Old 12-25-2018, 05:39 PM #16
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Originally Posted by 0verland View Post
I've run a catch can on many other cars both boosted and N/A. All applications have proven to work in my case. I was just curious because I see all the applications for our rigs only on the 1GR, but nothing for the 2UZ.
Has anyone put one on the 2UZ? Pics would be nice to see for either.
Bump
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 12-25-2018, 09:08 PM #17
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Has anyone living in an area that requires emissions testing installed a catch can? If so, any issues passing?
Obviously you could just reinstall the stock setup for testing but unless I’m misunderstanding this, the engine should burn more cleanly if anything.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 01:00 PM #18
Jazz30-06 Jazz30-06 is offline
Jazz30-06 is on a distinguished road
Adding a can won't hurt emissions.
Originally Posted by ZebRuaj View Post
Sold the G35 and moved the catch can over into the 4Runner for kicks. Ebay unit with 3/8" fuel line from the auto parts store.
Mounted it on the driver side fender area.
Last picture is with 4 days of short driving, less than 80 miles. A lot of water condensation with some oil. Curious how much of the condensation is due to winter temps and my short drives. Will probably have to empty it out weekly at this rate.
6340
6342
IMG-20181201-110006
Have you compared the style you bought to the more typical ones like this?
https://www.amazon.com/EVIL-ENERGY-0...s%2C179&sr=8-6
I have been going back and forth on which I want to go with. Also, have you had any issues with the mount on yours?
Jazz30-06 is offline   Reply With QuoteReply With Quote
Old 05-02-2019, 03:59 PM #19
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
The key is getting 1 that has built in baffles of some sort. The mounts are flimsy. Twist it with too much hand torque, and they bend.
For our 4.0's, you also want one with the biggest capacity you can fit in. I ended up taking mine off for this reason. It was 3/4 full with a week of driving. Was turning into a weekly emptying so it wouldn't back flow into the intake. Wasn't so much of a problem of seeing blow by in the can, was more of condensation for me.
I became paranoid every time the wife or someone else drove the rig and I'd worry if the catch can was emptied 1st or not. Figure the 4.0 made it this far before I threw one on. It can go much further with me taking it back off.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 07:16 PM #20
Wow, that's an absurd amount of water. That would help explain why the oil cap always has a milkshake on the bottom of it even though I don't burn coolant or anything like that. I always just assumed it was because the neck was so long. I have a can on-hand now but have been waiting to install it because the holes on mine were drilled and tapped too deep. Now that I know that it fills that fast, I'm not sure I want to install it either. Where do you live that has that high of humidity, if you don't mind me asking?
Old 05-21-2019, 08:24 AM #21
ZebRuaj's Avatar
ZebRuaj's Avatar
Wasn't humidity for me, was MN winters and condensation.
Old 10-25-2020, 11:09 AM #22
teenee51 teenee51 is offline
teenee51 is on a distinguished road
The primary purpose of the "catch can" is to prevent intake valve deposit buildup. This is most frequently a problem with direct injection (post intake valve) engines. The 4th & 5th generation 1GR-FE (and others) have a "sequential fuel injection system" that injects prior to the intake valves. Gasoline is a great solvent. Unless someone can prove there is a intake valve deposit issue with these engines, it seems that a catch can are more prone to problems (frozen condensation for one) then being a solution. Also, if there was a crankcase vent issue, why does my PCV valve and throttle body have almost no deposits after 90K?
teenee51 is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 07:56 PM #23
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
Yes they do work...after 5k miles....why is there so much blow by?
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 08:09 PM #24
toyoman25's Avatar
toyoman25's Avatar
5k miles
Sent from my SM-N975U using Tapatalk
2005 4th gen upkeep and catch up Black4thgen05 4th Gen T4Rs 5 08-01-2012 03:40 AM
4 runner ever catch on fire? goodlooking4runner General Discussions 13 01-06-2012 10:42 PM
4 runner ever catch on fire? goodlooking4runner 4th Gen T4Rs 10 01-03-2012 03:12 PM
How to install windshield catch kit?? Help! jsulen 3rd gen T4Rs 6 02-09-2011 12:51 PM
Catch all mats Rayh78 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-16-2003 12:19 PM
