Old 06-24-2013, 12:12 PM #1
jmm3807 jmm3807 is offline
jmm3807 is on a distinguished road
Strut Mount Tightening
So I have a strut mount that has came
loose. I'm just not sure why it has to be totally replaced and can't be tightened. I've attached a picture for opinions. I'm no mechanic or anything just wanted some input.
Bad Mount
Good Mount
jmm3807 is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 12:20 PM #2
cabowally cabowally is offline
cabowally is on a distinguished road
Single nut on top needs to be tightened to: Torque: 25 Nm (260 kgf-cm, 18 ft-lbf)
3 nuts on the upper side of the front shock absorber with coil spring: Torque: 64 Nm (650 kgf-cm, 47 ft-lbf)
cabowally is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 12:21 PM #3
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
It can't be tightened down because the nut is out of thread. Whatever you do, don't take that nut off. You need to compress the spring and reassemble the assembly with the proper bushings
zopperman is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 12:22 PM #4
So I should go buy a wrench set and try to tighten it?
Old 06-24-2013, 12:24 PM #5
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
no, bcause it's not going to work. the shock is gonna spin in place... because the nut is out of thread...
i had the same thing happen to mine...
does that washer jingle around when you drive?
Old 06-24-2013, 12:25 PM #6
Sorry didn't see the last reply. So basically a spring compressor and someone with the know how plus a replacement strut mount kit and I should be alright.
Old 06-24-2013, 12:28 PM #7
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
no worries. you may need bushings or seats, not sure exactly what is bad. check out a youtube video of how to assemble a coilover. You could try to tighten it down, but i highly highly doubt it's just a loose top nut.
Old 06-24-2013, 12:46 PM #8
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
It looks to me like the inner (bottom) bushing is toast. You don't need a spring compressor either. Yes, it makes life easier but I wouldn't say it's the only way as long as you have the right tools. Follow this guide, it will work even though your not lifting:
OME Install - no spring compressor - Toyota 120 Platforms Forum
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 12:46 PM #9
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
yeah, i guess you don't need one, it just would make it way easier.
that method is cool, basically using the movement of the suspension with a floor jack to compress the spring while leaving the top of the assembly in place?
you can use a ratchet strap to compress the spring...
Old 06-24-2013, 01:08 PM #10
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
try to tighten the top nut. use one of those open ratchet wrenches and a channel lock to hold the top post. I just did this to mine.
LTDSC is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 01:10 PM #11
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
yeah in hindsight this is worth a shot. but don't be surprised if it just spins the shock like mine did...
Old 06-24-2013, 01:11 PM #12
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
i just did it to mine, hold the channel locks tight with the squared off top post. It cant spin if you hold it and then itll tighten that nut down. Although the threads match in both pics so looks like something else is the problem.
Old 06-24-2013, 04:39 PM #13
I'm just wondering if this is a strut mount or strut issue? The strut seems fine. I just don't understand how it happened. Is there a plate that holds the strut a certain way or something.
Old 06-24-2013, 04:41 PM #14
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
check out the exploded diagram i posted.
Shock is probably fine, just a hardware issue
Old 07-03-2013, 06:22 PM #15
It appears that whoever owned this 4runner before didn't have a clue. It had to have been doing this for a long time.
tightening the Ebrake cable? twitchee2 3rd gen T4Rs 11 11-05-2021 11:57 AM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
WTB: 3rd gen extended stud for strut mount t4r4life Want to Buy/Trade 2 09-01-2010 04:16 PM
Is tightening the driveshaft bolts necessary? kn38ms Maintenance/Detailing 1 04-18-2008 08:23 PM
Emergency Brake - tightening Up michael90630 4th Gen T4Rs 1 12-06-2007 12:42 AM
