08-29-2013, 02:14 PM
#16
Originally Posted by Martinjmpr
Doesn't the 4runner come with supposedly "lifetime" WS coolant?
This x 1000
The first thing I'd say to those of you worrying about your V6 head gasket is this:
KEEP CALM AND CARRY ON!
Remember that message boards like this tend to magnify flaws and failures.
It's easy to understand why - there aren't too many message boards where people sign up just so they can post "Hey, I just wanted to say my vehicle has 150k on it and everything works fine!" Instead, people who have a problem sign up to post here, and they run into other people who also signed on to post about problems/issues they had.
Since there are, proportionally, so many people posting about problems, a casual reader could get the idea that the problem is more widespread than it actually is.
Many years ago, I owned a 1999 Subaru Outback Wagon with the 2.5l flat 4 motor. Those of you who have any experience with Subarus know that this motor was notorious for blowing head gaskets! I bought mine with 42k on it (before I had done the research and before I knew about the HG problem) and I was always paranoid that my gasket would blow. Any sign of less-than-perfect running would have me panicking and checking the radiator overflow tank and/or the oil.
4 years after I bought it, I traded it in with 120k on the clock and not a lick of trouble. And then I started looking around and saw that there were so many 1997-2002 Subarus on the road (including my brother's, he drives a 2002 Impreza TS wagon with the same HG-trouble-prone 2.5) that there couldn't be that much of a problem - otherwise why would all these cars still be on the road instead of in a junkyard somewhere? Surely nobody's going to throw down ~$3k to fix the HG on a 13 year old POS with 167k on it!
I've also noticed just in my city (Denver) that you can't swing a dead cat without hitting a dozen 2nd gen 4runners or 89-94 pickups (the last version of the Hilux sold in the US, I call them "Pre-Tacomas.") Most of these have the 3.0, A/K/A "Three Point Slow" that is also notorious for eating HG's.
And yet, these old, beat up, dented Toyotas are still on the road. Hell, I went to Lowe's yesterday and somebody had a 2nd gen (1994) 4runner sitting in the parking lot for sale - asking $4500!
Bottom line is that it's important to keep some perspective when you look at threads like this. A 4runner is a mechanical device, and there's no mechanical device in the world that can't break - especially as it gets older (note that in at least one recent HG failure thread the T4R in question had over 200k on it.)
I don't care if it's an T4R, a Mercedes, a LC 100, a Lexus, or a tank, if it's mechanical, it CAN break.
If a given single point failure (say the HG) happens 3 times out of every 100 vehicles instead of 1.5 times out of every 100 vehicles, that's a 100% increase in failure, but it still means you have a 97% chance of it never happening to you.
When all is said and done it's probably more likely that your T4R will get totaled by a texting driver or a soccer mom yelling at her kids, (or by you) than it will suffer a HG failure.
So do regular maintenance and don't worry yourself too much. There are way too many 4th gens on the road now for this to be a significant issue.
This is seriously one of the best posts I've read on here. I couldn't agree with it more. Especially in those "what's the best oil/filter?" threads.
08-29-2013, 04:22 PM
#17
There is no "WS Coolant" and there is no such thing as "lifetime" fluids. SLLC (Super Long Life Coolant) lasts around 90~100k, WS fluid we've found (By we, being customers, owners, and dealerships) to last around the same range if the vehicle is driven under "normal" conditions.
I completely agree with Martinjmpr, keep in mind that we've only have a little over half a dozen verified headgasket failures on the 4Runners on this forum and MAYBE 10 or so combined with T120 for just 4Runners (I don't know about the Tacomas and FJ Cruisers as I don't check those sub-sections often). We're probably looking at about MAYBE 5~10% failure rate for actual on-road vehicles; that being said, the headgaskets are the same and there IS an updated part because there is an issue with the old design (why Toyota has not released at least a TSB to inform technicans of it I do not know) so potentionally all vehicles could be affected; but not all vehicles will fail.
That's why I can't really give you a very complete answer on "preventative maintence" because all we know is that a small percentage of vehicles with an "obsolete" headgasket design are failing for some reason. I haven't had the opportunity to see a vehicle with this issue in person, nor have I seen enough pictures of the failed headgasket itself to compare the failure spots (that would be great to have come to think of it...)
In any case, I wouldn't panic... if you have the money and time to spend and you really feel like you want to change the head gasket; go ahead and do it. But, don't feel like the truck is going to just die on you randomly. I understand the idea of "better to have it changed when you plan for it, than have it go out when you least expect it" but most headgasket failures occur very mildly over a span of time and you can catch it early enough before any real damage can be done. At worst, maybe puff some coolant into the catalytic converters... but who care about those? In short, I wouldn't change the headgasket out unless you're really planning on doing like an engine rebuild or something; if it does fail, it seems to occur rather tamely and nothing super crazy where one day its fine and the next you have coolant shooting out the tailpipe.
