11-27-2005, 02:02 AM
Has anyone ever found a loose propeller shaft bolt?
After 13,000 miles my propeller shaft bolts aren't even close to coming loose. I applied the specified torque (and then some) but didn't budge them. I'm wondering... Has anyone ever found a propeller shaft bolt that needed torquing?
2004 Pacific Blue SR5 4WD V8
11-27-2005, 01:34 PM
Re: Re: Has anyone ever found a loose propeller shaft bolt?
Originally posted by Hitman
Were you expecting them to come loose?
If so, why?
If they are properly torqued from the beginning, they should never loosen on their own. I guess it couldn't hurt to check, though...
Because the manual states to tighten them periodically!
So I'm curious too - this ever happen to anyone?
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
11-27-2005, 01:41 PM
I've had mine checked a couple of times over the last 60,000 miles. Never loose. I tow trailers sometimes, and off road all the time.
What I did do which helped though, was to really grease the drive shaft slip joints. Until I took the time to really pump & pump Amsoil grease into the joint, I could feel the characteristic pop at a stop. I pumped until I could see the blue grease emerge from the other end of the joint. Flawless operation since then.
RL
Dallas, Texas
2004 4Runner Sport Edition
11-27-2005, 01:44 PM
Yes - ditto on greasing it up & getting rid of the noise "pop." Wonder why they designed it like that!?
11-27-2005, 05:19 PM
I have never checked them and I never will.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
11-27-2005, 05:23 PM
Man, I don't know . . .something may fall off.
11-27-2005, 07:54 PM
Why are you so confident they don't need checking?
11-27-2005, 08:40 PM
what is this guy talking about? is he saiding if you pump the slip joint full of grease till it come out the other end of the drive shift it will get rid of that F%^&ing clunking noise when you take off after a complete stop on the drive shift?
2004Runner SE 4WD
Natural White
________________________________________
Factory Option:Sunroof,Valor Tip,Double Deck Cargo,Rear Spoiler,DRL,Electrochromatic Mirror,Leather
Mods:Limited Sliver RB,OEM All Weather Mats,(F)Stainless Steel Door Sill,TRD Badge,20% Tint,SuperBrightLeds.com(6)White LEDs: Dome/License/Doors/& Map Light,Custom TRD License Plate Frame,Alpine IVA D900,7"VizuaLogic ADV. LC Headrest Monitor,Escort 8500 X50 w/ Custom Mounted Smart Cord,115v switch w/ X-Power 150W Inverter,G2 Sliver Painted Caliper,REVO 265/70/17,Rear Parking Light Mod,PAC SWI-ALP,OBX Sport Pedal,Ashtray&Lighter Kit,06 LEDs Taillight,55w yellow Foglight bulbs, McCulloch 6000k HID headlight
11-27-2005, 08:51 PM
Yes, it stops the clunck. It works. Just do it.
11-27-2005, 08:59 PM
Yes. For some reason the spline shaft / slip joint in the rear driveline is insufficiently greased at the factory. Instead of sliding smoothly, it makes an occasional abrupt lurch. It's that clunk sound you hear when you'd swear someone bumped you from behind. Adding 10-20 pumps of grease into the appropriate zerk fitting solves the problem.
Check out:
http://www.toyota-4runner.org/showth...highlight=zerk
11-27-2005, 09:20 PM
Check out:
SWEET!! I been away from T4R.ORG too long! Feel good to be back on line again!:awais:
2004Runner SE 4WD
Natural White
11-27-2005, 09:42 PM
It works like a champ. Just make sure you get to all the zerks. I use the waterproof Amsoil synthetic grease for these, and all other pivot joints.
RL
Dallas, Texas
11-28-2005, 12:08 AM
Can you use the waterproof amsoil grease you use for the u-joint and slip joint too?? or do you use a different grease for each?
2004Runner SE 4WD
Natural White
11-28-2005, 10:36 AM
Because with all the different vehicles that I have owned over the past 20 years, none of them had a loose U-joint bolt. This is my third 4x4 and I have driving them since 1988. However, I have worn out non-greasable U-joints.
11-28-2005, 10:48 AM
I grease the drive shaft slip joints and the Total Chaos Upper Control Arms on the 4Runner. I also use it for the pivot points on my motorcycles. All slow moving high friction joints.
As opposed to wheel bearing grease.
RL
Dallas, Texas
