it is more lift than I was thinking it would be. Do I need to drive/settle it before alignment? I don't want to get the alignment done, then have it settle, and then do it again.
Thanks, Dan.
Soulman is offline   Reply With QuoteReply With Quote
Old 05-07-2014, 08:34 PM #24
Originally Posted by Soulman View Post
Just installed the Toytec Ultimate lift. But, I swapped out the rear springs for OME 893E- these were supposed to lift 1.5" but ended up lifting about 2.25". Glad I didn't go with any higher. The fronts I had to turn down about 1/4 inch for about a 1/2 inch decrease in lift.
So,
DF--- 18.75--- 22.0
PF--- 19.0--- 22.0
DR--- 20.75--- 23.0
PR--- 21.0--- 23.25
Thanks, Dan.
Give it a few days to settle before you get the alignment. Are you sure about your rear springs? Did you mean 895E?
It's kinda hard to know the exact lift amount compared to stock since everyone's stock springs are like saggy old boobs. Some are worse than others.
Old 05-07-2014, 08:39 PM #25
I did mean 895E- I edited it, thank you. As for a few days to settle...is that just sitting around (I have a car I drive more in summer)? It has been sitting in the driveway but don't I need to drive it to settle them? Thank you!
-1999 4Runner Limited w/RR locker, OME/5100s, 285 Toyo Trail R/Ts
-2021 Tacoma TRD Offroad w/OME/Bilsteins, 285 BFGs
Old 05-07-2014, 10:12 PM #26
It will settle better getting used. Needs to get cycled to really settle.
Old 05-07-2014, 10:49 PM #27
Plumber Plumber is offline
Plumber is on a distinguished road
Full OME Suspension with 886 and 896
Front: 24.25
Rear: 24.75
Build Thread
OME 886/896 w/OME shocks, "customish" sway bar end links, 265/75r16 KM2s, ext. diff breather, plastidip, CBI DLB's w/BeanLED duallys, custom electrical distro, Cobra 75wx st, 4ft Firestik Firefly on Comet RS730, Demello 3 hoop bumper w/Warn VR 8000, Camburg Balljoint UCA's, CBI rear plate bumper w/swing out tire carrier, CBI bolt-on sliders, Matte Bronze Konig Countersteer Type X 16s, more to come....
Plumber is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 02:33 AM #28
iceking05 iceking05 is offline
iceking05 is on a distinguished road
Looking for Moog 81108 and Moog 81081 with Bilstein 5100 lift height. what setting did you use for the front bilstein shocks. Thanks.
iceking05 is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 04:10 AM #29
MN4RNR's Avatar
MN4RNR MN4RNR is offline
MN4RNR is on a distinguished road
MN4RNR's Avatar
2006 V6 no aftermarket add ons.
OME 883 and 895E
Front - 22"
Rear - 23"
Still there after 1000 miles, some fire roads and heavyish loads from hardware store runs.
Defensor Fortis
02'-12'
"Sammy" 2006 SR5/OME Lift/Wulf UCA/C4 Fab Sliders and Skid/Kenda Klever AT2/BajaRack/Snorkel/Homebrew Drawer/Interior LED swap/TRED Pros
MN4RNR is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 06:58 PM #30
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Heights:
Front: 26"
Rear: 25.75"
Suspension:
Front: Radflo 2.5 Coilover with top plate spacer
Rear: All Pro 3.5" rear springs with cheap shocks
1.5" Body Lift all around
Weight Restrictions:
Front Perkins Bumper
Rear Custom bumper with 35" tire
Budbuilt skids front and mid
Baja Rack
Full Gas Tank
A10MileHusker is offline   Reply With QuoteReply With Quote
36" Ride Height is 2" lift? Greydog Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-08-2013 08:27 PM
rear ride height after lift Aquatic Escape Classic T4Rs 2 04-17-2012 02:35 AM
Limited owners with ride height adj. Lift question ToyotaTrailTeam 4th Gen T4Rs 8 10-02-2010 09:47 PM
Ride Height praetorian 4th Gen T4Rs 3 10-23-2007 06:10 PM
Ride height of the 4th gen chunderboy 4th Gen T4Rs 3 02-11-2005 07:25 PM