08-29-2013, 04:53 PM
#18
Yes sir 100% agree BWINC mine was a quest for info on this occurrence and like you say likely a small % . Just had a buddy with the 010 jeep liberty HG go ! You being in the biz have access to more than some of us so your opinion is highly respected . Only way I would do this is if it went or doing the whole shebang headers & all ! Guess everyone needs to accept this as possible but not probable ,course when it happens to you all that goes out the window and then nobody wants to shell out 3K . Again thanks for your help in explaining .
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
08-29-2013, 05:03 PM
#19
Whoops my mistake, I got the WS transmission fluid confused with the coolant.
Martin AKA Zapp Branigan - No longer a 4runner owner!
08-29-2013, 05:10 PM
#20
Thought I would also add this "it ain't" WS , just had mine serviced & the writer claimed same thing but after 104g mi , lucky for me knew somebody got it cheaper . Service tech said it was gross ! Anyway I noticed a difference right away .
08-29-2013, 08:26 PM
#21
I posted this over on the other thread this AM, and I agree that keeping some perspective on this is important.
My thoughts:
I've had a few other vehicles which required HG replacement, so this is not news, but a bummer for sure. Based on the pics I've seen, its a big job. I was hoping to get 200k before HG replacement but what can you do. I've had many other brand where HG jobs were needed, its almost a silent factor of ownership. Sooner of later, every manufacturer has a model/engine that sees more HG jobs. Could be the gasket, head or block quality or design.
I may also be heading down HG road, losing coolant and rough idle at start, no codes yet, 160k miles, V6, 2007 SR5 4R.
On the cost side, its lose/win situation vs having the V8 engine. If you expect a 200,000 mile service life, the V8 costs $7,700 more in fuel (3mpg diff @$3.50/gal) and timing belt jobs (2x$800). So, you're winning with the V6, even net of the HG job.
So for me, this is an unwanted expense, but the cost of a newer rig, more cash into the deal, taxes and insurance cost increases and monthly payments is WAY more than a fix that will keep my 4R on the road for another 160K perhaps.
In any event, if we keep reporting to Toyota, perhaps there will be some partial reimbursement in the future.
This x 1000
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
01-24-2022, 11:55 PM
#22
Thank you guys so much for this info.
I just bought a 2003 V6 sr5 with 163k and am currently in the process of doing as much preventative maintenance as possible and affordable, before I start in on wheels tires and lift.
This HG issue has been stressing me out, thinking there's a ticking time bomb waiting for me.
90% is pretty good chances to me.
2003 4Runner SR5
01-28-2022, 07:39 AM
#23
Real Name: Armando
Real Name: Armando
I'm still waiting for HG issues. It's been a long 17 year wait since I bought my 2005 V6.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
01-28-2022, 10:09 PM
#24
Real Name: Tim
Real Name: Tim
Bought my 03 about a year and a half ago with 237k miles on it it now has around 263k miles and it’s been fine just take care of your truck and it’ll take care of you
07-08-2022, 04:59 AM
#25
Just wanted to add that my 2003 SR5 V6 is at 403590 Kms and running strong on the original head gasket. I had a new rad and water pump installed last year, hopefully that will help keep the engine at a safe operating temp for years to come. Take care of your 4runner and it will be fine
01-10-2023, 03:42 PM
#26
Oh damn, I thought you said 400,000 miles ! But that is a good long run there
01-11-2023, 06:02 PM
#27
Another HG failure in a 2005 4Runner @ 218k miles
Just finishing off a HG replacement job.
It was a bear of a job, with rusted manifold nuts, waiting for parts that broke while disassembling them, plus machine shop time on the heads, and having to redo the oil pump o-ring (must've slipped during the 1st assembly).
The head gasket was a Felpro unit that had 3 layers sandwiched on top of each other, unlike the single metal gasket from Toyota.
After doing this, I can unequivocally state that I would have not done this work preemptively. It ran for 16 years with minor repairs, and I changed it when it actually happened.
1st one is a bear, but after this, if it happens withing 5 years, I'll do it again as I am keeping this thing, and will be buried in it.
So my advise? "Laissez faire" Let it be and deal with it when and IF it happens. You can also sell the car and get a horse (no head gasket to worry there!)
01-12-2023, 01:51 PM
#28
Change your anti-freeze every 50K
