Old 07-30-2020, 06:04 PM #181
montijo505's Avatar
montijo505's Avatar
Originally Posted by Jcmeadows82 View Post
Was literally just looking at these. 160k on my stock LCA's and alignment shop says I need new ones. I like the fact that these come with everything. the site i found them on is:
TRC482 | SuperPro Suspension Control Arm Lower Complete Assembly Kit Double Offset Front Lexus GS 2001-2009 | Toyota 4Runner 2002-2009
I wont be doing this anytime real soon, probably in the next year. Startin the research now.
These come to same price as OEM if you can reuse your hardware. Go on amayama.com the OEM are $225 + shipping.
Only argument for these is upgraded bushings and come with cam bolts already.
Either way you can't go won't, especially with them being in sale for $599 right now.
Sent from my SM-G986U using Tapatalk
Old 09-16-2020, 03:45 PM #182
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Moog bushings and LBJ feedback
I've swapped Moog bushings and LBJ into my OEM LCAs, prolly two years ago. One of the arms has developed an annoying squeak/scraping sound while going over bumps. The Moog LBJs have tiny boots that I'm not even sure how they keep dirt out once the arms drooping. When I have time this fall, I'll swap over an used set of OEM arms and study the squeak.
Anyway, just some real world feedback.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 02:10 PM #183
EdmundGTP EdmundGTP is offline
EdmundGTP will become famous soon enough
Originally Posted by SHagood View Post
Sorry for bringing this back from the dead. How are they holding up? Are these the ones?
2008 Toyota 4Runner Front Lower Control Arm with Ball Joint Pair
Those are them, and they're still going just fine. Bushings look to be in good shape still. Ball joint boots are getting a little dry, but I expect that out here in the desert.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
EdmundGTP is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 07:11 PM #184
Cpt_Romania Cpt_Romania is offline
Real Name: Ruben
Cpt_Romania is on a distinguished road
Real Name: Ruben
Any updates on the 1A LCAs for people?
Cpt_Romania is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 07:54 PM #185
T4RDirt's Avatar
T4RDirt T4RDirt is offline
Real Name: Devo
T4RDirt is on a distinguished road
T4RDirt's Avatar
Real Name: Devo
I've had one in on my passenger side for 2 years and no complaints. Going to do drivers side soon with the same ones
Sent from my KB2007 using Tapatalk
T4RDirt is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 08:04 PM #186
Real Name: Ruben
Real Name: Ruben
Did you use all of the OEM hardware or buy new ones?
Old 05-28-2021, 08:10 PM #187
Real Name: Ruben
Real Name: Ruben
Originally Posted by EdmundGTP View Post
No idea what NJShadow did , but I'll tell you what I did. I replaced my worn out OEM LCAs with the ones from 1A auto for the following reasons.
1. They're a fraction of the cost of OEM's (I think I paid 180 for the PAIR)
2. I can replace them at least 2 times over for the cost of what OEM LCA's are going for currently.
3. They're cheap enough to justify also purchasing replacement bushings/ball joints so that my worn out OEM LCA's can be rebuilt for use as spares, should the 1A Auto LCAs ever crap out. So I end up with minimal down-time changing them out, and a set of spares for the same cost, (probably less actually) than what it'd cost to buy replacement OEM.
Frankly, with the look and feel of the 1A auto LCA's I'll be surprised if I ever even need the spares.
I am buying these along with the Inner and Outer Tie Rod set from 1A Auto as well.
Did you use the factory hardware, did you need to buy anything else? Camshaft bolts etc? And if so, from where did you grab them? What grease did you use to add extra to the BJs as well?
Thank you
Old 10-02-2022, 08:35 AM #188
Hitmanhink Hitmanhink is offline
Hitmanhink is on a distinguished road
Great thread! I’m intrigued with the Superpro LCA’s those seem pretty legit but still not a ton of feedback on these. Would love to hear how these are holding up after at least a couple years. So far I’m seeing good feedback on this thread: SuperPro LCA
I’m trying to boil this down a little bit though… It seems the biggest complaints are cheap aftermarket LCA’s not lasting very long. So many of you are buying a full OEM LCA’s or doing an OEM rebuild…
It seems like the aftermarket LCA’s are failing due to cheap bushings, is that right?
