07-01-2013, 10:49 PM
Parking Brake Adjustment advice?
I've been 5 years without a decent parking brake, wouldn't hold whatsoever. It was brake time anyway so I just installed new rotors in the rear, new pads and new parking brake shoes.
Adjusted the parking brake per the Toyota procedure (tighten via the screwdriver/adjuster hole in the rotor) 'til it holds, then back off a bit 'til wheel spins freely. Well, it didn't do much, pedal still easily went to the floor. So I took out the center console and adjusted the cable. Pedal is much more stiff now and seems within the 5-7 click specs or so ... but it just seems to me that the brake is still very weak.
i.e. If I put the truck in gear it just rolls away with the brake on, I would think the parking brake should be able to hold at idle no? Anybody else with a V-8 can test theirs and let me know?
---'03 4Runner LTD V-8 | XREAS + Daystar 2.5/1.25 on stock coils | Michelin LTX AT2 P265/70/17, PIAA 510 ATP | AirLift 1000 | SpiderTrax
---'94 4Runner 4WD 3.slow - 215K mi. and still runnin' strong.
07-01-2013, 10:57 PM
Real Name: Bill
Real Name: Bill
The parking brake on my 2003 may as well not been there for all the good it did.
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
07-01-2013, 11:19 PM
If I put mine in gear, it would go with it on. I have tested it on a big hill, in neutral, and it held just fine, meaning it wouldn't budge at all.
2005 4runner
2004 corvette
07-01-2013, 11:21 PM
I just had mine adjusted at the dealer, it's so strong that I really have to give it some gas if I want to move with it engaged.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
07-01-2013, 11:26 PM
Just adjust them out a hair further ( the shoes that is ) if they are too tight they will just wear in
07-01-2013, 11:29 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
do you have to adjust from under the center console by the shifter at all? or is it literally just tighten the screw in the hole on the rotor?
07-01-2013, 11:36 PM
Just the adjuster inside the "drum"
07-01-2013, 11:37 PM
Unless they are all the way adjusted and you still can't get it to hold, then maybe the cables were stretched and you would have to adjust the cables. Not very common though
07-03-2013, 01:28 AM
Thanks guys. I'll try just adjusting at the rotor a bit more. Tested a bit ago on a slight incline / driveway and it didn't hold much at all. I have the center console apart and nuts adjusted as far as they can go with the cable. I checked all cables and everything seems fine, would sure like to have at least some parking brake. Only thing I haven't replaced is the cables themselves, but they look good as new to me.... On a ~10deg driveway I'd think the truck shouldn't roll any.
07-03-2013, 07:54 AM
Here's what I did:
I pulled the rear brake calipers off, and removed the drums. This will allow you to spray everything with brake cleaner and clean up the inside of the drums and visually inspect everything. It only takes 30 minutes to do both sides.
Then you can very easily adjust the shoes until the drums fit snug going back on. Like Lobsta said...they'll wear in.
Then bolt everything back up and it works great for a long time to come. No adjustment needed to the cables (in most cases).
If you want, everytime you do your tire rotation you can follow this method while the rear tires are off.
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
07-03-2013, 11:34 AM
i've never noticed the park brake ever holding the vehicle since i bought it new in 2004... i did ask the dealer to adjust it when i was getting the cat replaced under warranty but didn't notice any change after they did. you have a link to the doc showing how to adjust the cable in the center console?
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
07-03-2013, 01:49 PM
My 2003 parking brake is a joke. I've never tested it on a hill, but I normally put it all the way to the floor (way more clicks than 5-7) when I have my car on jacks and one time I forgot to release it when I drove it around the block. I couldn't even feel the brake on until I noticed the dash light was on.
I need to adjust it, but many other higher priority projects on the agenda.
07-03-2013, 02:20 PM
Sure, here's pics from the service manual. You have to remove the whole center console to get in there and be able to get wrenches on the adjustment screws, but it doesn't take that long..... Plus you get to find all your spilled coins and French fries once removed
10-23-2017, 12:57 PM
This might help. I just made a video for adjusting the P brake
https://youtu.be/6YctXVZB8_E
2006 Sport v6 4x4
Videography | Photography | Guitar | Drums | Rollerblading | Road tripping | T4R
10-23-2017, 04:40 PM
Someone else mentioned removing the caliper -- if you don't want to do this for whatever reason, use a C-clamp or large screwdriver to compress both calipers, allowing the wheel to spin freely.
My parking brake was pretty useless as well -- I don't think it was ever adjusted since new. When I adjusted mine, I turned the clickwheel just until I could not spin the drum/rotor with my hand. Then I backed it off one click at a time, I think it was 3-4 clicks, until it spun with no "drag" noise. Set & release the brake and give it another spin to make sure. Repeat for the other side.
I did this about a month ago and the brake is working quite well. My driveway is on a rather steep incline and there have been no complaints.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
