07-05-2013, 11:36 PM
Real Name: Colin
Real Name: Colin
sluggercz's '05 Build Thread
How she look's now:
I'll try and keep this thread up to date as well as document each modification with pictures + a tutorial.
[Updated to include tools and parts used for each modification]
4Runner purchased 14th June, 2013:
1st modification, Plasti-dip'd Wheels:- Tools: Jack + stands, 21mm Socket wrench for lugs, torque wrench (should go to at least 90ft-lb)
Parts: Plasti-dip Spray(can be found at Lowe's, Home Depot, etc.), Index Cards and painter's tape.
- Jack one side up.
- Remove wheels and place index carts to prevent overspray, cover lugnuts with painters tape.
- (Not pictured) Spray light first coat, wait 30 min. Spray 4 more coats per wheel, waiting ~30 min. between each coat. Once done spraying last coat, immediately remove index cards and lug nuts and allow final coat to dry for ~40 minutes. Reattach wheels + move on to the other side.
- All done.
- Used about 2 cans of Plasti-dip for all 4 wheels.
2nd modification, Plasti-dip'd Grill:- Tools: 10mm Socket wrench
Parts: Plasti-dip spray, less than 1 can is needed.
- Unbolt front grill, use a 10mm socket. Should be 8 grey nuts that connect grill to hood, and 2 black bolts that connect hood latch to grill.
- (Not pictured) Follow same technique as painting the wheels, start with a light coat, wait 30min, then add 3-5 more coats.
- Re-install grill.
3rd modification, Badge removal:- Tools: Heat gun or blow-dryer, metal scraper or dental floss/fishing line.
Parts: Goo-gone (or other adhesive remover)
- To remove the badges I used a B&D Heat gun (though I'm sure a blowdryer would work just as well) and the metal scraper supplied in the kit.
- Set the heat-gun around Low-Med heat (~200 degrees Fahrenheit) and held it about a foot away.
- Angle the scraper to as near parallel to the side panel as possible to prevent any scratching.
- Use an adhesive remover if needed to get rid of any remaining gunk.
4th modification, Interior LED Swap + Auto-on Maplights:
Tools: 10mm Socket wrench, thin flathead screwdriver, crimper + wire stripper.
Parts: 4th Gen interior LED kit, 18AWG wire, Red wire tap connector, Blue Female+Male insulated quick disconnects.
Followed t4rman's "How to" on toyota120 forums.
Wired maplights to ILE circuit so they turn on when doors open/car unlocked, and dim after ~15 seconds. Followed JA's write-up, skipped using a switch though.- Maplights:
- Maplights + Driver side door light:
- Passenger side door light:
- Rear lights(secured LED boards with hot glue):
- Cargo area light:
- Full length shot:
- Night shot:
07-05-2013, 11:38 PM
Real Name: Colin
Real Name: Colin
Reason: Edited for clarity.
07-06-2013, 02:02 AM
This whole thread[liked]
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
07-06-2013, 03:08 AM
I love your 4runner man. Nice color looks mint condition.
07-06-2013, 07:49 AM
Keep up the quality work.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
07-06-2013, 09:33 PM
Real Name: Colin
Real Name: Colin
Washed and waxed this morning:
7th Modification, Additional 12V socket(for GPS):
Tools:10mm socket wrench, wire stripper + crimper.
Parts:12V Aux Power Socket(can find these at AutoZone/O'Reilly/etc.), Red Wire Tap Connector (22-16AWG), Red + Black 18AWG wire, 2 Red female quick disconnect terminals. - Remove lower panel dash panel and metal shield, each is secured by 2 10mm bolts:
- Remove rear center console to access the stock 12V power connector(has 2 wire's coming out: 1 red, 1 white with a black stripe):
- Use wire tap's to splice into the positive and negative wire's, then run cable behind the center console to area underneath the steering column:
- Crimp a female quick disconnect terminal onto the end of each wire. Then connect the positive to the center wing on the added socket, and the negative to the outermost wing:
- I ran the GPS cable behind the side stripping:
- Reattach center console, lower dash paneling. Turn car on and test to see if the new socket is powered:
Success! Now I can use both my GPS and radar detector.
07-08-2013, 05:59 AM
good mods!..ur truck looks gr8.......think the last remaining mod is blacked out projector retrofits...
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
07-10-2013, 02:29 PM
Real Name: Colin
Real Name: Colin
Yeah, hopefully should be done with the Retrofit by the end of this week. Blacking out the headlight housing as well.
