Originally Posted by Seasparrow
@ 81runner
Isn't the whole point of the switch to stop the starter activating in gear? If the switch isnt in park or neutral the starter circuits will not activate, thats why it cant be started in gears like reverse or drive, correct ? Thus moving the gear shift lever a few times may over come the worn / stuck switch and the switch will be seen in the proper position.
Yes that's correct. The neutral safety switch is specifically to prevent a trigger of the starter circuit when the trans is not in neutral or park. So cycling thru the gears if the switch is stuck could free it up to where you get it to make contact in the correct position and thus start the engine. Pretty sure we're on the same page there.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
