Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-20-2013, 01:18 AM #1
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
4th Gen Helpful DIY Videos
Suspension:
Coilover Disassembly Without a Spring Compressor (Tacoma)
Adjusting Upper Control Arms (Tacoma/Tundra)
Rear Lower Control Arm Installation (FJ Cruiser)
Spacer Lift/Leveling Kit Installation
Engine:
V6 -
Spark Plug Installation
Mass Air Flow Sensor Cleaning (FJ Cruiser)
Oil Change
V8 -
Timing Belt Disassembly (Tundra)
Timing Belt Disassembly - Part 2(Tundra)
Timing Belt Disassembly - Part 3(Tundra)
AFE Air Filter Install (Same Method to Replace Air Filter
Both -
Homemade Snorkel (Land Cruiser)
Driveline:
V6 -
V8 -
Transmission Fluid and Filter Change - Part 1
Transmission Fluid and Filter Change - Part 2
Driveline Service
Wheel Spacer Install (Pickup)
Both -
Front Brake Replacement
4x4 Front Hub Assembly Replacement
Power Steering Rack Replacement - Part 1
Power Steering Rack Replacement - Part 2
Exterior:
Front Wheel Bearing Replacement
Rear Bumper Reflector Replacement
Rear Blinker Light Replacement
How to PlastiDip Front Emblems and Grille (Maxima)
Backup Camera Install - Part 1
Backup Camera Install - Part 2
Rear Quarter Window Replacement
Rola Roof Basket Install
Windshield Replacement
Interior:
Cabin Air Filter Change
HVAC Control Removal and LED Replacement
Door Panel Removal
Zero-point calibration
Map Lights Turn on with Open Doors
iPad Mini Dash Install
Door Panel Removal
Reset Maintenance Light
LED Map/Dome Light Install
Audio:
Stock Radio Removal
Speaker Replacement
"GTA Car Kits" AUX Input Install
Misc:
Myths About PlastiDip
In threads where a different car/truck is used, the process is pretty similar, if not the same, but make sure before trying, to check the possible differences in the processes.
Feel free to add to this list. I was just bored so I decided to browse YouTube to provide whatever help I can.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 07-20-2013, 01:23 AM #2
ghostridr's Avatar
ghostridr ghostridr is offline
ghostridr is on a distinguished road
ghostridr's Avatar
Some of these videos show FJs & Tacos, but same applies for 4runners.
Tacoma Coil Over Shock Disassembly without a Spring Compressor
Myths About Plasti Dip (Vol 1)
How To Plasti Dip Emblems and Front Grille - HD Step by Step - DipYourCar.com
Change rear blinker light on 4th gen 4Runner
Replace 2003-2005 Toyota 4Runner Rear Bumper Reflector , How To Change Install 2004 TO1184101
How To FJ Cruiser Rear Lower Control Arm install
25470 -25480- 25490 -Toyota Tacoma/Tundra Adjustable Front Upper Control Arms - Specialty Products Company
2006 SR5 V6 4WD Titanium : Toytec 2" Superflex Rear Springs / Toytec 1.6" Silver Coils - Bilstein 5100 All Around (Front set @ 1.75) - WeatherTech Digital Floormats - 6000K HID Swap - 6000K LED Interior Light Mod - Diff Mod - Husky D-Ring Shackle Hitch Mount - FJ TE 8-Hole Rims wrapped in BFG KM 255/75/17 Tires - Reverse Tail Light 6000K LED Light MOD - Custom'ish Rear End Links
ghostridr is offline   Reply With QuoteReply With Quote
Old 07-20-2013, 11:20 AM #3
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
I think the Eric the car guy videos on the silver 4th gen are V8, just FYI.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 07-20-2013, 03:39 PM #4
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
They're V6. On the Trans Fluid change it shows him doing a test drive and it's the 4spd trans.
-Helpful DIY Videos
Old 07-20-2013, 04:16 PM #5
WXman's Avatar
WXman WXman is offline
WXman is on a distinguished road
WXman's Avatar
So you have to drop the exhaust to do the trans fluid on the V6? ouch that sucks!
2004 Limited 4x4 - 4.7L - Dynomax VT muffler - Airbox mod - Bilstein 5100s front/Daystar spacers rear - Cooper Discoverer AT3 P265/70-17
WXman is offline   Reply With QuoteReply With Quote
Old 07-20-2013, 04:25 PM #6
NJshadow93's Avatar
NJshadow93's Avatar
You can see the V8 when he opens the hood. The only reason he dropped the exhaust is to change the filter I believe.
Old 07-20-2013, 04:37 PM #7
dgwood12's Avatar
dgwood12 dgwood12 is offline
Real Name: Dustin
dgwood12 is on a distinguished road
dgwood12's Avatar
Real Name: Dustin
I found this one for spark plug replacement on '06 V6 that you can include in the list as well. Essentially the same as the V8 but useful nontheless.
How to change spark plugs - Toyota 4Runner 2006 - YouTube
dgwood12 is offline   Reply With QuoteReply With Quote
Old 07-20-2013, 06:40 PM #8
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
Fixed Ericthecarguy's videos to v8... NJ you better be right
-Helpful DIY Videos
Old 07-21-2013, 12:18 AM #9
Rommel's Avatar
Rommel Rommel is offline
Rommel is on a distinguished road
Rommel's Avatar
Would that video by Eric also be applied to the V6 model as well?
Anyways, here is a video for the MAF cleaning.
How-to Clean Mass Air Flow Sensor
My Divemoblie 4runner
2005 Toyota 4runner V6 SR5
Rommel is offline   Reply With QuoteReply With Quote
Old 07-21-2013, 01:17 AM #10
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
Only the V6 2005+, as the '04 has a 4spd still.
-Helpful DIY Videos
Old 07-21-2013, 01:27 AM #11
NJshadow93's Avatar
NJshadow93's Avatar
Check out the transmission filter part 2 video, 15:35, you clearly see the V8 cover, just so you feel better good idea for the thread too, this could definitely help.
Old 07-21-2013, 11:36 AM #12
Gatafly Gatafly is offline
Gatafly is on a distinguished road
Good thread for people to keep adding videos to that they find.
Gatafly is offline   Reply With QuoteReply With Quote
Old 07-21-2013, 10:47 PM #13
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Great idea, @Stuck CAPS . Can you organize the first post by catergory and add all the vids that people are posting to post #1. Like maybe suspension, engine (then break that down into v6 and v8), driveline, body work, electrical
I dunno, just general stuff like that.
zopperman is offline   Reply With QuoteReply With Quote
Old 07-22-2013, 01:16 AM #14
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
Was thinking that, just was waiting for a few more vids.
Edit- Done.
-Helpful DIY Videos
Old 07-22-2013, 04:06 PM #15
ghostridr's Avatar
ghostridr's Avatar
This should be stickied!
Helpful UCA info jangoforhire 5th gen T4Rs 0 03-24-2012 11:00 PM
How helpful are tires? Spiggie 4th Gen T4Rs 7 05-07-2011 12:29 AM
Any information would be helpful 93runnnerguy Classic T4Rs 7 09-13-2010 09:37 PM
What state? What helpful skills do you have? diamondplate General Discussions 15 09-11-2010 03:55 PM
