Originally Posted by Trekburt
What notch did you put your front 5100s at? I am about to put Toytec springs over my Bilsteins. Do you like how it looks and rides?
Sent from my Pixel 3 XL using Tapatalk
I bought the struts pre-assembled by Toytec at a 2.5” lift. I just went out to look, and I saw three rings on the shock bodies. I assume that means my shocks are at the lowest setting. I hope that’s the setting for the most lift, not the least!
I like how it looks. It’s not a huge difference from my Daystar 2.5/1.5 spacer setup, but the difference in the rear is noticeable because of my worn out old springs.
I haven’t driven on the new suspension yet, so I won’t know for a while. I went with the 5100s because I don’t do enough off-roading to justify the 6112/5160s. I’m also going to install higher caster UCAs, put the front sway bar back on, and get an alignment done before I drive it.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
