01-17-2019, 12:15 PM
#16
Tagged for later.
2005 4R V8 4x
01-18-2019, 01:07 AM
#17
As Riceandpho said, use the Metra 95-8202 kit if you have an SR5 with the base radio. Use the factory brackets with the kit and it is nice and solid.
Here's mine
01-18-2019, 10:28 AM
#18
Real Name: Eric
Real Name: Eric
Here's mine
Yeah the use of the factory brackets makes it nice.
Oh, I like the dust cover btw. I've had a couple made for my "toys". lol
2007 4.7 Limited - Let the fun begin!
01-18-2019, 10:26 PM
#19
Thanks, it's just a wrap though. Gonna do a few other pieces on the interior as well.
01-19-2019, 09:43 AM
#20
Originally Posted by riceandpho
you cannot use that kit for the base radio opening, the other guy has a jbl radio opening.
your radio kit is the metra 95-8202 kit, just have the side gap covers. it works really good when done right. scosche and american international and bestkits uses the similar stuff, but will show the sides of radio more.
Is the 95-8202 the one that replaces the factory brackets? I have a non JBL SR5 that currently has a single DIN Pioneer that was installed before I bought the truck. I haven’t taken it apart yet, but based on what I’ve read on this forum, I will need to source factory brackets when I buy a double DIN, but with certain kits, I know you don’t need them. For example, I just installed a Sony XAV-AX1000 in my daughter’s ‘03 Camry (which had JBL), and used Metra 99-8231, which had its own plastic brackets that clipped onto the front filler piece. It installed perfectly, but was a real pain because the factory bracket screws wouldn’t work with the Sony, and the screws that came with the kit wouldn’t either. I had to source some different self tapping screws to make it work, which delayed the install a bit, but then it dropped in and fit perfectly. Sorry for the long story, but I just want to be sure I don’t waste time and money ordering factory brackets only to find out that the install kit doesn’t need them.
Edit: never mind, I just got my answer above. I guess I should’ve read the whole thread before asking about the brackets.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
01-19-2019, 10:16 AM
#21
99-8300 kit for 25-30 bucks, or source the factory radio brackets to use the 95-8202.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
01-19-2019, 10:21 AM
#22
Real Name: Eric
Real Name: Eric
I meant on the AR. lol The CF wrap looks good too though.
01-19-2019, 10:23 AM
#23
Derp!
When it's time to get sh*t done...
05-25-2020, 01:38 PM
#24
Anyone know where parking brake wiring is? Trying to finish my install for AA and DVD
05-25-2020, 02:30 PM
#25
I just grounded mine, it just bypasses the whole parking brake switch needed to be depressed to play. It’s the lime green wire rolled up and grounded the the bolt on the left side of the face.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
05-25-2020, 03:02 PM
#26
Do yourself a favor and just ground that wire unless you want to make changes on your radio ONLY when the parking brake is engaged.
05-26-2020, 11:54 AM
#27
Recently installed a Pioneer AVH-2550NEX DVD unit and grounding that light green parking brake wire did not work. Ended up purchasing this DIY Parking Brake Bypass from ebay to get the override to work correctly. Super easy to install while installing a new head unit...
DIYBypass Parking Brake Bypass Fits ALL AVH Pioneer Override DVD Video Lockout | eBay
05-26-2020, 02:18 PM
#28
Originally Posted by spdrcr29
How do like the AVH-2550NEX? That is the unit I’m close to pulling the trigger on. It was between that and the Sony AX210sxm but I already have an xm tuner and antenna now and there’s a lot more reviews on the Pioneer. I think I’m pretty set on the Pioneer 2550. Was considering ordering today or next few.
Hmmmm, interesting and good to know on the newer units, mine works fine grounding the PB wire but is an older unit. Guess I’ll have to order a bypass myself then.
05-31-2020, 06:21 PM
#29
So should I use a toggle? Or just ground it?
05-31-2020, 06:22 PM
#30
It's great actually. Like it alot better than my other A.M radio
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Factory 4th gen radio
AURunner |
Classifieds - buy & sell (no commercial ads please) |
1 |
04-19-2010 11:40 PM |
Radio replacement?
snowdrif |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
1 |
12-03-2008 09:23 AM |
factory radio replacement
yotarunner |
2 |
12-26-2006 11:48 PM |
XM Radio to Factory Radio
SC06BT4R |
9 |
04-20-2006 04:47 PM |
