05-20-2016, 09:45 AM
#31
Originally Posted by neoguri
How to use a bottle jack for that? I also bought some LCA bushings and cam bolts. And I got some LR UCA. Now deciding whether to do it myself or shop it.
What was your total cost
Sent from my XT1575 using Tapatalk
2007 LIMITED 4WD V8
Salsa Red Pearl
05-20-2016, 10:16 AM
#32
I went with OEM$ 275/piece.
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
05-20-2016, 11:13 AM
#33
Energy Suspension bushings with Ac delco ball joints on oem arms.
2 years beating the crap out of them with no issues.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
05-20-2016, 12:39 PM
#34
Real Name: Kyle
Real Name: Kyle
Originally Posted by Mike07SE
Actually, caster and camber.
I guess you inherently gain the more camber adjustment because you have more caster to play with. Unless were talking about adjustable BJ UCAs?
2015 SR5 T4R :: ordering parts.
2004 V8 T4R :: just a bunch of crap off ebay bolted on to a rusty toyota. ( build thread.)
05-20-2016, 01:14 PM
#35
This was referring to a few posts back when str3tlaw was writing about the LR UCA's. They have full adjustability of camber and caster.
But with any other UCA's, you're right that they only add caster that is lost in the lifts.
Sent from my XT1254 using Tapatalk
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
05-20-2016, 01:31 PM
#36
Real Name: Kyle
Real Name: Kyle
Ah right, so adjustable ball joints. So if you want uniball, you get no adjustment.
05-20-2016, 01:51 PM
#37
Originally Posted by knightsfs4
Do you have an update on what you ended up doing for your LCAs?
No idea what NJShadow did , but I'll tell you what I did. I replaced my worn out OEM LCAs with the ones from 1A auto for the following reasons.
1. They're a fraction of the cost of OEM's (I think I paid 180 for the PAIR)
2. I can replace them at least 2 times over for the cost of what OEM LCA's are going for currently.
3. They're cheap enough to justify also purchasing replacement bushings/ball joints so that my worn out OEM LCA's can be rebuilt for use as spares, should the 1A Auto LCAs ever crap out. So I end up with minimal down-time changing them out, and a set of spares for the same cost, (probably less actually) than what it'd cost to buy replacement OEM.
Frankly, with the look and feel of the 1A auto LCA's I'll be surprised if I ever even need the spares.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
05-23-2016, 10:55 PM
#38
LR UCA $470, bushings are $20 each x4, bolts $75
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
05-24-2016, 02:49 AM
#39
Real Name: Kyle
Real Name: Kyle
Did they actually feel solid? I just about pulled the trigger on these a couple weeks ago.
05-24-2016, 12:58 PM
#40
Laying them right beside the OEM's there's no immediately discernible difference between the two. Bushings and ball joint passed the "looks good feels good" test. Steel thickness and arm shape is nearly identical, with the only noticeable exception being part number identification stampings. Fitment into the frame mount points was good. Fitment of the lower coilover mounting was good. Holes for attaching LCA skids (if you're running them) were all present and in the correct locations. Had no issues getting the truck back into it's previous alignment spec.
At this point, I wouldn't hesitate to get them again. If for some unknown reason they shit out tomorrow then my opinion will change, but I have no reason to expect that to happen.
05-25-2016, 01:38 AM
#41
Real Name: Kyle
Real Name: Kyle
Thank you. I will likely be grabbing a set because of your testimony.
05-25-2016, 09:27 AM
#42
are they really 160 for a pair? am I looking at what you bought? and your saying the quality seems at least unnoticeable from OEM?
2005 Toyota 4Runner Steering & Suspension System Parts | 2005 Toyota 4Runner Aftermarket Suspension & Steering Parts At 1A Auto
05-25-2016, 01:00 PM
#43
Originally Posted by Billynath1988
I was thinking the same! Damn, may just take a chance on them for right now....when they come back in stock, that is.
EdmundGTP, do you have a pic of them side by side with the stockers?
2004 4Runner Sport V8 -Gibson catback -AFE Filter/HCF Delete -Weston Bull Bar -Bilstein 5100's/FJ Springs/1.5 Daystar rear spacer lift (awaiting warm(er) weather to install), FJ 8 Hole's and 265/70/17 Dueler's, Toyota factory Smokers Kit (for additional plug in)
05-25-2016, 01:34 PM
#44
Those are them. When I bought them I paid $158 plus shipping for the pair. I think the total was $172. Their prices seem to fluctuate slightly. Quality looked on par with the OEM LCA's that I yanked out.
I've only had them installed for a few thousand miles so far, and the extent of abuse that I've put them through has been limited to driving off curbs at 20+ mph and cruising over 15mph speed humps at 40+ to shake down the suspension I just installed. No issues thus far. If something comes up with them I'll surely post up about it but I have no expectation of that. I don't think I'm the only person on this forum running these particular LCA's either.
To be honest, there's really no good reason these days that parts like these LCA's should cost more than what 1A auto is charging. They're mass-produced stamped steel + casting weldments with a few pieces of also mass produced hardware attached. Not space shuttle parts.
05-25-2016, 01:37 PM
#45
I do not have a picture of them side by side with the OEM's. Though I believe there is another LCA thread on this forum where someone does have similar pics posted of the same LCA's.