07-10-2013, 02:40 PM
Real Name: Colin
Real Name: Colin
Bumper/headlights removal + Painting Headlight Housing Black
07-10-2013, 02:42 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Originally Posted by sluggercz
Painting headlight housing & BiXenon Retrofit:
Tools: Oven, 10mm Socket, Proxxon Rotary Tool FBS 115/E, Painter's tape
Parts: FX-R III Retrofit Kit, Aluminum Tape, JB KwikWeld, JB SteelStik, Clear Waterproof Silicone Caulking, Krylon Satin Black Spraypaint
References:- 2004 Toyota 4Runner HID retrofit
- Projector Retrofit - 2006 4Runner
- Rickashay's Projector Retrofit
Write-up:
(in progress - pictures to come)
Part 1: Painting the headlight housings and projector shrouds - Remove headlights from the vehicle, may have to remove front bumper to make it easier.
- Bake headlights in oven at 200deg. Fahrenheit for ~15 minutes.
- Remove light assembly from oven and use a thin flathead screwdriver to assist in prying the lens from the light assembly.
- Store the lens in a dust free environment.
- Unassemble the headlight.
Keep it coming! we could use a good retrofit write up
07-10-2013, 03:00 PM
Real Name: Name's not dude!
You've been busy! Looks great!
Terri
My Satoshi Grille Mod
2008 Sport - TOYOTA Raptor Grill - Toytec 3" Suspension Lift with Coilovers - Bilstein 5100 - Cooper Discover STT Pro -
Fuel Beast Wheels - 20% Tint - LED Interior - Remote Start
07-10-2013, 07:44 PM
Real Name: Colin
Real Name: Colin
Windows Tinted
07-10-2013, 11:52 PM
Real Name: Leonard
Real Name: Leonard
Looks great, just like new. Looks like you have been on a mod craze like I was during the winter.
Having fun's build
07-12-2013, 01:28 PM
Real Name: Colin
Real Name: Colin
Bilstein 5100/OME 885,895 Install
Bilstein 5100's/ OME 885,895 Install:
(Write up in progress)
Before:
After:
For the most part followed Photog's Write Up: "OME Install, No spring compressor". However, I found the OME 885's to be a bit too stiff to install when combined with the Bilsteins and had to resort to using the AutoZone Strut Spring Compressor.
Tools: 14mm, 17mm, 19mm, 21mm socket wrenches, Jack + stands, spring compressor (rented from AutoZone), LiquidWrench, Red LocTite
Parts: Bilstein 5100 Adjustable Front Shocks, Rear Shocks. ARB OME 885(Front) + 895(rear) coils.- Exploded view of Suspension w/Torque values, click for a larger image size (should help with visualization):
- Components:
- Stock front height: approx. 33"
- Stock rear height: approx. 35"
Write-up:- Will start on the front. Loosen lug nuts on front wheels. Jack up the car and place jack stands underneath frame on both sides - may need to use 2"x4"x4" pieces of wood to have enough ground clearance- remove wheels:
- Remove front skid plate:
- Remove sway bar starting with unbolting the sway links then unbolting sway bar brackets:
Sway bar link:
Sway bar brackets:
- Place floor jack underneath LCA and jack up:
Done with the install, here are the numbers for the new ride height(pictures to follow):
Front Right - Ground to top of wheel well:
Stock: 33" Now: 39"
Rear Right - Ground to top of wheel well:
Stock: 35" Now: 38.5"
As you can see, I now have a slight bro-rake - but hopefully the front will settle a 1/2" or more over the next month or two. If the front coils don't settle I'll probably get some top mount spacers with extended studs for the rear, most likely a 1/2" set.
07-12-2013, 02:48 PM
Real Name: Colin
Real Name: Colin
LED Footwell Lights
Going to tackle the LED footwell lights today.
I'm going to be using the STRIP_RL_12_W_6k LED panels from VLEDs.
Since I'm still waiting on the Cole Hersee switch I ordered, I will be wiring this into the ILE circuit (the same wire the maplight mod taps into) so the footwell lights come on when a door opens and so they automatically turn off as well.
I'm using J.A.'s 4Runner site as a reference, here's the link.
From J.A.'s site:
Negative terminal taps in here
Positive terminal taps in here
I'm using a small battery pack with alligator clips connected to test different placements for the footwell LEDs:
Done with the footwells!
They took longer than expected, mainly because I had to fabricate some angled T-mounts for the rear footwell areas; also, I had to deal with the flaps on the bottom back side of the Limited bucket seats - folded the bottom half of the flap back and up behind the top half.
I'll post some pictures soon, but for now I can tell you that it makes a load of difference at night - especially when you are stepping into/out of your newly lifted runner.
