Originally Posted by zopperman
loosen the LCA bolts.
This. If you loosen the alignment bolts a little the arm will drop down as much as you want.. I installed 4 or 5 suspensions without doing it before I saw the light...
As far as tips that'll make it quicker, You can probably just drop the assembly enough to unload the coil and, keeping the lower shock bolt in, just move the clip without
completely removing the assembly from the truck.. That's really about all you can do to speed it up though.
..Other than the LCA tip of course, but that's just generally helpful for lifting these, not necessarily the adjusting the billies part.
