Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-05-2013, 11:36 PM #1
sluggercz's Avatar
sluggercz sluggercz is offline
Real Name: Colin
sluggercz is on a distinguished road
sluggercz's Avatar
Real Name: Colin
sluggercz's '05 Build Thread
How she look's now:
I'll try and keep this thread up to date as well as document each modification with pictures + a tutorial.
[Updated to include tools and parts used for each modification]
4Runner purchased 14th June, 2013:
1st modification, Plasti-dip'd Wheels:
  1. Tools: Jack + stands, 21mm Socket wrench for lugs, torque wrench (should go to at least 90ft-lb)
    Parts: Plasti-dip Spray(can be found at Lowe's, Home Depot, etc.), Index Cards and painter's tape.
  2. Jack one side up.
  3. Remove wheels and place index carts to prevent overspray, cover lugnuts with painters tape.
  4. (Not pictured) Spray light first coat, wait 30 min. Spray 4 more coats per wheel, waiting ~30 min. between each coat. Once done spraying last coat, immediately remove index cards and lug nuts and allow final coat to dry for ~40 minutes. Reattach wheels + move on to the other side.
  5. All done.
  6. Used about 2 cans of Plasti-dip for all 4 wheels.
2nd modification, Plasti-dip'd Grill:
  1. Tools: 10mm Socket wrench
    Parts: Plasti-dip spray, less than 1 can is needed.
  2. Unbolt front grill, use a 10mm socket. Should be 8 grey nuts that connect grill to hood, and 2 black bolts that connect hood latch to grill.
  3. (Not pictured) Follow same technique as painting the wheels, start with a light coat, wait 30min, then add 3-5 more coats.
  4. Re-install grill.
3rd modification, Badge removal:
  1. Tools: Heat gun or blow-dryer, metal scraper or dental floss/fishing line.
    Parts: Goo-gone (or other adhesive remover)
  2. To remove the badges I used a B&D Heat gun (though I'm sure a blowdryer would work just as well) and the metal scraper supplied in the kit.
  3. Set the heat-gun around Low-Med heat (~200 degrees Fahrenheit) and held it about a foot away.
  4. Angle the scraper to as near parallel to the side panel as possible to prevent any scratching.
  5. Use an adhesive remover if needed to get rid of any remaining gunk.
4th modification, Interior LED Swap + Auto-on Maplights:
Tools: 10mm Socket wrench, thin flathead screwdriver, crimper + wire stripper.
Parts: 4th Gen interior LED kit, 18AWG wire, Red wire tap connector, Blue Female+Male insulated quick disconnects.
Followed t4rman's "How to" on toyota120 forums.
Wired maplights to ILE circuit so they turn on when doors open/car unlocked, and dim after ~15 seconds. Followed JA's write-up, skipped using a switch though.
  • Maplights:
  • Maplights + Driver side door light:
  • Passenger side door light:
  • Rear lights(secured LED boards with hot glue):
  • Cargo area light:
  • Full length shot:
  • Night shot:
sluggercz is offline   Reply With QuoteReply With Quote
Old 07-05-2013, 11:38 PM #2
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
5th modification, LED Tail light swap:
Followed CookieRoe's Install Guide
Tools: 10mm Socket wrench, 10mm wrench
Parts: 81551-35320, 81561-35280
  • Close up:
  • Brakes pressed:
  • Brakes not pressed:
  • LED Tails + License Plate lights:
Old 07-06-2013, 02:02 AM #3
awdjunkies's Avatar
awdjunkies awdjunkies is offline
awdjunkies is on a distinguished road
awdjunkies's Avatar
This whole thread[liked]
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
awdjunkies is offline   Reply With QuoteReply With Quote
Old 07-06-2013, 03:08 AM #4
longobongo longobongo is offline
longobongo is on a distinguished road
I love your 4runner man. Nice color looks mint condition.
longobongo is offline   Reply With QuoteReply With Quote
Old 07-06-2013, 07:49 AM #5
ebg18t ebg18t is offline
ebg18t is on a distinguished road
Keep up the quality work.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 07-06-2013, 09:33 PM #6
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
Washed and waxed this morning:
7th Modification, Additional 12V socket(for GPS):
Tools:10mm socket wrench, wire stripper + crimper.
