Old 09-06-2013, 10:22 AM #1
wkeryder4's Avatar
wkeryder4 wkeryder4 is offline
Real Name: Will
wkeryder4 is on a distinguished road
wkeryder4's Avatar
Real Name: Will
Adjusting bilstein 5100's
Hey everybody, so I've had my Bilsteins on for about two months now and they are set at the .85 setting. I finally got around to getting some all terrains put on and now I'm debating moving them up to the 1.75 setting. I was wondering if anyone had any tricks that made the job a bit quicker/easier. I'd hate to have to spend another day taking them out and putting them back in. I found the most difficult part about putting them in was pushing the LCA down far enough to squeeze them in and I'm assuming with the added height it's gonna be even more of a pain to get them back in. I used the jack handle method but it scares the crap out of me putting stress on that lower ball joint.
wkeryder4 is offline   Reply With QuoteReply With Quote
Old 09-06-2013, 10:26 AM #2
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Originally Posted by wkeryder4 View Post
Hey everybody, so I've had my Bilsteins on for about two months now and they are set at the .85 setting. I finally got around to getting some all terrains put on and now I'm debating moving them up to the 1.5 setting. I was wondering if anyone had any tricks that made the job a bit quicker/easier. I'd hate to have to spend another day taking them out and putting them back in. I found the most difficult part about putting them in was pushing the LCA down far enough to squeeze them in and I'm assuming with the added height it's gonna be even more of a pain to get them back in. I used the jack handle method but it scares the crap out of me putting stress on that lower ball joint.
either disconnect the UBJ or loosen the LCA bolts.
i find disconnecting our ball joints with a pitman arm puller is really easy
zopperman is offline   Reply With QuoteReply With Quote
Old 09-06-2013, 12:45 PM #3
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
This. If you loosen the alignment bolts a little the arm will drop down as much as you want.. I installed 4 or 5 suspensions without doing it before I saw the light...
As far as tips that'll make it quicker, You can probably just drop the assembly enough to unload the coil and, keeping the lower shock bolt in, just move the clip without completely removing the assembly from the truck.. That's really about all you can do to speed it up though.
..Other than the LCA tip of course, but that's just generally helpful for lifting these, not necessarily the adjusting the billies part.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 09-06-2013, 03:44 PM #4
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
I completely agree on the LCA bolts. After doing it both ways and damaging the LBJ boots the first time, I can't figure out why anyone would do it with the jack/pry bar method. It's way more difficult that way.
ktom3001 is offline   Reply With QuoteReply With Quote
Old 09-06-2013, 09:18 PM #5
wkeryder4's Avatar
Real Name: Will
wkeryder4's Avatar
Real Name: Will
If I were to loosen them could I get away with just marking the washer to the body of it and re-torquing the bolt to that position. (I don't have a torque wrench)
Old 09-06-2013, 09:27 PM #6
tony_4r tony_4r is offline
tony_4r is on a distinguished road
I wrote this thread with some tips.....
My experience and tips to install front Billstein 5100s
Definetily the lca method makes it easier
2008 4Runner SR5 V8 4wd with 5100 Bilstein (1.75") and FJ springs; FJ wheels
Before: 1999 5-Speed SR5 4Runner
1994 5-Speed SR5 4Runner
1987 Land Cruiser FJ70
1979 Land Cruiser FJ40
tony_4r is offline   Reply With QuoteReply With Quote
Old 09-06-2013, 09:28 PM #7
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
You could, but in my experience if you don't fool with things they'll stay pretty much in place. You're going to need another alignment after lifting the front end more anyway. The guys at the alignment shop will torque the bolts to the OE specs, you just gotta get it good and tight to drive around and until you get to the alignment shop.
Adjusting Tundra 5100's cj80cruiser 3rd gen T4Rs 11 01-15-2013 08:25 PM
Bilstein 5100 FS sblbdr For Sale: Suspension/Wheels/Tires 0 08-26-2012 12:16 AM
Bilstein 5100 + FJ springs Or Bilstein 5100 + stock springs Morrobayrunner Engines / Suspension / Wheels / Tires / Audio / Accessories 16 09-23-2010 06:03 PM
Bilstein 5100 or OME L01D General Discussions 5 04-28-2010 11:23 AM
bilstein 5100, bilstein 5125, & OME 891 rayny1014 Classifieds - buy & sell (no commercial ads please) 4 07-10-2009 10:27 AM