I have a question on those of you rebuilding… if you replace the ball joints and the bushings, then it’s just the steel part of the OEM LCA’s that your retaining right? Is it the steel from the OEM LCA’s that’s most valuable? In other words your saying the steel in the aftermarket LCA’s are what’s causing them to fail?
Or are the aftermarket LCA’s that are available out there, just not coming with good bushings and ball joints?
Looking for feedback from those with firsthand experience here
Silver 05’ 4Runner V8 4.7L Sport, Bilstein 5100 shocks, Dobinsons C59-314B front springs, Dobinsons Aluminum Billet UCA’s, Superpro offset LCA’s, OCD sway bar endlinks, Toytec Superflex RCC2.0-P rear springs, Cooper Discoverer A/T 3 285/70/17 tires, SCS Blaze 10 Wheels with -10mm offset, and lots of plans for future mods…
Hitmanhink is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 01:38 PM #189
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I bought a pair of 1Aauto LCA's and installed Super Pro bushings in them before installation. I also scuffed up the paint, repainted and clear coated before install. So far so good, I don't off road and not many miles on them. The bushings that come in them appear identical to OEM. I also used new OEM alignment hardware as mine were rusted in place.
Not sure how durable the ball joint is that comes with the 1Aauto but no problems yet.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-05-2022, 10:40 AM #190
I'm curious who makes the bushings for 1A auto, sounds like a close match to OEM. Same for the LBJs.
Old 10-06-2022, 02:18 AM #191
Real Name: Ruben
Real Name: Ruben
I just went with the 1A Auto LCAs, installed them and haven't had any problems. I think people overthink it. It's not a complex part and it does a simple job, well so far for me. I don't think it makes sense to spend a lot of money on this area. My experience here so far!
Old 10-06-2022, 08:56 AM #192
I agree with you to some degree. The bushings and the BJs are the key components and there's a high probability they're made in China. How long they'll last is only a guess at this point.
OEM bushings and BJs are lasting over a decade and now that the 4th gens are getting long in the tooth, some of us are trying to save some coin and gambling. I'm in the same boat and trying to decide which way to go.
Old 10-06-2022, 09:22 AM #193
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
I've had 1AAuto on mine for 1 year now, and they've been totally fine.
Some components have to be OEM. Just not sure this is one of them.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 10-06-2022, 12:32 PM #194
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Although an LCA isn't a "complex" part, it does perform a very important function. And when it goes bad - particularly if it fails at the wrong time - you can end up in a world of hurt. I consider LCA's (and many other simple parts) to be safety items and I'm not willing to cheap out on them for that reason.
As for how long aftermarket - particularly cheap aftermarket - parts will last, I'd be more than willing to bet that they don't last nearly as long as OEM. I work in a Toyota dealership, and you should see some of the aftermarket crap that folks have installed to save money that we then have to replace. Some of it is downright scary. (Dorman Intermediate Steering Shafts for instance.)
Too Stroked is offline   Reply With QuoteReply With Quote
Old 10-11-2022, 02:26 PM #195
I wonder too, if you swap out rubber bushings on the LCA’s for poly bushings would that put extra stress on your UCA bushings if they’re still rubber?
Rear Lower Control Arm Brian1973 3rd gen T4Rs 64 07-15-2018 10:19 PM
Lower control arm bushings blue4r 3rd gen T4Rs 4 05-01-2013 04:04 PM
Lower control Arm Bushings gmata 3rd gen T4Rs 2 11-08-2011 08:10 AM
Need front lower control arm!!!!!! richyrich307 Classifieds - buy & sell (no commercial ads please) 0 01-23-2011 11:48 AM
Need Help - Lower Control Arm AlexJet Problems & Warranty Issues 0 08-25-2007 08:00 PM
