06-30-2013, 11:48 AM
How to remove skid plate Nut in frame?
Do the dealer totally lunched a drill and tap for the DR bolt on the front skid plate. The hole is very oblong and a third of the nut is misisng, so tapping is not a great option,
Any ideas on how to get that captive nut out? There is an opening in the frame so it's possible to get a narrow tool in there, but it's a straight-in approach, no way to get any angle on it.
Torch it and chisel ?
I was thinking of replacing with one of those steel clips with nut on top.
Thanks for any suggestions.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
06-30-2013, 12:31 PM
Please post a pic or some pics. It’s hard to visualize w/o pics that drilling and over sizing is not the best option.
06-30-2013, 12:38 PM
I used a hammer and punch that just fit in the frame and broke the weld loose. Then put in a Rivnut.
2008 T4R Sport V8 4WD Titanium
1999 Shelby Series 1
06-30-2013, 05:52 PM
Really? How well is the RivNut holding up? I plan on doing the same thing when I order some new skidplates, since many of them use the existing bolt holes.
Also what size are you using? The largest I found were 8mm, though I'd like to bump them to 10mm if I could find some.
06-30-2013, 06:09 PM
I replaced all with stainless machine bolts (washers & lockwashers) the same size on all the skid plates. I enlarged the holes on the plates and had no problems through 6 oil changes now.
I got the rivet nuts from McMaster Carr.
07-01-2013, 08:29 AM
Since the hole is somewhat oblong due to the dealer drilling sideways it seems, I'm going to drill it out to a much larger hole and try to get the nut off.
If the nut is stubborn I'll try a Nutsert first, otherwise will try the RivNut.
Thanks guys.
09-06-2013, 01:10 PM
Mine is rattling and I accidentally knock out one of the lock nuts for the bolt. I am also interested in the RivNut. How is it holding up thus far?
2006 Shadow Mica 4Runner 4.7 V8 Sports Edition
3" OME Fronts with 885 Coils with Top plate spacer, 2" OME Rear 60020 Shocks with Toytec Light Superflex Coils, Total Chaos Uniball UCAs, 275/70/17 BFG AT KOs, Hoen Endurance yellow fogs
10-12-2013, 11:36 AM
I never repaired it, been debating on a skids. So finally ordered a Man A Fre front skid which bolts to the front of the forward stock skid and again at the rear of the back stock skid, so it skips those mid mount points.
