02-18-2022, 12:42 PM
official vendor
official vendor
Did you upgrade your halogen headlights with LED bulbs or LED headlight assemblies?
Hey everyone,
Have you upgraded your OEM halogen headlights with LED bulbs? or after-market LED headlight assemblies, or still keep the stock halogens? Do you have plans?
02-18-2022, 01:01 PM
I bought an aftermarket assembly with LED Projectors. These trucks are old enough that a whole new headlight isn't a bad idea vs polishing and modifying the originals.
02-18-2022, 01:03 PM
It seems like there's mixed reviews on many aftermarket housings, in terms of how generous the years & sun are to the clarity of the outer lens. I haven't been able to find a specific brand/part that there's a consensus on.
It appears rebuilding the OEM housings from an 06-09 with better lights is the way, but for us guys with the '03-05, it's not so straightforward.
I've seen many remarks that LED bulbs in the early 03-05 housings give questionable results. Whereas high-end projector upgrades give top-notch results.
I want to do an upgrade but I do not want to have to cook my headlights in the oven and then die-grind my way to good cut-off and excellent throw. Or get an aftermarket housing that turns yellow in a couple of years.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
02-18-2022, 03:50 PM
Personally I'm going to be adding my own clearcoat or wrap to the aftermarket one when it arrives. I figure if I can protect it before anything gets messed up that's way easier than trying to clean it up after it starts to wear.
02-18-2022, 05:06 PM
If I do, I’m buying factory housings and putting Tiny Monster bulbs in. They’re amazing.
2008 SR5 4Runner V6 4WD
02-18-2022, 05:18 PM
Had LEDs in 06-09 housings and I hated em, so I went back to H11 halogens and I'm much happier. When these go out, I'll do the H9 mod
02-18-2022, 07:41 PM
Real Name: Matt
Real Name: Matt
I’ve had Auxbeam FT-1 LED low/hi’s for about a year or more. I love the light output. I do have them adjusted 4” below center at 25’ so I don’t destroy oncoming traffic. I found out a while back that the bulbs are not DOT approved according to NHTSA and am researching different bulbs. I may install H9 halogens idk yet.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
02-18-2022, 07:43 PM
I have an '06 and use HID's, seems you can't get those much anymore. Any LED bulbs work well enough now?
2006 Sport V6
Bought used @ 185k miles
My first T4R, previous XJ owner
02-18-2022, 08:25 PM
Just as a point of reference, none of the "drop in" LED headlight bulbs are legal for on-road use. All of the reputable sellers of this type of bulb bowed to government pressure and pulled their products off the market.
02-18-2022, 08:45 PM
An 06 owner with the factory projector beam with halogens originally. These fade over time, so Sylvania LEDS. Decent light output and instant on is nice.
02-19-2022, 01:53 AM
Should be said LEDs should only be put in 06+ models.
LEDs should NOT be put in halogen assemblies with reflector bowls. Do NOT be that guy.
'08 Silver SR5 V6 4x4: OEM+
02-19-2022, 11:22 PM
Real Name: Russell (OB #9908)
Very happy with the Boslla B4 Bullet LEDs I installed on my ‘07 Sport.
02-20-2022, 04:47 PM
I replaced the OEM projector housings with some ebay special black OEM looking projector housings. My OEM headlight housings are very pitted and faded and wouldn't stay polished even with a clear coat. The ebay specials look just like the OEM headlights, except painted black. Unfortunately, the light output, cutoff, and aim were nowhere close to OEM with the OEM halogen bulbs. Terrible, uneven and distorted cutoff and a very pronounced rainbow effect at the top of the cutoff. The actual light output sucked as well but I put up with it for a year or two. I even purchased some used OEM housings that were better than mine, that I had intentions of polishing and swapping out the ebay housings.
Somewhere along the way, I picked up a set of VLed LED bulbs and figured I'd try them because it couldn't get much worse. Much to my surprise after a little adjusting, the LEDs drastically improved the cutoff, aim, and definitely the actual light output. They also got rid of that crazy rainbow effect that was going on and I was able to aim the lights correctly. No hot spots and they don't blind oncoming traffic. After about 6 or 7 years in the hot NM sun, these ebay headlights are starting to fade and the black paint inside is pealing so eventually I'll replace them. Hopefully I can still get the same ebay headlights!
I was so impressed with the LEDs on my 4th gen that I ordered a set of LEDs for my 5th gen but other than updating the look of the light output, I would say overall they are no better than what was originally in there. The projector on the 5th gen is totally different and it took a lot of trial and error to get the LED to "clock" correctly so the overall light output is just OK.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
02-21-2022, 06:31 PM
LED bulbs
Have tried about a dozed different bulbs between 2 vehicles. I have the 06-09 Akkon headlights on my 04. First set of LED's I tried was on my 11 Camry, and lets just say it was a scary drive around the block. Those bulbs didn't throw light more than 30' I'd say. That was back in 2015ish. Ran HID's for a few years after on both vehicles. Tried again on an amazon sale for some Simdevanma 8k lumen and was shocked. They were comparable to my HID's I was running. Ran them for a while til Sealights were on sale, but they had horrible throw and went right back. Had good luck with Katana 10k and 12k lumens and ran them on both cars for a while. Ordered beamtech and another at the same time and they went right back(amazon hated me). Autlead, and more sealights went back. Hikari ultra focus 18k aren't as advertised and went back. Auxito 16K lumen are by far the best I've found. Sharp cutoffs, very bright. Best bang for the buck! I also agree, do not run LED or HID in reflector housings please!
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
02-21-2022, 11:01 PM
Get a 2k clear coat. It has a catalyst that hardens the clear coat. I ran an "Automotive" clear coat from a FLAPS when I painted my brakes. One accidental drip of brake clean and the clear and base paint came straight off. I re-cleared them with a 2k clear that I bought off Amazon. Have used brake clean and wheel acid and they still look new. I also repainted my fender using the same stuff. Its super solid. The best you can get out of a rattle can.
