Old 07-03-2013, 11:55 PM #1
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Gauge backlight issue
Tonight was the first time driving it since the big service with the CDL replacement. I use the auto headlight feature and the headlights turned on but the backlight behind my gauges and the controls didnt. It was still somewhat light out so i thought maybe the lights hadnt turned on. Until i realized the headlights were on so why wasnt my backlight working?
Is there a fuse i can check? Maybe something blew when he did the service? Any help? If not im bringing it back Friday when they open and ask them to look at it.
LTDSC is offline   Reply With QuoteReply With Quote
Old 07-03-2013, 11:58 PM #2
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Check your dimmer switch?
zopperman is offline   Reply With QuoteReply With Quote
Old 07-04-2013, 12:01 AM #3
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
it was fully up. They just wouldnt kick on, and the gauge indicators were still bright red so i knew it hadnt even kicked on.
Old 07-04-2013, 12:03 AM #4
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
try TAIL fuse, red 10 amp
Old 07-04-2013, 12:06 AM #5
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
If the dimmer switch blew, it would cause this. So if all your fuses are okay, I would look into that.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 07-04-2013, 12:07 AM #6
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
ill check it all tomorrow, its dark and still 100* out. Way too hot to be out and fighting with a fuse. I hope its a simple fuse.
If its not the fuse im going to take it to the dealer just to try to get the dimmer switch replaced no charge as it worked before he replaced the actuator.
I know it has nothing to do with it but it worked fine until then.
Old 07-04-2013, 12:10 AM #7
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
well, the CDL switch is right by the dimmer so maybe they f'd it up some how? Do your HVACs have backlight? prob not the fuse if they do
Old 07-04-2013, 12:15 AM #8
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
Nothing has back light. I went out and checked, TAILS fuse was blown and i replaced and it still doesnt work. Also checked dome as well. Others were fine. Dimmer switch works to turn up/down the brightness of the pointers.
Old 07-04-2013, 12:16 AM #9
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
hmmm sounds like a short?
Old 07-04-2013, 12:17 AM #10
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
awesome, not what i wanted to hear. Ill have to take it in and play up the "it worked before" card and see where it gets me.
Not what i wanted at all.
Old 07-04-2013, 12:27 AM #11
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
did the fuse blow again?
Old 07-04-2013, 12:35 AM #12
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
no, was still good.
Old 07-04-2013, 01:04 PM #13
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
ok checked things this morning. Its definitely my tail light fuse. Whenever i turn on the headlights it blows out. I went through about ten fuses to test as i unplugged the tails, heads, high, low, parking lights, fog lights. Whenever the headlight switch turns over from OFF, it instantly blows the tail fuse.
So what now?
Old 07-04-2013, 01:39 PM #14
NJshadow93's Avatar
NJshadow93's Avatar
It's probably that whole switch that's bad, it might be worth replacing that and seeing if that solves it. I think it's about $70 IIRC?
Old 07-04-2013, 01:41 PM #15
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
thats what i was thinking. I wonder if its even worth it to take to the dealer and have them look or just order and replace the switch myself.
$93 from rock auto for the Auto w/ fog switch. Crap.
Fuel Gauge issue. A.Wilson013 3rd gen T4Rs 24 01-20-2019 06:14 PM
Did I read about a fuel gauge inaccuracy issue...? yotaman75 3rd gen T4Rs 8 11-06-2012 10:33 PM
Gas Gauge Issue DirtDawg 3rd gen T4Rs 12 09-10-2011 12:15 AM
speedo, odo, fuel gauge issue badhabt Classic T4Rs 1 09-01-2011 01:16 PM
Temperature gauge issue leslie22 Problems & Warranty Issues 6 10-13-2010 11:27 PM