Parts:12V Aux Power Socket(can find these at AutoZone/O'Reilly/etc.), Red Wire Tap Connector (22-16AWG), Red + Black 18AWG wire, 2 Red female quick disconnect terminals.
  1. Remove lower panel dash panel and metal shield, each is secured by 2 10mm bolts:
  2. Remove rear center console to access the stock 12V power connector(has 2 wire's coming out: 1 red, 1 white with a black stripe):
  3. Use wire tap's to splice into the positive and negative wire's, then run cable behind the center console to area underneath the steering column:
  4. Crimp a female quick disconnect terminal onto the end of each wire. Then connect the positive to the center wing on the added socket, and the negative to the outermost wing:
  5. I ran the GPS cable behind the side stripping:
  6. Reattach center console, lower dash paneling. Turn car on and test to see if the new socket is powered:
    Success! Now I can use both my GPS and radar detector.
Old 07-08-2013, 05:59 AM #7
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
good mods!..ur truck looks gr8.......think the last remaining mod is blacked out projector retrofits...
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 07-10-2013, 02:29 PM #8
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
Yeah, hopefully should be done with the Retrofit by the end of this week. Blacking out the headlight housing as well.
Old 07-10-2013, 02:40 PM #9
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
Bumper/headlights removal + Painting Headlight Housing Black
Tools: Oven, 10mm Socket, Painter's tape
Parts: Krylon Satin Black Spraypaint
Write-up:
Part 1: Removing bumper and headlight assembly
  1. Remove the radiator shield, secured by 8 clips.
  2. Disconnect fog light cables.
  3. Remove front bumper, 6 clips and 6 claws on top. 8 bolts underneath.
  4. Disconnect High, Low, and Side lights.
  5. Remove 2 top bolts, 1 inside bolt and 1 bolt on outside. Top and inside are grey, outside is black.
Part 2: Painting the headlight housings and projector shrouds
  1. Remove all screws and rubber grommets from back of the headlights:
  2. Bake headlights in oven at 200deg. Fahrenheit for ~15 minutes.
  3. Remove light assembly from oven and use a thin flathead screwdriver to assist in prying the lens from the light assembly.
  4. Store the lens in a dust free environment.
  5. Remove amber reflector and diffuser for side light.
  6. Prep light shroud by cleaning with alcohol and masking side light area.
  7. Paint by spraying around 2-4 light coats, waiting ~5minutes between coats. Should take an hour to dry.
Old 07-10-2013, 02:42 PM #10
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Originally Posted by sluggercz View Post
Painting headlight housing & BiXenon Retrofit:
Tools: Oven, 10mm Socket, Proxxon Rotary Tool FBS 115/E, Painter's tape
Parts: FX-R III Retrofit Kit, Aluminum Tape, JB KwikWeld, JB SteelStik, Clear Waterproof Silicone Caulking, Krylon Satin Black Spraypaint
References:
  1. 2004 Toyota 4Runner HID retrofit
  2. Projector Retrofit - 2006 4Runner
  3. Rickashay's Projector Retrofit
Write-up:
(in progress - pictures to come)
Part 1: Painting the headlight housings and projector shrouds
  1. Remove headlights from the vehicle, may have to remove front bumper to make it easier.
  5. Unassemble the headlight.
Keep it coming! we could use a good retrofit write up
zopperman is offline   Reply With QuoteReply With Quote
Old 07-10-2013, 03:00 PM #11
Mytoy4's Avatar
Mytoy4 Mytoy4 is offline
Real Name: Name's not dude!
