Old 01-19-2017, 05:59 PM #46
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Originally Posted by Inv4drZm View Post
Really not sure the point of this thread? To see how your truck measures up to other's? Bragging rights?...
As I'm sure you have seen, many new owners wanting to do a lift are unsure what kind of lift heights they can expect from certain combinations of suspension components and vehicle configurations. This thread attempts to consolidate this info into one place and prevent new thread duplication.
techno is offline   Reply With QuoteReply With Quote
Old 01-19-2017, 06:09 PM #47
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
With adjustable coilovers its pointless to compare.
With a non-adjustable setup it is slightly more relevant only if a noob wants to compare numbers to see if they installed it correctly.
I found it useful (first time around) what route I wanted to take. I wanted a more mild lift and didn't want to look like I skipped leg day with stock tire size. I also refused to use the adjustment option on the Billy 5100, wanted a spring lift for the front. (and adjustable coilovers weren't in the budget)
Noob needed help finding something other than the standard 3/2" lift ;)
Times have changed, now rocking 285s and a 3/2" lift
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 06-18-2017, 04:28 PM #48
williamteichroeb williamteichroeb is offline
Real Name: William Teichroeb
williamteichroeb is on a distinguished road
my measurements
2009 SR5 4runner
addional weight- demello 3 hoop front bumper NO winch (approx 120lbs)
Front lift- OME 885 coils with 3/8" top out spacer back both sides, drivers side also has 5mm trim packer, nitrocharger 90021 shocks
rear lift- toytec superflex 2" coils with fox 2.0 performance series shocks for 2-3" lift
BFG KO2's 255/75R17 measured 31" height front 2, 31 1/4" height rear 2 with 36 psi in all 4
hub to fender measurements:
DF--23 7/8"
PF--24 1/4"
DR--24"
PR--24 3/8"
ground to fender measurements:
DF--38 5/8"
PF--39 3/8"
DR--38 11/16"
PR--39 3/8"
as you can see more or less even front to back, but there is a good drivers side lean. Mind you this is with a full tank of gas. I'll measure with an empty tank soon for comparison
2009 4runner SR5
build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
williamteichroeb is offline   Reply With QuoteReply With Quote
Old 01-31-2018, 09:13 PM #49
Jbarber777 Jbarber777 is offline
Jbarber777 is on a distinguished road
Toytec coil spacer/rear coils lift
Anybody running the toytec 3” coil spacer/rear coils lift? And if so what are the measurements? I read through and I don’t think I saw anybody with this specific lift.
Jbarber777 is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 09:12 PM #50
roy326 roy326 is offline
roy326 is on a distinguished road
Ironman 4x4 (they advertise 2” on their website) nitro gas 0-660lbs . The kit came with optional spacers for the front that I took advantage of since I’ll be running a metal bumper and winch later (I don’t recall the height of spacers,but it was less than 1”)
Full tank of gas btw and it’s been two weeks since install. There is no added weight at the moment.
Driver/Passenger front: 23.25/24
Driver /Passenger rear: 23/24
03 4runner V8 4x4
12 GX460
17 Tacoma OffRoad
roy326 is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 02:41 PM #51
wingzerom31996 wingzerom31996 is offline
wingzerom31996 is on a distinguished road
Post lift stats
2005 V8 4x4
Sports
Pre-lift:
FRONT D Center of hub to fender: 19.68"
FRONT P " " 20.4"
Rear D/P " " 21.5"
Post lift
Front D Center of hub to fender: 21.00
Front P " " 21.65
Rear D/P :23
OME 883
OME 895E
Bilstein 5100. No lift setting (perch at 0)
wingzerom31996 is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 10:21 PM #52
Tuby27 Tuby27 is offline
Tuby27 is on a distinguished road
2004 v6 sr5 4x4 no extra weight
Bilstein 5100 all around, front set at second perch
Wheelers t1 front springs and t12 rear springs
Hub to fender
Front- 22”
Rear- 24”
Jba high castor UCA.
Lift vs ride height list-076ee22d-e419-4934-97b0-3e5e31e0a149-jpg
Daily: 2004 4Runner SR5 V6 4x4
Pleasure: 2007 Tacoma DCLB TRD Sport 4x4
Tuby27 is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 08:44 PM #53
laufer's Avatar
laufer laufer is offline
laufer is on a distinguished road
laufer's Avatar
2004 Limited 4x4 V8 leveled with Bilstein 5100 and 5th gen TE springs
2004 Limited 4x4 V8 with rear air suspension, which I had removed using the Metal Tech 4x4 kit.
Original ride height: LF 18.75", RF 19.25", LR 21.5", RR 21.25"
New ride height: LF 20, RF 20.5, LR 21.5, RR 21.5"
Total lift: 1.25" F / 0 R
Suspension: Bilstein 5100 (second-lowest setting) and 5th gen TE springs.
This basically levels the vehicle, but it should be enough for 32" tires (255/75R17). No armor or other extra weight except some ARB skid plates.
More details on the 5th gen springs are available at my original post: https://www.toyota-4runner.org/2818606-post2594.html
I hope everybody is safe out there!
