Old 10-20-2022, 08:13 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
Truck pulls/shims to the side when going over bumps - what could be causing this?
Whenever I hit a bump my truck tends to pull to the right. This is a new thing so I imagine it's a new issue caused by a shock/bushing?
CO4x499 is offline   Reply With QuoteReply With Quote
Old 10-21-2022, 12:15 AM #2
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
I went on a rampage trying to fix mine and it could be a lot of things, honestly.
Bad tie rod ends
High mileage power steering pump
Bad steering rack bushings
Worn tires
Bad LCA bushings
Bad sway bar bushings
It is worse if you're lifted. Mine is lifted with new 305/70r17 tires and I've done the following:
New whiteline LCA bushings
New tie rod ends
"New" steering rack with poly bushings and 1/2" bolts
New uniballs in the UCAs
Removed rag joint from steering shaft
And I still get wonky steering over bumps. Its WAY better than it used to be but my next course of action is re-valving the shocks to be comfier then new power steering pump. Then maybe I'll try a late model FJ cruiser steering rack
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
caused , imagine , issue , thing , truck
Truck Pulls Right After Steering Rack Replacement - 2 shops can't align hungryeddy 3rd gen T4Rs 12 09-08-2021 09:28 AM
Truck pulls hard to the right when braking mscot 5th gen T4Rs 11 01-03-2019 03:32 PM
Truck pulls left when hitting the brakes. MandAtaco 3rd gen T4Rs 22 04-07-2017 07:01 PM
Rotated tires-now pulls to side and steering wheel shakes MidwestJ 5th gen T4Rs 2 09-21-2015 02:48 PM
95 4Runner Pulls out INTERNATIONAL truck SixxiA Gallery 7 04-28-2010 11:05 AM
