PIFFF! Service Port!? What the hell do you need one of those for!
Joking aside, Toyota doesn't seem to put service ports on our fuel rails usually; I have no real clue why... BUT, if you need to hook a gauge inline, test fuel pressure, and/or run some injector cleaner through the vehicle the feed and return lines are quick disconnects located near the brake master cylinder, just remember to pull the fuel pump fuse when you have them disconnected and to block off the return if you're trying to run injector cleaner through the vehicle.