Blue Rhino - KD9IOJ - Stratosphere Mica 2004 4Runner Limited 4WD V8 (UZN215)
- front: 5th-gen TE springs w/ Bilstein 5100s set to 1.75", rear: Dobinson C59-599 1" lift springs
- Cooper A/T3 S4 255/75R17 - 5th-gen brake calipers and front rotors
- Kenwood DMX7704S digital media receiver HU
laufer is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 12:21 AM #54
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Mine will be off since I measured on my inclined driveway but -
Dobinsons C59-314/GS59-221 Front, C59-505/GS59-705 Rear.
23.5" all the way around - but I was JUST able to accomplish this today. The rear required BOTH a Daystar 1.5" FJ spacers AND a Dobinsons 15mm spacer...
Had the 15mm on and it was about an inch off, the 1.5" still was missing .5" but both gets me pretty dead on with the passenger rear which is WILD to me lol.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 03:14 PM #55
Rishi3's Avatar
Rishi3 Rishi3 is offline
Rishi3 is on a distinguished road
Rishi3's Avatar
Originally Posted by Roburban View Post
Anyone have any Cornfed 3/2 measurements???
My saggy springs are not the greatest at 160k miles but with the cornfed 3 rear and 2 front lift:
Front: 21.75
Rear: 22.5
So if I get some bilsteins and toytec springs I should be seeing about a 2 inch gain front and back OVER what I have with my "3/2" spacer lift.
That's nuts
Sent from my ONEPLUS A6003 using Tapatalk
Rishi3 is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 04:12 PM #56
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
2004 Limited V8 4WD, roof rack and 2 ~heavy amplifiers in the rear cargo area are the only real extra weight. Spare on roof rack.
Lift: Daystar 2.5” front/1.5” rear spacer lift, 1” Toytec body lift.
Center of wheel to fender:
Driver side front: 22.75”
Passenger side front: 23.00”
Driver side rear: 23.00”
Passenger side rear: 23.00”
Lift vs ride height list-88e53a49-ff46-4f5f-ae2f-247da5cef7eb-jpeg
ads2539 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 04:11 PM #57
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Stock 2005 V8 with 150k miles. Would this be considered sagging?
Front: 19”
Rear: 20.5”
Are people using diff drop kits to protect your CVs when lifting over 3 inches? Or does an aftermarket upper control arm help with this? Newb questions.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 09-19-2020, 05:09 PM #58
ads2539's Avatar
ads2539's Avatar
My 16 year old stock rear coils must have been really tired.
I just upgraded my rear today from the Daystar 1.5” spacer lift to the Bilstein 5100/Toytec coils 2” shock/spring lift, and my left and right rear measurements have both gone from 23” to 25”. I was expecting a half inch increase, not two inches!
Has anyone else had similar results?
I will also be ugrading my front from the Daystar 2.5” spacer lift to the Bilstein 5100/Toytec shock/coilover 3” lift. I wonder if I’ll get a 2” difference in the front, too.
I also wonder if the upgraded front will lower the rear a little. Right now, with just the new rear suspension installed, there is a 2.5” (?) rake. At ~23” all around, my 4R was basically level. Now, it’s at 22.5” in the front and 25” in the rear.
The rear lift has lowered the front a little, but my 4R is parked on a little downslope, so maybe it’s a little lower due to that.
UPDATE: I took measurements with my T4R on level ground. The rear went down ~.25” and the front went up ~.25”, so I’m still at ~2” rake.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
Old 09-26-2020, 03:31 PM #59
ads2539's Avatar
ads2539's Avatar
Another update:
I just finished the installation of my Bilstein 5100 shocks, Toytec springs and 1/4” spacers on the front that are supposed to achieve a 3” lift.
I now have a 3” front lift, a 2” rear lift and a 1” body lift, all Toytec except for the 4 Bilstein 5100 shocks.
My measurements are now:
Driver’s side front: 23.25”
Pass. side front: 24.00”
Driver’s side rear: 24.00”
Pass. side rear: 24.75”
Measurements taken on level ground with ~1/2 tank of gas and no occupants.
(My Daystar spacer/Toytec body lift measurements were all 23”, except for the driver’s side front which was 22.75”.)
My 4Runner is a V8.
Old 09-26-2020, 11:16 PM #60
Trekburt Trekburt is offline
Trekburt is on a distinguished road
Originally Posted by ads2539 View Post
Another update:
My 4Runner is a V8.
What notch did you put your front 5100s at? I am about to put Toytec springs over my Bilsteins. Do you like how it looks and rides?
Sent from my Pixel 3 XL using Tapatalk
Trekburt is offline   Reply With QuoteReply With Quote
36" Ride Height is 2" lift? Greydog Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-08-2013 08:27 PM
rear ride height after lift Aquatic Escape Classic T4Rs 2 04-17-2012 02:35 AM
Limited owners with ride height adj. Lift question ToyotaTrailTeam 4th Gen T4Rs 8 10-02-2010 09:47 PM
Ride Height praetorian 4th Gen T4Rs 3 10-23-2007 06:10 PM
Ride height of the 4th gen chunderboy 4th Gen T4Rs 3 02-11-2005 07:25 PM