Mytoy4 will become famous soon enough
Mytoy4's Avatar
You've been busy! Looks great!
Terri
My Satoshi Grille Mod
2008 Sport - TOYOTA Raptor Grill - Toytec 3" Suspension Lift with Coilovers - Bilstein 5100 - Cooper Discover STT Pro -
Fuel Beast Wheels - 20% Tint - LED Interior - Remote Start
Mytoy4 is offline   Reply With QuoteReply With Quote
Old 07-10-2013, 07:44 PM #12
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
Windows Tinted
Got all the windows tinted with 3M FX 15%:
Old 07-10-2013, 11:52 PM #13
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Looks great, just like new. Looks like you have been on a mod craze like I was during the winter.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 07-12-2013, 01:28 PM #14
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
Bilstein 5100/OME 885,895 Install
Bilstein 5100's/ OME 885,895 Install:
(Write up in progress)
Before:
After:
For the most part followed Photog's Write Up: "OME Install, No spring compressor". However, I found the OME 885's to be a bit too stiff to install when combined with the Bilsteins and had to resort to using the AutoZone Strut Spring Compressor.
Tools: 14mm, 17mm, 19mm, 21mm socket wrenches, Jack + stands, spring compressor (rented from AutoZone), LiquidWrench, Red LocTite
Parts: Bilstein 5100 Adjustable Front Shocks, Rear Shocks. ARB OME 885(Front) + 895(rear) coils.
  • Exploded view of Suspension w/Torque values, click for a larger image size (should help with visualization):
  • Components:
  • Stock front height: approx. 33"
  • Stock rear height: approx. 35"
Write-up:
  1. Will start on the front. Loosen lug nuts on front wheels. Jack up the car and place jack stands underneath frame on both sides - may need to use 2"x4"x4" pieces of wood to have enough ground clearance- remove wheels:
  2. Remove front skid plate:
  3. Remove sway bar starting with unbolting the sway links then unbolting sway bar brackets:
    Sway bar link:
    Sway bar brackets:
  4. Place floor jack underneath LCA and jack up:
Done with the install, here are the numbers for the new ride height(pictures to follow):
Front Right - Ground to top of wheel well:
Stock: 33" Now: 39"
Rear Right - Ground to top of wheel well:
Stock: 35" Now: 38.5"
As you can see, I now have a slight bro-rake - but hopefully the front will settle a 1/2" or more over the next month or two. If the front coils don't settle I'll probably get some top mount spacers with extended studs for the rear, most likely a 1/2" set.
Old 07-12-2013, 02:48 PM #15
sluggercz's Avatar
Real Name: Colin
sluggercz's Avatar
Real Name: Colin
LED Footwell Lights
Going to tackle the LED footwell lights today.
I'm going to be using the STRIP_RL_12_W_6k LED panels from VLEDs.
Since I'm still waiting on the Cole Hersee switch I ordered, I will be wiring this into the ILE circuit (the same wire the maplight mod taps into) so the footwell lights come on when a door opens and so they automatically turn off as well.
I'm using J.A.'s 4Runner site as a reference, here's the link.
From J.A.'s site:
Negative terminal taps in here
Positive terminal taps in here
I'm using a small battery pack with alligator clips connected to test different placements for the footwell LEDs:
Done with the footwells!
They took longer than expected, mainly because I had to fabricate some angled T-mounts for the rear footwell areas; also, I had to deal with the flaps on the bottom back side of the Limited bucket seats - folded the bottom half of the flap back and up behind the top half.
I'll post some pictures soon, but for now I can tell you that it makes a load of difference at night - especially when you are stepping into/out of your newly lifted runner.
badge removal , build thread , led lights , modification , plasti dip
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
Sam's Build Thread... I AM SAM 5th gen T4Rs 87 11-13-2012 08:51 PM
My build thread Kirby Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-08-2007 11:02 PM
