Old 02-16-2014, 07:45 PM #31
c_mack9's Avatar
c_mack9 c_mack9 is offline
c_mack9 is on a distinguished road
c_mack9's Avatar
I have a v6 with part time 4wd. When I put it into 4hi I have 4wd but the 4wd and the center diff lock lights flash. Everything seemed to be working normally except for the lights. I was on a little back road today driving slow in 4hi and out of nowhere my front wheels locked up and I slid to a stop. I finally got it unhung and back to 2wd to get it home, but if the lights are flashing don't mess with it. If that would have happened on the interstate I could have been killed.
c_mack9 is offline   Reply With QuoteReply With Quote
Old 12-03-2018, 01:51 AM #32
Jean Grey's Avatar
Jean Grey Jean Grey is offline
Jean Grey is on a distinguished road
Jean Grey's Avatar
4wd doesn't work
Hello, I just got a 2003 v8 limited and the found out the 4wd doesn't engage. Can anybody point me to the right thread on how to solve this problem?
Jean Grey is offline   Reply With QuoteReply With Quote
Old 12-03-2018, 11:54 AM #33
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
What's not engaging? The center diff lock? 4lo? The V8 is full time 4wd.
eleven14 is offline   Reply With QuoteReply With Quote
Old 12-05-2018, 10:28 PM #34
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
Chances are that your actuator is bad
On the v8 it's a pretty in-depth job and $ of actuator itself is expensive
Best of luck
Sent from my E6810 using Tapatalk
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 12:33 PM #35
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
So did somebody come up with the solution to this issue?
Lost 4wd last month, and a buddy has the same issue.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 03:56 PM #36
Jean Grey's Avatar
Jean Grey's Avatar
thank you, any way to get around this?
Old 11-12-2019, 04:00 PM #37
Jean Grey's Avatar
Jean Grey's Avatar
it full time 4wd v8 model, yet I bought it from a guy who didn't tell me it is only working in 2wd, so it must be the actuator. you have to take out transfer case to replace it. The other models are easy to replace the motor. This one has clips on the actuator rods. So I am not in the mkt for dropping the t-case. might be out of luck unless I can tap on it or something?
Old 11-12-2019, 06:46 PM #38
Since mine is the v8 also with full.time 4wd
I installed a switch to trick the computer into thinking its locked
That in turn turns off the vsc trac
Too.much $$$ to fix
Best of luck
Sent from my SM-G950U using Tapatalk
Old 11-29-2019, 04:38 PM #39
Perl T4R Perl T4R is offline
Perl T4R is on a distinguished road
My '05 V6 T4R is being a real *****, could use some assistance and you seem to have helpful advice. Got stuck in 4Lo, the 4wd light started flashing when out on the trails. When I try to shift out of 4lo it starts beeping. Shop has replaced two t-case actuators, thinking 1st one might be bad, didn't fix issue. Tried replacing front ADD actuator, no fix. Could it be the 4wd ECU? Appreciate any help you might have!!
Katie
Originally Posted by BlackWorksInc View Post
Like I said, it could be either a failed actuator and/or a failed switch. Unfortunately some of the limit switches are not in fact servicable and thus may require replacement of an entire actuator (I believe this is the case with the transfers case actuator, I can't remember because some of the newer ones like the New Tacomas have replacable switches.)
Here's a "Quick Training Guide" from TIS on the '03-'09 T4R 1GR-FE 4WD system and what testing would look like:
Attachment 94231
So if you did manage to do an actuator test of the system, your screen should have shown a data list of the following switches with on/off indications when you tested the actuator:
~TL1
~TL2
~TL3
~DL1
~DL2
~ADD
The system uses a combination of On/Off switches to know what position it is in currently, what position it wants, and if it in fact shifted into that position. A failure of any one or more switches can cause the ADD or Transfer Case Actuator to not even engage.
Perl T4R is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 03:51 PM #40
waclo23 waclo23 is offline
waclo23 is on a distinguished road
Hello, I am having trouble with my 4th Gen 4 runner not engaging into 4Hi.
When I switch into 4Hi, the indicator lights start flashing but nothing happens and the 4wd does not engage. When I switch it back into 2wd it makes a horrible grinding noise like missing a shift in a manual transmission and then the indicator lights turn off.
This has happened the last two times I have tried to use 4Hi and now there is a metallic rubbing noise while I am driving. Does anybody know what could be causing that rubbing noise?
2003 Toyota 4 Runner SR5 V6
waclo23 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 11:32 PM #41
miller507's Avatar
miller507's Avatar
Check if the front diff actuator is working... That grinding normally happens when you go from 4lo to 4hi without doing a complete stop when in neutral.
LC Prado 150
4th Gen 4Runner
1GR-FE
2003 , 4th gen , 4wd , limited
major 2003 4 runner problems cman 4th Gen T4Rs 32 05-18-2020 07:07 AM
90 4runner problems? sndstrm Classic T4Rs 8 03-20-2017 07:43 PM
Will springs and shocks from a 2003 4Runner fit a 1997 4Runner?? gkatmar 4th Gen T4Rs 0 04-13-2007 10:42 AM
2003 NAV problems Avian Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-23-2006 02:25 PM
2003 V8 DAC & Reverse to Drive Problems!!! 4RunnerLaker Problems & Warranty Issues 10 08-30-2004 06:15 PM
