06-17-2020, 02:12 PM
#121
Originally Posted by trdsport
Anyone here have a audio visual of the result of DT headers of a 4.7V8?
Hey man, I have DT headers, a flowmaster 50, and removed the rear exhaust resonator.
Inside the car with windows up
Rev recorded from the rear bumper
Sent from my Pixel 2 using Tapatalk
"Bertha" '06 V8 Limited
3" OME | Matte Bronze SCS Ray 10s | 285/70/17 BFG KO2s
06-17-2020, 02:34 PM
#122
Real Name: Jordan
Real Name: Jordan
I’ve got some multimedia here: https://www.toyota-4runner.org/3502768-post20.html
Originally Posted by chrono
Sounds great!!
04 4Runner SR5 4WD V8
06-18-2020, 03:47 PM
#123
Thanks! I'm really happy with it, barely noticeable at highway speeds and not obnoxious around town but has a great grumble at idle and opens up nicely when romping on it
06-22-2020, 08:26 PM
#124
Nice!
07-05-2020, 05:21 PM
#125
Questions for those of you that have installed the DT long tube headers without a catalytic converter - Did you need 02 extensions on both front and rear positions or only rear to eliminate the check engine light? Ordered DT long tube and Gibson cat back from Jason Burtman and he told me I needed 4 spacers, but I've heard elsewhere it needs only the rear spacers. Any insight you guys have would be appreciated.
08-30-2020, 05:01 PM
#126
I’ve had the DT shorties for a few months now waiting for time to install them. Does anybody happen to know the status of the CARB exemption for these? I was going to just straight pipe my shorties, but I figure if I do that, I might as well sell the shorties and buy long tubes. If they will be carb legal by my next smog test, then I will weld in the factory cats.
What I don’t want to do is hack up my working factory manifolds and then have to buy new ones to pass smog in a year.
08-31-2020, 03:04 PM
#127
For anyone who cares, I put in a call to DT and they said that they will probably have an answer on the CARB EO end of September. Apparently their first application failed.
For now, I will be straight piping my shorties because all the DT's are backordered for a long time. If/when they get CARB exemption, I will removed and weld my cats on them.
09-01-2020, 11:37 AM
#128
Nortex Raceflow-x exhaust
Originally Posted by dropspace
FWIW I did not get a CEL and did not use the eliminators. DT Shorty headers and magnaflow high flow cats.
Full custom exhaust all the way back, not sure if that matters. The shop that did it specializes in Toyotas so maybe they knew how to space the sensors correctly. I also probably got lucky.
Shared album - Jonathan Stevens - Google Photos
Very interested in pursuing this same header/CAT/custom exhaust modification at Nortex Autoworks. Question, since the install, have you had any issues ? Aside from cost, would you still recommend this set-up? Any issue with exhaust not taken to very end of vehicle (e.g. fumes)? Thanks for any feedback.
Mark
10-05-2020, 03:14 PM
#129
Real Name: Melinda
Real Name: Melinda
Ok so jumping in on this thread. Just starting to notice a bit of bluish smoke on cold start up on my 03. Sounds like I'd better get going on replacing the headers soon next. Just about to roll 300,000 so I got my monies worth! If DT is way on back order, do you just get on that list now or what are you guys doing or would recommend please?
2003 Limited w/ Nav.; Painted custom; hood, bumpers, bottoms of doors, running boards, tail gate fin & bottom of gate, and roof racks lined with Full Metal Jacket polymer spray & repainted Trail Edition Shoreline Blue Pearl. De-badged since she's custom looking now. 4x4 V8. 320,000 miles as of Oct 2021. Mods: Fully synthetic fluids for engine oil & diffs. BFG A/T TA's KO2 for my TRD flat black rims & complete Stage 7 ICON suspension. A little front bumper plastic surgery. AFE Air filter. Magnaflow cat back exhaust. EBC green stuff brakes & slotted & drilled rotors.
10-12-2020, 06:16 PM
#130
For any of those still waiting, I called today to check on the CARB E.O. and still no word back yet, and no indication yet of when they'll know differently.
10-13-2020, 01:25 AM
#131
Just when i get my hopes up. I guess gotta keep waiting till they get the approval or move the duck out of California. lol
10-13-2020, 01:27 AM
#132
Real Name: Melinda
Real Name: Melinda
Ah so maybe better news for those of us who don't live in CA?
11-02-2020, 05:36 PM
#133
Originally Posted by IamHimeros
You'll be fine if you weld in some cats...
Sorry for reviving this a couple years later, but I've run into the issue of my headers cracking as well and want to go the route of DT. For emissions compliance, is the only option to basically remove and reuse the stock cats?
11-03-2020, 11:01 AM
#134
I'd recommend replacing the stock cats with some high-quality cats like the G-Sport by Gesi cats.
They'll burn cleaner than OEM and will outlast the truck. Buy once, cry once.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
01-17-2021, 01:34 PM
#135
So no CEL eliminator if using these cats?
My 06 V8 has a bad cat on the drivers side. Looking to replace those and headers at the same time, but would prefer to use a version that doesn’t throw a code.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
