09-23-2013, 11:01 PM
#46
^ no shit right. Had I known about the"maintenance" of keeping an eye on these things in the beginning, I wouldn't have got them. Crazy how fully torqued lugs created that much stress from being backwards
09-23-2013, 11:06 PM
#47
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Originally Posted by gaterose
I have to agree that this is plausibly the correct answer (although obviously we can't recreate to determine for sure).
Since the lug nuts are conical, I assume this help center the spacers onto the lugs making the spacers both hub and lug centric.
It seems to me that if the spacer was allowed to wobble around on the lugs (because it wasn't perfectly centered due to the lug nut not centering the stud) it could grind away the stud and allow movement for the wheel to have enough leverage to snap them off.
This. OP, you installed the flat side of the lugs facing the spacer? Not the conical side which helps center it on the lugs
They don't require so much "maintenance" as they do just doing it the right way. I haven't looked at mine since i did the initial re-torquing...
09-23-2013, 11:10 PM
#48
Not sure. The lugs securing the spacer to the rotor studs were backwards. They were tightened to spec but it didn't matter. Spacer was flush against rotor
09-23-2013, 11:13 PM
#49
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Of course it was flush against the rotor, but it wasn't centered AND torqued on the lugs and nothing prevented it from moving on the lugs, thus shearing the studs...
you have a big "O" on the little "o" sized stud, the stud can wiggle inside the big O. the conical lugs, when used correctly will lug - center the spacer and you shouldn't have issues.
I have wheeled the piss out of mine and stand by them
09-23-2013, 11:25 PM
#50
What he ^ said . WTF
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
09-23-2013, 11:32 PM
#51
Okay that clears a lot up and I extend my apologies if my comments rubbed you the wrong way. I've just seen a lot of one-post wonders that are fairly suspicious and difficult to validate.
It does in fact seem like this was caused by you; but I am very happy that you and those involved survived.
09-24-2013, 12:48 AM
#52
[*]GHS, my bad I couldn't see your "this thread is worthless without pics" smiley on my tapatalk app. My bad
GHS has much love for you
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
09-24-2013, 04:26 AM
#53
Originally Posted by gshadow325
I can't say many home mechanics are like me with a whole assortment of snap on tools and a 75 gallon air tank.
Your a tool. No pun intended.
SOLD Jan/15
03 V8 4x4 Limited, RAS converted to coil w/1.5 spacers, Bilstein 5100's 2.5" setting, 265/70R17 Grabber AT2s, FJ Rims, Custom headers, dual exhaust, 20% tint, HCF delete, VSC off mod, blacked-out headlights, WeatherTechs, TRD shift knob.
09-24-2013, 05:20 AM
#54
God blessed that nobody hurt.
Thanks for posting the information.
09-24-2013, 06:58 AM
#55
Real Name: Armando
Real Name: Armando
I had my Spidertraxx spacers installed by 4Wheel Parts store here in Austin this past February and haven't had any issues. I got my info from JA's 4runner website, which by the way, this dude is a 4runner genius. I wanted the aggressive stance while keeping my stock wheels, which I think look just fine. 4Wheel Parts store required that I bring my 4runner back in after 100 miles of driving to re-torque, otherwise I would void the warranty.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
09-27-2013, 11:39 PM
#56
I was in similar situation. same wheel, spidertraxx, but I was only going about 30 mph, and my wheel hit another person. it was all good though, it was dealership **** up installing the wheel, so they fixed it all. the problem was the spacer wasn't tightened, so when it fell off, it was still tight on the wheel.
09-28-2013, 03:26 AM
#57
I guess All-Pro uses these "fool proof" lugs for this reason. I was wondering how you were able to install the lugs backwards, but these were the only open end wheel spacer lugs I've used, and as you can tell - aren't able to be installed backwards.
WishIWentLongTravel 2006 V6 - Icon extended travel coilovers w/ resi, Total Chaos UCA, Wheelers Super bump's, Metal Tech "LT" w/ Icon VS 2, Metal Tech lower links, JBA Long Tube Headers, Dirtydeeds exhaust, Gunmetal Konig Countersteer X, B.A.M.F LCA Skids
09-28-2013, 07:18 AM
#58
@ kkz
those are 17mm head lugs you are referencing. With 19mm open end Acorn lugs you can install them backwards since the head is the same size as the lug. Nothing is fool proof, nothing! What seems logical to the 20 year veteran mechanic, can be effed up in 5 minutes by stupidity.
Things like this is why I want to do things myself. I have had customers come in telling me they just came from jiffy lube for a oil change and their car is leaking oil now. Come on does the car really need two oil filter gaskets?
Sad thing is 99% of these so called pros ase, fyi, bte, abc, pss, what ever acronyms they want to use to make them sound better, don't even own a torque wrench in their tool box. I am sure
@ BlackWorksInc
can attest to that. These mechanics think going to town with a air gun will suffice.
meanwhile in my personal home tool box i have one of these shiney snap on digital torque wrenches. has to do a head gasket, so perfect reason to buy a new tool LoL
09-28-2013, 11:36 AM
#59
Real Name: Ethan
Real Name: Ethan
@ kkz
@ BlackWorksInc
see post #53
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555
oh my god the erection I have from this thread is unreal.
04-24-2014, 05:47 PM
#60
Real Name: David
Real Name: David
Originally Posted by Sungod
.....Loctite is not something I would want to rely on. Buying correct fitting wheels is the better choice. .....
Do you ever fly a commercial airline? Ever relied on a weapons system to stop the bad guys from overrunning your position? You'd be suprised how much some of us rely on Loctite!
By the way, I understand your point was that relying on Loctite alone is foolish. Components have to be properly mated and correctly torqued and then at that point Loctite becomes worth far more than its weight in gold!
2007 V6 SR5 4WD - OME 884/Toytec Superflex with Bilstein 5100s - Air Lift 60809 Air Bags - Sixity Wheel Spacers - Draw-Tite 75155 Receiver - Tekonsha P3 Electric Brake Controller - B&M 70264 Tranny Cooler
2006 Jayco Jay Series 1206 PUP - 3450 lb GVWR/14' Carson Landscape Trailer - 7000 lb GVWR/16' Wells Cargo Enclosed Trailer - 7000 lb
16-19 MPG City/20-22 MPG Highway/17-20 MPG w/Jayco @ 55 MPH/16-19 MPG with Landscape Trailer @ 5500lb @ 55 MPH/12-14 MPG with Enclosed Trailer at 55-60 MPH @ 6000lb - Pushing air sucks gas!
