08-04-2013, 09:29 AM
Real Name: Jeff
Real Name: Jeff
3rd Brake Light Issue
My 3rd brake light was out. I searched around and read that I will probably have to remove the spoiler to swap it out. So before doing all that, I decided to try the "smack the shit out of it" method. I stuck a broom stick between the brake pedal and the seat, went around to the back, and slapped the light. It flickered a few times, I kept smacking it, then it stayed on. I know this is just a temp fix, since I drove it for a few days and now its out again. Broom stick and slapping got it back on again today tho.
So has this happened to anyone? Is it worth trying to find the loose wire or am I better off just getting a whole new light? I have a feeling this is going to be a PITA...
2006 SR5 4X4 V6 - 98k - Shadow Mica
5100'[email protected], FJ Coils, Magnaflow 22" w/ Side Exit & Res. Hack, HIDs: 5000k Lows, 3000k Fogs, LED Rev, White/Blue Gauge/HVAC Swap, Int/Ext LED Swap, Foglight Mod, Custom Grille, Plasti-Dipped, Debadged, Weathertechs, -HCF, AVS In-Channels, Remote Start, Rodloft Pro, Firestone Dest. A/T 265/65/17s My Thread
Floating Rear Accessory: 18' Lund Alaskan
08-04-2013, 07:44 PM
theres 2 10mm bolts to take out, then the 2 philips screws, maybe the plug is loose, you have the regular or led?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
08-04-2013, 08:37 PM
Real Name: Jeff
Real Name: Jeff
cool thx! ill prob yank it off tomorrow
led
