07-02-2013, 04:07 PM
was T Boned..vsc abs lights now on
was t boned today, the impact bent my passenger front tire...got a tow truck, lifted the front wheels, started the car,put it in 2wd, put it in neutral t owed it to the mechanic, about 4miles away..about 3miles into the trip the abs,vsc and another light came up on the dash...am worried..did i mess up truck?
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
07-02-2013, 04:36 PM
Probably just a sensor was broken, what kind of car hit you?
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
07-02-2013, 04:59 PM
Real Name: Alex
Real Name: Alex
Glad you're ok, Could've definitely been worse. Might be a sensor that got whacked outta place. Damage doesn't look to bad
06' Sport Edition
07-02-2013, 05:03 PM
Real Name: Ryan
Real Name: Ryan
I'd say definitely an ABS sensor or something like that judging by your wheel being bent that bad.
If only you had Xwing sliders like Demello has on his 4Runner!
X-wings meets Acura - Toyota 120 Platforms Forum
2007 Toyota 4Runner Limited V8 4x4
|Goodyear Duratrac 275/65R18|Daystar 2.5F RAS Adjusted Rear|1.25" Spidertrax|BM Chop|WeatherTech Floor Liners|28% Tint|LED Interior/Exterior Swap|4300k HID's|"Black Series" Projector Lenses|Jet Yellow Fogs|Pioneer AVH-P8400BH|Airaid Synthamax|HCF Delete|
07-02-2013, 09:33 PM
Not to sound mean or anything... but yeah... if those lights weren't on I'd be surprised.
You probably didn't do any more damage than you already had done by the accident, the system just threw DTCs for issues already present that will be fixed by the shop, so don't worry about it. Just make sure you get everything checked out properly and fix what needs to be fixed.
My guess, you're looking at maybe;
-Spindle and hub
-Upper and/or Lower Control Arms (Balljoints included)
-Steering Rack (assuming the tie rod didn't bend/snap and imparted force to the steering rack)
-Axleshaft
-Sway Bar Link
-Brackets for the Front Diff (unlikely, but the front diff might have been shifted over slightly)
-ABS Wheel Speed Sensor & Wiring
-Possibly the brake line on that side
-Fender Flare
-Door Body Paneling
-Possibly a new door or some sheet metal work
-Sheetmetal work (obviously)
-Running board (if you want them still, have them check the running board mounts to the body, they more than likely pushed into the body during the impact)
-Strut/Shock Assembly
-ect
Just have the truck scrutinized with a magnifying glass and have the Insurance company cover the damages, many times small things come back in a big way after an accident. You want to catch even the smallest issue now before it becomes a bigger problem later down the road.
07-03-2013, 12:44 AM
Real Name: Allen
Real Name: Allen
-Spindle and hub
-Axleshaft
-Sway Bar Link
-Fender Flare
-Door Body Paneling
-ect
From what I can tell, it looks like it was a really low car. If I were him, I would also check to be sure the frame wasn't tweaked. A car sliding under a truck can cause some terrible damages underneath that you won't be about to see.
2003 Toyota 4Runner SR5 iForce 4.7L V8 2WD Natural White With Plastic Bumper Cladding, Everything Completely Stock.
Owned since 10/3/11
90,000 Miles and counting!
07-03-2013, 12:49 AM
Real Name: Sam
Real Name: Sam
id have it totaled and start over. I would not want that back.
07-03-2013, 12:50 AM
lights probably came on because the PCM was actively reading wheel speed and noticed a discrepancy between the front two wheels up on the dolly and the rear wheels moving at tow truck speed. It decided the sensors were out of range and disabled VCS/ABS as a result.
frame looks OK. running board seems to have taken most of the impact.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
07-03-2013, 06:40 AM
thanks guys for kind words.....yeah, nobody was hurt, the car was going at about 40 to 50mph... while i was doing about 8-10mph, i accelarted hard when i saw him secs b4 impact [the other car said he didnt see me at all] witnesses say the impact was like an explosion/gunshot,
from initial analysis, the mechanic says the spindle and lower control arms are probablly going to be changed out....the struts appear ok.
will have a better idea of all the bad parts later today.
07-03-2013, 09:43 AM
To me, that looks really bad. I would be concerned about stuff you can't see with the eye. A shock load like that to the front suspension has got to be hard on joints and alignment and steering rack seals and CV shafts and everything else. Mounts are probably bent and bushings are probably shot.
Having said that, my 4R was involved in an identical accident before I purchased it...and other than the fender and door being a different shade of grey (the painter who did this sucked at his job apparently) you can't tell it ever happened. Mine drives straight as an arrow and has zero vibration or issues. So they can be fixed right....if you go somewhere that has competent mechanics.
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
